If I press Shift and close a window, it saves without opening the dialog window. Is there a hot key to automatically not save a window and close it without opening the dialog window?
quoderatmac wrote: If I press Shift and close a window, it saves without opening the dialog window. Is there a hot key to automatically not save a window and close it without opening the dialog window?
It does not save the window in terms of creating a recreation macro, it rather hides the window, as far as I know. But if you press Alt (Mac) or Option (Windows) while closing a window, the window is killed with no dialog. See
Because I want to close a graph without saving 99% of the time, I have this running at startup:
ModifyBrowser slashK=1
(For some reason, this parameter is not documented for ModifyBrowser but still works)
That at least helps to get the desired behavior for graphs created from the data browser window.
A
February 22, 2012 at 09:18 am - Permalink
February 22, 2012 at 10:20 am - Permalink
February 23, 2012 at 05:23 am - Permalink
