String to ASCII
Hi at All,
I wuold like to convert a string of characters in ASCII values.
So I made a function using SSCANF:
Function/S str2ASCII(tmpstr)
	String tmpstr
	String tmpASCII
	Variable i=0, tmp, num=strlen(tmpstr)
	For (i=0;i<num;i+=1)
	sscanf tmpstr[i], "%c", tmp
	tmpASCII+=num2str(tmp)
return tmpASCII
So I check the function and It works. When I use the function:
String test
String test2
test2="Hello"
test=str2ASCII(test2)
"Attempt to use a null string variable" appears and this message "Missing text resource for error: 0" appears on the command line.
Where is the error? Because If I add print command in the function, a right result appears.
Thanks in advance.
Matteo
jjweimer
Try this
	string tmpstr
	string tmpASCII="" // required declaration here, otherwise string is NULL
	variable i, tmp, num=strlen(tmpstr)
	for (i=0;i<num;i+=1)
        return tmpASCII
which gives
•print str2ascii("Hello")
  72101108108111
hrodstein
Here is a solution that does not use sscanf:
Function/S Str2ASCII(str)
	string str
	String result = ""			// Initialize to empty string
	Variable i, count=strlen(str)
	for (i=0;i<count;i+=1)
	     String ch = str[i]
	     Variable num = char2num(ch)
	     result += num2str(num)
	return result
