Hot key for "no save" of window?
If I press Shift and close a window, it saves without opening the dialog window. Is there a hot key to automatically not save a window and close it without opening the dialog window?
awirsing
quoderatmac wrote: If I press Shift and close a window, it saves without opening the dialog window. Is there a hot key to automatically not save a window and close it without opening the dialog window?
It does not save the window in terms of creating a recreation macro, it rather hides the window, as far as I know. But if you press Alt (Mac) or Option (Windows) while closing a window, the window is killed with no dialog. See
DisplayHelpTopic "Close Window Dialog"
A
chozo
Because I want to close a graph without saving 99% of the time, I have this running at startup:
ModifyBrowser slashK=1
(For some reason, this parameter is not documented for ModifyBrowser but still works)
That at least helps to get the desired behavior for graphs created from the data browser window.
