Benchmarks
I compared a 2006 vintage MacBook Pro (Core II Duo, 2.33GHz, 3GB) running OS X 10.4.11 with a 2010 MacBook Pro (i7, 2.66GHz, 8GB) running OS X 10.6.3. Igor Pro 6.20B02 was used in both cases. I used the Igor benchmark experiment (File->Example Experiments->Testing->Benchmark 2.02) and ran 121 iterations.
The total time to run the benchmark on the 2006 MacBook Pro was 54.77 seconds versus 30.35 on the 2010 MacBook Pro.
Here are the details:
**** test on Macintosh OS X10.6.3 using 6.20 and 121 passes; Mac Book Pro 2100 i7
Create new graph time: 124.98ms, relative speed= 1.78
big data update time: 58.25ms, relative speed= 1.37
curve fit time: 741.47µs, relative speed= 1.46
user curve fit time: 11.68ms, relative speed= 1.36
double complex fft time: 531.88µs, relative speed= 1.72
single complex fft time: 518.60µs, relative speed= 1.60
double real fft time: 255.68µs, relative speed= 1.58
single real fft time: 242.43µs, relative speed= 1.52
5 pass smooth time: 279.95µs, relative speed= 1.47
Sort 8192 points time: 11.84ms, relative speed= 1.62
WaveStats time: 139.58µs, relative speed= 1.45
simple eqn time: 470.12µs, relative speed= 1.11
exp eqn time: 634.93µs, relative speed= 1.35
sqrt eqn time: 498.00µs, relative speed= 1.38
sin eqn time: 324.76µs, relative speed= 1.44
User fit fctn time: 419.51µs, relative speed= 1.45
MatrixOp eqn time: 15.88µs, relative speed= 1.83
**** done ****
total test time= 30.3483
jjweimer
System: MacBook 1.83 GHz Intel Core 2 Duo, 2GB Ram + MacOS X 10.6.3 + Igor Pro 6.12
**** test on Macintosh OS X10.6.3 using 6.12 and 121 passes
Create new graph time: 202.17ms, relative speed= 1.48
big data update time: 99.08ms, relative speed= 1.45
curve fit time: 1.41ms, relative speed= 1.34
user curve fit time: 20.79ms, relative speed= 1.71
double complex fft time: 1.04ms, relative speed= 1.42
single complex fft time: 992.81µs, relative speed= 1.20
double real fft time: 482.43µs, relative speed= 1.17
single real fft time: 448.32µs, relative speed= 1.10
5 pass smooth time: 521.51µs, relative speed= 1.04
Sort 8192 points time: 24.95ms, relative speed= 1.53
WaveStats time: 248.28µs, relative speed= 1.07
simple eqn time: 467.41µs, relative speed= 2.99
exp eqn time: 745.09µs, relative speed= 2.70
sqrt eqn time: 781.24µs, relative speed= 2.26
sin eqn time: 577.25µs, relative speed= 2.01
User fit fctn time: 722.18µs, relative speed= 1.79
MatrixOp eqn time: 35.69µs, relative speed= 0.67
**** done ****
total test time= 50.1788
jjweimer
System: MacBook 1.83 GHz Intel Core 2 Duo, 2GB Ram + MacOS X 10.6.3 + Igor Pro 6.20b2
Create new graph time: 206.54ms, relative speed= 1.45
big data update time: 99.94ms, relative speed= 1.43
curve fit time: 1.39ms, relative speed= 1.35
user curve fit time: 20.61ms, relative speed= 1.72
single complex fft time: 991.39µs, relative speed= 1.20
double real fft time: 486.61µs, relative speed= 1.16
single real fft time: 445.80µs, relative speed= 1.10
5 pass smooth time: 521.13µs, relative speed= 1.04
Sort 8192 points time: 24.39ms, relative speed= 1.57
WaveStats time: 256.93µs, relative speed= 1.04
simple eqn time: 664.27µs, relative speed= 2.10
exp eqn time: 1.03ms, relative speed= 1.95
sqrt eqn time: 876.45µs, relative speed= 2.02
sin eqn time: 634.70µs, relative speed= 1.83
User fit fctn time: 761.85µs, relative speed= 1.70
MatrixOp eqn time: 34.83µs, relative speed= 0.69
**** done ****
total test time= 51.5081
Larry Hutchinson
Might as well add a recently acquired machine:
HP Pavilion p6320y running AMD Phenom II X4 820 and Windows7 64bit.
**** test on Personal (Build 7600)6.1.7600 using 6.12 and 121 passes; HP AMD Phenom II x4
Create new graph time: 100.18ms, relative speed= 2.99
big data update time: 90.35ms, relative speed= 1.58
user curve fit time: 15.09ms, relative speed= 2.35
single complex fft time: 791.35µs, relative speed= 1.50
double real fft time: 408.08µs, relative speed= 1.38
single real fft time: 403.26µs, relative speed= 1.22
5 pass smooth time: 339.44µs, relative speed= 1.60
Sort 8192 points time: 14.31ms, relative speed= 2.67
WaveStats time: 630.31µs, relative speed= 0.42
simple eqn time: 534.88µs, relative speed= 2.61
exp eqn time: 824.48µs, relative speed= 2.44
sqrt eqn time: 717.41µs, relative speed= 2.47
sin eqn time: 645.37µs, relative speed= 1.80
User fit fctn time: 548.14µs, relative speed= 2.36
MatrixOp eqn time: 22.26µs, relative speed= 1.07
**** done ****
total test time= 35.2478
mtaylor
I just upgraded my mobile machine, so I'm posting benchmarks here as a point of reference for anybody considering an upgrade. My old machine was a 2.2 GHz Core2 duo from 2007 or so.
Early 2011 Macbook Pro with 8 GB of Ram, 1 GB vram, 5400 RPM HDD
**** test on Macintosh OS X10.6.7 using 6.21 and 121 passes; Early 2011 MBP
Create new graph time: 118.60ms, relative speed= 2.52
big data update time: 50.81ms, relative speed= 2.82
curve fit time: 654.89µs, relative speed= 2.88
user curve fit time: 6.45ms, relative speed= 5.50
double complex fft time: 422.30µs, relative speed= 3.49
single complex fft time: 403.66µs, relative speed= 2.94
double real fft time: 205.60µs, relative speed= 2.74
single real fft time: 198.97µs, relative speed= 2.47
5 pass smooth time: 256.83µs, relative speed= 2.11
Sort 8192 points time: 11.14ms, relative speed= 3.43
WaveStats time: 134.72µs, relative speed= 1.98
simple eqn time: 267.20µs, relative speed= 5.22
exp eqn time: 397.90µs, relative speed= 5.05
sqrt eqn time: 295.25µs, relative speed= 5.99
sin eqn time: 281.92µs, relative speed= 4.13
User fit fctn time: 204.35µs, relative speed= 6.32
MatrixOp eqn time: 11.86µs, relative speed= 2.01
**** done ****
total test time= 26.1131
This laptop has two gpu's in it, and it didn't seem to matter which one was enabled at the time of testing (forced by gfxCardStatus 2.0.1). Also, I was able to decrease the total test time by about 9 seconds by hiding the application while it ran (cmd-h), reminding us that suppressing graphics is a great way to get faster performance with current hardware, without the need to upgrade.
I will post another update with a workstation running a 6-core 3.2GHz i980x cpu later this week.
mtaylor
As promised, here is a dell workstation with the 6-core i7 in it.
**** test on Professional Service Pack 1 (Build 7601)6.1.7601 using 6.21 and 121 passes; i7-980X
Create new graph time: 56.38ms, relative speed= 5.31
big data update time: 57.46ms, relative speed= 2.49
curve fit time: 881.71µs, relative speed= 2.14
user curve fit time: 6.98ms, relative speed= 5.08
double complex fft time: 569.89µs, relative speed= 2.58
single complex fft time: 534.00µs, relative speed= 2.22
double real fft time: 283.55µs, relative speed= 1.99
single real fft time: 259.83µs, relative speed= 1.89
5 pass smooth time: 223.35µs, relative speed= 2.43
Sort 8192 points time: 8.93ms, relative speed= 4.28
WaveStats time: 383.77µs, relative speed= 0.70
simple eqn time: 322.31µs, relative speed= 4.33
exp eqn time: 493.32µs, relative speed= 4.08
sqrt eqn time: 429.01µs, relative speed= 4.12
sin eqn time: 443.55µs, relative speed= 2.62
User fit fctn time: 242.02µs, relative speed= 5.34
MatrixOp eqn time: 15.18µs, relative speed= 1.57
**** done ****
total test time= 20.8849
jjweimer
I was also able to shave about 10s off the total time on a MacBook Pro by hiding Igor during the test.
thomas_braun
**** test on Windows XP Professional Service Pack 3 (Build 2600)5.1.2600 using 6.22 and 121 passes; AMD Dual X2 3800+ 2GB RAM
Create new graph time: 201.20ms, relative speed= 1.49
big data update time: 134.42ms, relative speed= 1.07
curve fit time: 1.80ms, relative speed= 1.05
user curve fit time: 17.82ms, relative speed= 1.99
double complex fft time: 1.58ms, relative speed= 0.93
single complex fft time: 1.16ms, relative speed= 1.02
double real fft time: 550.47µs, relative speed= 1.03
single real fft time: 591.89µs, relative speed= 0.83
5 pass smooth time: 507.10µs, relative speed= 1.07
Sort 8192 points time: 19.62ms, relative speed= 1.95
WaveStats time: 287.52µs, relative speed= 0.93
simple eqn time: 856.57µs, relative speed= 1.63
exp eqn time: 1.30ms, relative speed= 1.54
sqrt eqn time: 1.12ms, relative speed= 1.58
sin eqn time: 906.11µs, relative speed= 1.28
User fit fctn time: 547.45µs, relative speed= 2.36
MatrixOp eqn time: 41.59µs, relative speed= 0.57
**** done ****
total test time= 60.3425
I've got the highest test time! (And a pretty old machine too.)
jdorsey
Old laptop (dual core Centrino) running Linux, Igor under Wine. No idea why Igor thinks it's running on a G5 - I have the Windows version of Igor installed.
**** test on Professional (Build 7600)6.1.7600 using 6.20 and 121 passes; Dual 2 GHz PowerPC G5 Mac Pro
Create new graph time: 769.24ms, relative speed= 0.39
big data update time: 134.70ms, relative speed= 1.06
curve fit time: 15.96ms, relative speed= 0.12
user curve fit time: 19.53ms, relative speed= 1.82
double complex fft time: 939.57µs, relative speed= 1.57
single complex fft time: 869.26µs, relative speed= 1.37
double real fft time: 459.42µs, relative speed= 1.23
single real fft time: 416.98µs, relative speed= 1.18
5 pass smooth time: 330.39µs, relative speed= 1.64
Sort 8192 points time: 14.38ms, relative speed= 2.66
WaveStats time: 647.14µs, relative speed= 0.41
simple eqn time: 334.59µs, relative speed= 4.17
exp eqn time: 647.36µs, relative speed= 3.11
sqrt eqn time: 485.81µs, relative speed= 3.64
sin eqn time: 646.08µs, relative speed= 1.80
User fit fctn time: 369.56µs, relative speed= 3.50
MatrixOp eqn time: 123.93µs, relative speed= 0.19
**** done ****
total test time= 156.86
mtaylor
The processor type info is entered by the user when you run the test. A dual G5 is the default and is what was used to establish the baseline of 1.0x speed.
I updated my posts because I mis-identified the processor I Was testing (it is a 980X)
I threw all the data here on a graph, along with some other benchmarks I've made and have some questions about consistency of the benchmark...
First of all, the first part of the test takes the longest amount of time to complete and is graphics intensive. The time to complete the benchmark isn't a real measure of only the cpu performance, but of the graphics system, which is strongly both OS and gpu dependent. Because of this, you can't really compare CPU vs. CPU based solely on the time to complete the test, especially across platforms.
The desktop machines reported(i980x, phenom) lagged behind severely in the wavestats test, while the laptops excelled... Why is this, I wonder?
My i980x should theoretically be mopping the floor with my laptop i7, as it has roughly 50% higher clock speed per core and about 50% the memory bandwidth… However, it only wins out in 4 of the 16 tests, one of which is the graphics test...
Perhaps it is time to update the benchmark with some multi-threaded tests?
BMangum
Core i7 860 @2.8 GHz; 4 GB Ram; NVIDIA Quadro NVS 290
64bit Win7 with 32 Bit Igor Igor 6.21
32.1 s with the window open vs 27.5 s with Igor minimized - see below
Igor window Open:
**** test on Professional (Build 7600)6.1.7600 using 6.21 and 121 passes; Core i7 860 @ 2.8 GHz 64bit Win7 4 Gb Ram
Create new graph time: 113.80ms, relative speed= 2.63
big data update time: 67.45ms, relative speed= 2.12
curve fit time: 899.39µs, relative speed= 2.10
user curve fit time: 7.12ms, relative speed= 4.98
double complex fft time: 577.78µs, relative speed= 2.55
single complex fft time: 551.85µs, relative speed= 2.15
double real fft time: 285.08µs, relative speed= 1.98
single real fft time: 262.26µs, relative speed= 1.88
5 pass smooth time: 214.49µs, relative speed= 2.53
Sort 8192 points time: 8.73ms, relative speed= 4.38
WaveStats time: 369.70µs, relative speed= 0.72
simple eqn time: 363.76µs, relative speed= 3.84
exp eqn time: 471.47µs, relative speed= 4.26
sqrt eqn time: 436.31µs, relative speed= 4.05
sin eqn time: 432.44µs, relative speed= 2.69
User fit fctn time: 242.62µs, relative speed= 5.33
MatrixOp eqn time: 14.58µs, relative speed= 1.64
**** done ****
total test time= 32.122
Igor Minimized:
Create new graph time: 100.13ms, relative speed= 2.99
big data update time: 67.06ms, relative speed= 2.13
curve fit time: 897.49µs, relative speed= 2.10
user curve fit time: 7.13ms, relative speed= 4.97
double complex fft time: 577.56µs, relative speed= 2.55
single complex fft time: 541.11µs, relative speed= 2.20
double real fft time: 285.11µs, relative speed= 1.98
single real fft time: 262.05µs, relative speed= 1.88
5 pass smooth time: 221.16µs, relative speed= 2.45
Sort 8192 points time: 8.70ms, relative speed= 4.39
WaveStats time: 379.42µs, relative speed= 0.70
simple eqn time: 363.05µs, relative speed= 3.84
sqrt eqn time: 437.58µs, relative speed= 4.04
sin eqn time: 432.42µs, relative speed= 2.69
User fit fctn time: 242.58µs, relative speed= 5.33
MatrixOp eqn time: 14.60µs, relative speed= 1.64
**** done ****
total test time= 27.4538
mtaylor
I discovered this morning that globally disabling vsync on my mac leads to a major speedup in the graphical part of the benchmark.
To do this, install the apple developer tools (Xcode) located on your os X install disc. Then, use the Quartz Debug application located here:
/Developer/Applications/Performance Tools/Quartz Debug
Click Window-> Quartz Debug Settings.
Choose Beam Sync -> Disable
The reason for the speedup is that vsync only allows one frame to be drawn per refresh. My laptop defaults to 60 Hz, so the maximum number of frames per second is 60. Indeed, during the benchmark, I was pulling 57-59 fps (checked by at-monitor). After disabling vsync, I was seeing numbers between 320-340 fps instantaneous and 160 fps average.
All other parts of the test were unaffected by this, so if you need to draw graphs very quickly, you might consider disabling vsync and see if it gives any performance improvement.
Create new graph time: 122.34ms, relative speed= 2.45 (Vsync automatic)
Create new graph time: 81.75ms, relative speed= 3.66 (Vsync off); 49% faster
Edit:
Additional gains were realized by disabling 2D acceleration.
Create new graph time: 77.01ms, relative speed= 3.89 (Vsync off, 2D Acceleration off); 58% faster
And surprising marginal gains were again seen by forcing the cpu integrated graphics using gfxCardStatus 2.01.
Create new graph time: 74.85ms, relative speed= 4.00 (Vsync off, 2D Acceleration off, int. gpu forced); 63% faster
sdriscoll
12-core Xeon Mac Pro with an 8-core process running simultaneously + one additional single-core process running as well
**** test on Macintosh OS X10.7.2 using 6.22 and 121 passes; 2 x 2.93 GHz 6-Core Xeon Mac Pro, 32 GB
Create new graph time: 126.72ms, relative speed= 2.36
big data update time: 61.70ms, relative speed= 2.32
curve fit time: 751.68µs, relative speed= 2.51
user curve fit time: 7.11ms, relative speed= 4.99
double complex fft time: 491.70µs, relative speed= 2.99
single complex fft time: 499.29µs, relative speed= 2.38
double real fft time: 239.37µs, relative speed= 2.36
single real fft time: 226.45µs, relative speed= 2.17
5 pass smooth time: 290.15µs, relative speed= 1.87
Sort 8192 points time: 12.36ms, relative speed= 3.09
WaveStats time: 139.59µs, relative speed= 1.91
simple eqn time: 366.47µs, relative speed= 3.81
exp eqn time: 547.17µs, relative speed= 3.67
sqrt eqn time: 400.80µs, relative speed= 4.41
sin eqn time: 312.43µs, relative speed= 3.72
User fit fctn time: 240.22µs, relative speed= 5.38
MatrixOp eqn time: 12.96µs, relative speed= 1.84
**** done ****
total test time= 29.9256
With Igor hidden (which is cheating of course)
Create new graph time: 73.08ms, relative speed= 4.10
big data update time: 61.36ms, relative speed= 2.33
curve fit time: 746.97µs, relative speed= 2.53
user curve fit time: 7.27ms, relative speed= 4.88
double complex fft time: 492.37µs, relative speed= 2.99
single complex fft time: 498.94µs, relative speed= 2.38
double real fft time: 239.61µs, relative speed= 2.36
single real fft time: 225.67µs, relative speed= 2.18
5 pass smooth time: 288.36µs, relative speed= 1.88
Sort 8192 points time: 12.35ms, relative speed= 3.10
WaveStats time: 139.36µs, relative speed= 1.91
simple eqn time: 362.95µs, relative speed= 3.85
exp eqn time: 546.15µs, relative speed= 3.68
sqrt eqn time: 403.36µs, relative speed= 4.39
sin eqn time: 312.17µs, relative speed= 3.73
User fit fctn time: 239.06µs, relative speed= 5.41
MatrixOp eqn time: 12.87µs, relative speed= 1.86
**** done ****
total test time= 22.327
sdriscoll
The other computer at my desk...sitting idle except for this test
**** test on Professional Service Pack 2 (Build 3790)5.2.3790 using 6.22 and 121 passes; 2.60 GHz AMD Phenom 9950, 16 GB, Win XP 64
Create new graph time: 122.29ms, relative speed= 2.45
big data update time: 85.79ms, relative speed= 1.67
curve fit time: 1.32ms, relative speed= 1.43
user curve fit time: 9.89ms, relative speed= 3.59
double complex fft time: 1.03ms, relative speed= 1.43
single complex fft time: 865.34µs, relative speed= 1.37
double real fft time: 422.99µs, relative speed= 1.33
single real fft time: 439.24µs, relative speed= 1.12
5 pass smooth time: 341.78µs, relative speed= 1.59
Sort 8192 points time: 13.52ms, relative speed= 2.83
WaveStats time: 185.53µs, relative speed= 1.44
simple eqn time: 612.97µs, relative speed= 2.28
exp eqn time: 941.52µs, relative speed= 2.14
sqrt eqn time: 790.28µs, relative speed= 2.24
sin eqn time: 679.69µs, relative speed= 1.71
User fit fctn time: 371.28µs, relative speed= 3.48
MatrixOp eqn time: 26.01µs, relative speed= 0.92
**** done ****
total test time= 39.499
With Igor minimized this drops to 28.7802 s. Probably because the "Create new graph time" is cut almost in half.
mtaylor
Other factors...
Any processor with turbo-boost is inherently difficult to benchmark. Turbo boost is a technology that automatically over clocks your processor by steps, depending on the temperature, power consumption and number of active cores. Because of this issue, you may not be running full speed as you think you are. I have found, however, that my simulations finish quicker if I just point a fan at my laptop while it is grinding away.
A nice overview of turbo-boost can be found on wikipedia. I have attached my latest benchmark below, with integrated graphics forced, disabled 2D acceleration and beam sync via quartz debug.
**** test on Macintosh OS X10.7.2 using 6.22 and 121 passes; 2.2 GHz Quad core MBP 8,2, 8 GB ram
Create new graph time: 85.48ms, relative speed= 3.50
big data update time: 54.32ms, relative speed= 2.64
curve fit time: 650.88µs, relative speed= 2.90
user curve fit time: 7.35ms, relative speed= 4.82
double complex fft time: 423.66µs, relative speed= 3.48
single complex fft time: 407.57µs, relative speed= 2.91
double real fft time: 207.15µs, relative speed= 2.72
single real fft time: 199.60µs, relative speed= 2.47
5 pass smooth time: 260.13µs, relative speed= 2.09
Sort 8192 points time: 11.27ms, relative speed= 3.39
WaveStats time: 138.01µs, relative speed= 1.93
simple eqn time: 269.35µs, relative speed= 5.18
exp eqn time: 402.24µs, relative speed= 5.00
sqrt eqn time: 299.86µs, relative speed= 5.90
sin eqn time: 283.29µs, relative speed= 4.11
User fit fctn time: 205.88µs, relative speed= 6.28
MatrixOp eqn time: 11.72µs, relative speed= 2.04
**** done ****
total test time= 23.1571
thomas_braun
Some numbers of my new machine. As the previois poster noted CPUs with Turbo Boost are difficult to benchmark properly. All benchmarks were acquired watching Igor drawing.
Igor (64-bit)
**** test on Win7 Professional Service Pack 1 (Build 7601)6.1.7601 using 6.23 and 121 passes; i7-3930K 6 cores Win7 x64 Igor x64, 32GB RAM Create new graph time: 64.89ms, relative speed= 4.61 big data update time: 39.63ms, relative speed= 3.61 curve fit time: 506.93µs, relative speed= 3.72 user curve fit time: 3.73ms, relative speed= 9.52 double complex fft time: 372.70µs, relative speed= 3.95 single complex fft time: 348.10µs, relative speed= 3.41 double real fft time: 179.75µs, relative speed= 3.14 single real fft time: 172.00µs, relative speed= 2.86 5 pass smooth time: 163.65µs, relative speed= 3.32 Sort 8192 points time: 7.39ms, relative speed= 5.17 WaveStats time: 81.90µs, relative speed= 3.26 simple eqn time: 171.18µs, relative speed= 8.15 exp eqn time: 278.05µs, relative speed= 7.23 sqrt eqn time: 207.41µs, relative speed= 8.53 sin eqn time: 212.89µs, relative speed= 5.46 User fit fctn time: 136.67µs, relative speed= 9.46 MatrixOp eqn time: 14.07µs, relative speed= 1.70 **** done **** total test time= 18.1146
Igor (32-bit)
**** test on Professional Service Pack 1 (Build 7601)6.1.7601 using 6.22 and 121 passes; i7-3930K 6 cores Win7 x64 Igor x32, 32GB RAM Create new graph time: 75.43ms, relative speed= 3.97 big data update time: 47.65ms, relative speed= 3.00 curve fit time: 604.79µs, relative speed= 3.12 user curve fit time: 4.85ms, relative speed= 7.31 double complex fft time: 464.54µs, relative speed= 3.17 single complex fft time: 342.43µs, relative speed= 3.47 double real fft time: 300.30µs, relative speed= 1.88 single real fft time: 181.83µs, relative speed= 2.71 5 pass smooth time: 189.11µs, relative speed= 2.87 Sort 8192 points time: 7.62ms, relative speed= 5.02 WaveStats time: 94.29µs, relative speed= 2.83 simple eqn time: 169.04µs, relative speed= 8.26 exp eqn time: 275.59µs, relative speed= 7.29 sqrt eqn time: 211.72µs, relative speed= 8.35 sin eqn time: 224.09µs, relative speed= 5.19 User fit fctn time: 148.07µs, relative speed= 8.73 MatrixOp eqn time: 13.62µs, relative speed= 1.75 **** done **** total test time= 21.2596
Igor 64bit with data from Igor 32bit as baseline
**** test on Professional Service Pack 1 (Build 7601)6.1.7601 using 6.23 and 121 passes; Create new graph time: 65.97ms, relative speed= 1.14 big data update time: 39.63ms, relative speed= 1.20 curve fit time: 504.63µs, relative speed= 1.19 user curve fit time: 3.71ms, relative speed= 1.29 double complex fft time: 373.09µs, relative speed= 1.27 single complex fft time: 348.21µs, relative speed= 1.00 double real fft time: 180.32µs, relative speed= 1.63 single real fft time: 174.40µs, relative speed= 1.02 5 pass smooth time: 166.75µs, relative speed= 1.14 Sort 8192 points time: 7.39ms, relative speed= 1.03 WaveStats time: 85.07µs, relative speed= 1.11 simple eqn time: 156.02µs, relative speed= 1.08 exp eqn time: 267.04µs, relative speed= 1.05 sqrt eqn time: 187.18µs, relative speed= 1.13 sin eqn time: 207.08µs, relative speed= 1.08 User fit fctn time: 131.58µs, relative speed= 1.14 MatrixOp eqn time: 14.07µs, relative speed= 0.89 **** done **** total test time= 17.7826
BMangum
I got a new core i7 ivy bridge machine...
**** test on WIN 7 using 6.30 and 121 passes; Core i7 3770k
Create new graph time: 37.44ms, relative speed= 8.00
big data update time: 35.44ms, relative speed= 4.04
curve fit time: 800.36µs, relative speed= 2.36
user curve fit time: 3.60ms, relative speed= 9.84
double complex fft time: 334.91µs, relative speed= 4.40
single complex fft time: 304.25µs, relative speed= 3.90
double real fft time: 158.36µs, relative speed= 3.56
single real fft time: 150.02µs, relative speed= 3.28
5 pass smooth time: 150.45µs, relative speed= 3.61
Sort 8192 points time: 6.84ms, relative speed= 5.59
WaveStats time: 80.29µs, relative speed= 3.32
simple eqn time: 139.34µs, relative speed= 10.02
exp eqn time: 229.45µs, relative speed= 8.76
sqrt eqn time: 177.05µs, relative speed= 9.99
sin eqn time: 176.52µs, relative speed= 6.59
User fit fctn time: 111.33µs, relative speed= 11.61
MatrixOp eqn time: 12.62µs, relative speed= 1.89
**** done ****
total test time= 12.759
johnweeks
BMangum wrote: **** test on WIN 7 using 6.30 and 121 passes; Core i7 3770k
If you get the latest build you will get the fix for this slow-down that I introduced when I fixed a bug in curve fit threading.
jjweimer
With Igor Pro in front and command window visible ...
**** test on Macintosh OS X10.9.2 using 6.34 and 121 passes
**** MacBook Pro Late 2013 2.6 GHz I7 16GB RAM OS 10.9.2
Create new graph time: 118.84ms, relative speed= 2.52
big data update time: 42.63ms, relative speed= 3.36
curve fit time: 518.17µs, relative speed= 3.64
user curve fit time: 4.39ms, relative speed= 8.08
double complex fft time: 322.54µs, relative speed= 4.57
single complex fft time: 298.06µs, relative speed= 3.99
double real fft time: 150.95µs, relative speed= 3.74
single real fft time: 142.81µs, relative speed= 3.45
5 pass smooth time: 207.85µs, relative speed= 2.61
Sort 8192 points time: 8.88ms, relative speed= 4.30
WaveStats time: 97.10µs, relative speed= 2.75
simple eqn time: 174.01µs, relative speed= 8.02
exp eqn time: 280.15µs, relative speed= 7.18
sqrt eqn time: 192.89µs, relative speed= 9.17
sin eqn time: 220.06µs, relative speed= 5.28
User fit fctn time: 140.25µs, relative speed= 9.22
MatrixOp eqn time: 10.79µs, relative speed= 2.21
**** done ****
total test time= 24.2226
With command window closed and Igor Pro put in background as quickly as possible ...
Create new graph time: 56.47ms, relative speed= 5.30
big data update time: 41.74ms, relative speed= 3.43
curve fit time: 518.24µs, relative speed= 3.64
user curve fit time: 4.40ms, relative speed= 8.06
double complex fft time: 328.25µs, relative speed= 4.49
single complex fft time: 299.51µs, relative speed= 3.97
double real fft time: 154.07µs, relative speed= 3.66
single real fft time: 143.35µs, relative speed= 3.43
5 pass smooth time: 207.10µs, relative speed= 2.62
Sort 8192 points time: 8.83ms, relative speed= 4.33
WaveStats time: 96.47µs, relative speed= 2.77
simple eqn time: 174.03µs, relative speed= 8.02
exp eqn time: 280.48µs, relative speed= 7.17
sqrt eqn time: 192.81µs, relative speed= 9.17
sin eqn time: 219.49µs, relative speed= 5.30
User fit fctn time: 138.19µs, relative speed= 9.35
MatrixOp eqn time: 9.66µs, relative speed= 2.47
**** done ****
total test time= 16.2594
jjweimer
thomas_braun wrote: @jjweimer: Can you repost with 121 iterations instead of 21? This would greatly simplify the comparison :)
Did it!
jjweimer
johnweeks wrote: I presume that you posted this to show the contrast in Create New Graph time.
Yes.
mtaylor
**** test on Macintosh OS X10.9.3 using 6.34 and 121 passes; late 2012 mac mini Quad Core 2.6 GHz core i7, 16GB ram, SSD, intel 4000 gfx
Create new graph time: 126.15ms, relative speed= 2.37
big data update time: 49.75ms, relative speed= 2.88
curve fit time: 577.79µs, relative speed= 3.26
user curve fit time: 5.43ms, relative speed= 6.54
double complex fft time: 352.52µs, relative speed= 4.18
single complex fft time: 336.69µs, relative speed= 3.53
double real fft time: 181.27µs, relative speed= 3.11
single real fft time: 174.31µs, relative speed= 2.82
5 pass smooth time: 228.26µs, relative speed= 2.38
Sort 8192 points time: 9.92ms, relative speed= 3.86
WaveStats time: 118.96µs, relative speed= 2.24
simple eqn time: 203.24µs, relative speed= 6.87
exp eqn time: 318.22µs, relative speed= 6.32
sqrt eqn time: 233.84µs, relative speed= 7.56
sin eqn time: 240.80µs, relative speed= 4.83
User fit fctn time: 162.32µs, relative speed= 7.96
MatrixOp eqn time: 10.57µs, relative speed= 2.26
**** done ****
total test time= 26.9465
mtaylor
Just updating a new data point with a current generation CPU
32 bit Igor
**** test on Windows 8 Professional (Build 9200)6.2.9200 using 6.34 and 121 passes; i7 4970k @ 4.9Ghz
Create new graph time: 52.44ms, relative speed= 5.71
big data update time: 32.97ms, relative speed= 4.34
curve fit time: 419.00µs, relative speed= 4.50
user curve fit time: 3.15ms, relative speed= 11.25
double complex fft time: 345.18µs, relative speed= 4.27
single complex fft time: 240.33µs, relative speed= 4.94
double real fft time: 164.28µs, relative speed= 3.44
single real fft time: 121.42µs, relative speed= 4.05
5 pass smooth time: 101.68µs, relative speed= 5.34
Sort 8192 points time: 4.82ms, relative speed= 7.93
WaveStats time: 60.87µs, relative speed= 4.38
simple eqn time: 118.00µs, relative speed= 11.83
exp eqn time: 191.99µs, relative speed= 10.47
sqrt eqn time: 144.75µs, relative speed= 12.22
sin eqn time: 157.84µs, relative speed= 7.37
User fit fctn time: 98.34µs, relative speed= 13.14
MatrixOp eqn time: 10.86µs, relative speed= 2.20
**** done ****
total test time= 13.6788
64-bit Igor
Create new graph time: 47.80ms, relative speed= 6.26
big data update time: 27.30ms, relative speed= 5.25
curve fit time: 1.93ms, relative speed= 0.98
user curve fit time: 2.61ms, relative speed= 13.60
double complex fft time: 277.13µs, relative speed= 5.31
single complex fft time: 243.02µs, relative speed= 4.89
double real fft time: 131.44µs, relative speed= 4.29
single real fft time: 124.43µs, relative speed= 3.95
5 pass smooth time: 113.22µs, relative speed= 4.79
Sort 8192 points time: 4.47ms, relative speed= 8.55
WaveStats time: 49.68µs, relative speed= 5.37
simple eqn time: 107.31µs, relative speed= 13.01
exp eqn time: 213.34µs, relative speed= 9.42
sqrt eqn time: 125.92µs, relative speed= 14.05
sin eqn time: 134.37µs, relative speed= 8.66
User fit fctn time: 91.95µs, relative speed= 14.06
MatrixOp eqn time: 12.12µs, relative speed= 1.97
**** done ****
total test time= 12.3603
Even though the 64-bit version outperformed the 32-bit version overall, it is curious that it falls flat on the curve fit test. Does anyone have an ideal why this might be?
johnweeks
mtaylor wrote: Even though the 64-bit version outperformed the 32-bit version overall, it is curious that it falls flat on the curve fit test. Does anyone have an ideal why this might be?
That is odd.
ChrLie
hmm, the comparison between IP6 and IP7 surprised me a bit!
**** test on Macintosh OS X10.11.6 using 6.37 and 121 passes; iMac (Retina 5K, 27-inch, Late 2015)
Create new graph time: 164.28ms, relative speed= 1.82
big data update time: 40.53ms, relative speed= 3.53
curve fit time: 563.94µs, relative speed= 3.34
user curve fit time: 4.48ms, relative speed= 7.92
double complex fft time: 315.65µs, relative speed= 4.67
single complex fft time: 278.30µs, relative speed= 4.27
double real fft time: 148.55µs, relative speed= 3.80
single real fft time: 133.43µs, relative speed= 3.69
5 pass smooth time: 201.60µs, relative speed= 2.69
Sort 8192 points time: 8.40ms, relative speed= 4.55
WaveStats time: 105.02µs, relative speed= 2.54
simple eqn time: 173.16µs, relative speed= 8.06
exp eqn time: 306.49µs, relative speed= 6.56
sqrt eqn time: 193.90µs, relative speed= 9.12
sin eqn time: 230.50µs, relative speed= 5.05
User fit fctn time: 132.54µs, relative speed= 9.75
MatrixOp eqn time: 19.50µs, relative speed= 1.23
**** done ****
total test time= 30.6379
**** test on Macintosh OS X10.11.6 using 7.00 and 121 passes; iMac (Retina 5K, 27-inch, Late 2015)
Create new graph time: 223.85ms, relative speed= 1.34
big data update time: 155.12ms, relative speed= 0.92
curve fit time: 221.20µs, relative speed= 8.53
user curve fit time: 3.59ms, relative speed= 9.89
double complex fft time: 359.19µs, relative speed= 4.10
single complex fft time: 337.72µs, relative speed= 3.52
double real fft time: 179.87µs, relative speed= 3.14
single real fft time: 165.10µs, relative speed= 2.98
5 pass smooth time: 117.49µs, relative speed= 4.62
Sort 8192 points time: 6.37ms, relative speed= 6.01
WaveStats time: 36.86µs, relative speed= 7.24
simple eqn time: 194.48µs, relative speed= 7.18
exp eqn time: 280.49µs, relative speed= 7.17
sqrt eqn time: 219.87µs, relative speed= 8.04
sin eqn time: 221.08µs, relative speed= 5.26
User fit fctn time: 119.42µs, relative speed= 10.82
MatrixOp eqn time: 21.62µs, relative speed= 1.11
**** done ****
total test time= 55.7927
jjweimer
ChrLie wrote: hmm, the comparison between IP6 and IP7 surprised me a bit!
The biggest slow downs seem to be in the graphics operations. Perhaps not surprising since IP7 supports Retina?
Modest slow downs in some operations are interesting.
Big speed ups in MatrixOP and other functions are good news.
Thanks.
ChrLie
You're right! This is what Wavemetrics says:
"Macintosh Retina and Windows high-resolution displays bring a more pleasing visual experience but also present performance challenges. Previously, one point lines were one pixel wide. Now, on high-resolution displays, such lines are two pixels wide and, depending on the operating system, graphics technology and the actual data, drawing can be thousands of times slower."
thomas_braun
**** test on Windows 7 Professional6.1.7601 using 7.01 and 121 passes; Dual 2 GHz PowerPC G5 Mac Pro
Create new graph time: 216.92ms, relative speed= 1.38
big data update time: 118.53ms, relative speed= 1.21
curve fit time: 283.17µs, relative speed= 6.66
user curve fit time: 4.66ms, relative speed= 7.61
double complex fft time: 326.21µs, relative speed= 4.51
single complex fft time: 296.96µs, relative speed= 4.00
double real fft time: 157.68µs, relative speed= 3.58
single real fft time: 142.47µs, relative speed= 3.45
5 pass smooth time: 117.64µs, relative speed= 4.61
Sort 8192 points time: 9.04ms, relative speed= 4.23
WaveStats time: 103.43µs, relative speed= 2.58
simple eqn time: 206.61µs, relative speed= 6.76
exp eqn time: 293.18µs, relative speed= 6.86
sqrt eqn time: 245.06µs, relative speed= 7.22
sin eqn time: 245.11µs, relative speed= 4.74
User fit fctn time: 188.31µs, relative speed= 6.86
MatrixOp eqn time: 28.77µs, relative speed= 0.83
**** done ****
total test time= 47.7564
And now with testing IP6 using the IP7 measurement as baseline.
**** test on Windows 7 Professional Service Pack 1 (Build 7601)6.1.7601 using 6.38 and 121 passes; Dual 2 GHz PowerPC G5 Mac Pro
Create new graph time: 102.42ms, relative speed= 2.16
big data update time: 46.29ms, relative speed= 2.56
curve fit time: 619.97µs, relative speed= 0.47
user curve fit time: 5.07ms, relative speed= 0.92
double complex fft time: 470.59µs, relative speed= 0.68
single complex fft time: 339.95µs, relative speed= 0.88
double real fft time: 292.47µs, relative speed= 0.54
single real fft time: 169.93µs, relative speed= 0.85
5 pass smooth time: 173.53µs, relative speed= 0.73
Sort 8192 points time: 7.17ms, relative speed= 1.27
WaveStats time: 100.26µs, relative speed= 1.17
simple eqn time: 169.21µs, relative speed= 1.22
exp eqn time: 283.68µs, relative speed= 1.04
sqrt eqn time: 215.74µs, relative speed= 1.13
sin eqn time: 227.13µs, relative speed= 1.08
User fit fctn time: 168.51µs, relative speed= 1.10
MatrixOp eqn time: 26.51µs, relative speed= 1.10
**** done ****
total test time= 26.6648
The machine is the same as in http://www.igorexchange.com/node/1489#comment-4988.
