Slider control for XY data does not work on waveform...how to do that ?
I use the following slider control code (thanks to "hrodstein") for applying slider control over a XY data ( actually to shift Y value ..like say Y=Y+5 through slider) and it works very well..but it does not work on waveform data like data created (fit_XData.x and fit_XData.d ) after doing a Gaussian fit on such XY data.
My question is what changes I need to do to have applicable also on waveform data.
Function/DF GetSupraPackageDFR()
    DFREF dfr = root:Packages:Supra
    if (DataFolderRefStatus(dfr) != 1)
        NewDataFolder /O root:Packages
        NewDataFolder /O root:Packages:Supra
        Variable/G dfr:gLastSliderValueAdded = 0
    return dfr
Function AddSliderValue(xWave, yWave, startX, endX, sliderValue)
    Wave xWave, yWave
    Variable startX, endX
    Variable sliderValue
    // Take the previously-added slider value, if any, into account
    DFREF dfr = GetSupraPackageDFR()
    NVAR gLastSliderValueAdded = dfr:gLastSliderValueAdded
    // To avoid accumulation of roundoff error we do this in two steps
    YWave -= (XWave>=startX && XWave<=endX) ? gLastSliderValueAdded : 0
    YWave += (XWave>=startX && XWave<=endX) ? sliderValue : 0
    gLastSliderValueAdded = sliderValue
[/quote]
supra wrote: I use the following slider control code ... My question is what changes I need to do to have applicable also on waveform data. ...
You might look in to the function x2pnt, leading I think to the following or its equivalent:
variable ps, pe
ps = x2pnt(ywave,startx)
pe = x2pnt(ywave,endx)
ywave[ps,pe] -= gLastSliderValueAdded
ywave[ps,pe] += slidervalue
Or alter the original code like this:
    if (WaveExists(xWave))
        YWave -= (pnt2x(YWave, p)>=startX && pnt2x(YWave, p)<=endX) ? gLastSliderValueAdded : 0
        YWave += (pnt2x(YWave, p)>=startX && pnt2x(YWave, p)<=endX) ? sliderValue : 0
JJWeimer's use of a variable to hold the result of pnt2x() would be a bit faster, but I don't think it will be noticeable in this application.
Thanks to jjweimer and Johnweeks...I used the following as suggested by Johnweeks and weimer...also I fogot to mention that in the main code I also have a option to put cursor on the data ( wave or XY) ..so that I can select a particular wave or XY data out of many wave / or XY and then can move the segment of the wave/XY ( usually the whole graph by putting the cursor at ends) by moving the slider.
Somehow I still didnt able to make it work on wave data.
    return dfr
Function MoveSegment(SliderValue)
    Variable SliderValue
    WAVE/Z yWave = CsrWaveRef(A)
    if (!WaveExists(yWave))         // Cursor is not on any wave
        return -1
    WAVE/Z xWave = CsrXWaveRef(A)
    if (!WaveExists(xWave))         // Cursor is not on XY pair
        return -1
    Variable startX = hcsr(A)
    Variable endX = hcsr(B)
    if (startX > endX)
        return -1
but somehow still it does not work ?
Try changing things this way ...
        return -1
//  this will exit the function when xWave does not exist
//  so no change will happen with scaled waves
// remove this segement of code
//  if (!WaveExists(xWave))         // Cursor is not on XY pair
//      return -1
//  endif
// this assures that start and end are arranged right regardless of cursors
    Variable startX = min(hcsr(A),hcsr(B))
    Variable endX = max(hcsr(B),hcsr(A))
// no longer needed here
//  if (startX > endX)
//      return -1
//  endif
Thank you so much J. J. Weimer...worked perfectly ...Thanks a lot for your kind help.
How about changing final part of the code to
        YWave(startX, endX) -=  gLastSliderValueAdded
        YWave(startX, endX) +=  sliderValue
The downside is that it employs a different syntax than the first part, but, at least for me, it's much easier to follow.
But maybe I miss something.
jtigor wrote: How about changing final part of the code to ...
I agree with your coding, but I could also be missing something.
