global variable, prompt, dependency
Hi everyone,
My problem is the following. I would like to establish a dependency of a wave on a variable that I created using the doprompt operation :
Function bibi()
Variable j, m
Prompt j, "Enter j"
Prompt m, "Enter m"
Doprompt "Parameters", j, m
Make/D/O/N=10 theWave; edit theWave
theWave:=p*j+m
But I get this error message : "Can't use local variables in dependency formula".
So I changed the function as following :
Function bibi()
Variable/G j, m
Prompt j, "Enter j"
Prompt m, "Enter m"
theWave:=p*j+m
But now, the error message is : "Can't prompt for this type of variable".
So, my aim is to establish a wave dependency on a variable (so that I would only need to change the variable instead of using the entire macro/function to change the wave). Is there a trick to make a variable (created by prompt/doprompt) global ?
jjweimer
Here is one way. Before running this, do the following on the command line:
Make/N=10 theWave
variable/G tg, kg
theWave := jg*p + kg
display theWave
Then, you can cause changes by running the viaPrompt function.
Function viaPrompt()
	NVAR jg, kg
	wave theWave = root:theWave
	variable j, k
	Prompt j, "Enter j"
	Prompt m, "Enter k"
	Doprompt "Parameters", j, k
	jg = j
	kg = k
Here is another way using an input panel. Create theWave at the root level and run the Panel Macro named Input. This avoids the need for global variables.
#pragma rtGlobals=1		// Use modern global access method.
Function UpdateWave()
	variable j, k
	ControlInfo/W=Input setvarj
	j = V_value
	ControlInfo/W=Input setvark
	k = V_value
	theWave = j*p + k
Function SetVarProc(sva) : SetVariableControl
	STRUCT WMSetVariableAction &sva
	switch( sva.eventCode )
		case 1: // mouse up
		case 2: // Enter key
		case 3: // Live update
			Variable dval = sva.dval
			String sval = sva.sval
			UpdateWave()
			break
			break
	endswitch
Window Input() : Panel
	NewPanel /W=(403,74,562,159) as "Input"
	ShowTools/A
	SetVariable setvarj,pos={18,15},size={120,19},proc=SetVarProc,title="j = "
	SetVariable setvarj,fSize=12,value= _NUM:0
	SetVariable setvark,pos={15,40},size={120,19},proc=SetVarProc,title="k = "
	SetVariable setvark,fSize=12,value= _NUM:0
EndMacro
johnweeks
Yes. Create a local variable for Prompt/DoPrompt, then assign that local variable to a global variable created later. Also, the local name you use to refer to a wave in a function is a local reference. Use the SetFormula operation to create a dependency in a function:
Function bibi()
	Prompt j, "Enter j"
	Prompt m, "Enter m"
	Variable/G globalJ = j
	Variable/G globalm = m
	SetFormula theWave, "globalJ*p + globalm"
If you want to check for existence of the global variables, and use their current values as a default, do this:
Function bibi()
	Variable j = NumVarOrDefault("globalJ", 0)
	Variable m = NumVarOrDefault("globalm", 0)
	Prompt j, "Enter j"
	Prompt m, "Enter m"
Note that this code ignores the issue of Data Folders. The way this code is written, it will create the global variables in whatever data folder is the current data folder. It will only work correctly if the current data folder is the same as the last time. Most likely, that folder will be root: and you will get along for a long time without any problems. But as time passes you will start using data folders and then it will break mysteriously.
Using data folders correctly in a case like this is difficult. A poor solution, but one that will always work, is to simply always use root:
Function bibi()
	Variable j = NumVarOrDefault("root:globalJ", 0)
	Variable m = NumVarOrDefault("root:globalm", 0)
	Prompt j, "Enter j"
	Prompt m, "Enter m"
	Variable/G root:globalJ = j
	Variable/G root:globalm = m
	SetFormula theWave, "root:globalJ*p + root:globalm"
Simon87
Thanks a lot for your help !
I will use the solution given by johnweeks, it will be easier for me (I also tried to create a local variable and a global variable equal to the local one, but using ":=" and it didn't work, and I didn't know the setformula operation).
