Summation of columns of a multi-dimensional wave
I would like to use the WaveStats command because I am interested in the 18 sums of the ResidsSquared wave. That is, the sums for i=0 up to i=17. Does anybody know a solution to my problem? Any suggestions are highly welcome.
Eduard
Function Local(Cumulative, Length) // Function to cacluate detrended fluctuation Wave Cumulative // Read series of integrated share price returns Variable Length // Number of points in share price series // The fluctuation is determined for eighteen different scales. The scales relate to an // integrated series of share price returns with 4,380 observations // The wave NumbSegments shows the number of segments in which the series with 4,380 observations // can be divided. The total series can be subdivided in 480non-overlapping segments with a length //(scale) of 8, 240 non-overlapping segments with a length of 16, etc. Make/O/N=18 Scale= {8,16,12,32,40,48,64,80,96,120,128,160,192,240,256,320,384,480} Make/O/N=18 NumbSegments = {480,240,160,120,96,80,60,48,40,32,30,24,20,16,15,12,10,8} Make/O/N=18 SumSquaredResids // Create a wave with 18 points to store the sum of each of the // squared residual series Variable i ,j // Create local variables i and j for (i=0; i<18; i +=1) // Repeat commands 18 times from i=1 to i=18 Variable segmlength = Scale[i] // Segment length varies from 8 when i=0 to 480, when i=17 Variable nsegments = NumbSegments[i] // Number of segments varies from 480 when i=0 and // segment length is 8 to 8 when i=17 and segment length = 480 Make/O/N=(Length-1) Xwave = mod(p, segmlength) +1 // Create Xwave series; X runs from // 1 up to the final point in a scale, // for a scale / segment length of 8, the // X wave runs from 1 up to 8 for (j=0; j<nsegments; j += 1) // Repeat CurveFit function for each of the segments // when i=0 CurveFit is repeated 480 times in accordance with // the number of segments; when i=17, Curve Fit is repeated // 8 times, for each of the segments (scales) with a length of // 480 observations // Determine local trend per segment (scale) as well as residuals against local trend. Square the // residuals // Create new wave ResidsSquaredd. Store squared residuals to this series. // Next determine sum of each of the ResidsSquared eighteen times (for i=1 to i=17) and store // the sums to the wave SumSquaredResids CurveFit/Q Line Cumulative[j*segmlength, (j+1)*segmlength -1] /X=Xwave /D /R /A=0 Wave Res_Cumulative Make/O/N=(Length-1) ResidsSquared ResidsSquared[j*segmlength, (j+1)*segmlength -1] = Res_Cumulative^2 WaveStats/Q ResidsSquared SumSquaredResids[i] = V_Sum endfor endfor End
take a look at the documentation for the /R flag for WaveStats, I think it will do what you want.
In general I would use a 2D wave to hold data for multiple runs of the same experiments, rather than concatenating them in a single 1D wave. Your way works, of course, but I find 2D data easier conceptually and more importantly it no longer requires that you know or pass around the length of each segment (it simply becomes the number of rows or columns in the 2D wave).
WaveStats will treat your 2D (or higher) waves as 1D waves, which means that with such data you will typically want to use a loop and pass WaveStats single rows or columns at a time. For such cases you can take a look at the ImageTransform getCol or getRow functionality, or MatrixOP's col() or row() functions.
August 6, 2012 at 02:34 am - Permalink
You're hardcoding the knowledge that the wave that is fitted is called 'Cumulative', and that the residual will therefore be called 'Res_Cumulative'. However, if you were to pass in a wave called 'whatever' then the residual would be called 'Res_Whatever', and the wave statement would fail. I would recommend passing '/R=Res_Cumulative' (or whatever name) instead of simply '/R' to the CurveFit operation, so that the residual wave will always be called 'Res_Cumulative'. This makes your code more robust.
This won't work properly due to the way in which Igor does wave assignments. In the above statement, Igor will try to fill e.g. ResidsSquared[j*segmlength] with Res_Cumulative[j*segmlength]^2. This point won't exist for any but the starting iteration, and therefore you'll either get a constant value (the last point in Res_Cumulative) or a runtime error. Instead you should change this to:
This stuff is easy to overlook while programming, so I tend to always use the magic variables 'p, q, r, t' explicitly when writing wave assignments.
August 6, 2012 at 03:10 am - Permalink
I do, however, have a further question related to the use of matrices. The above function performs calculations progressing from the oldest to the most recent observation of the Cumulative wave. I have written a similar function for which the same calculations are done in the opposite direction: from the most recent observation of the Cumulative wave down to the oldest observation. I wish to sum the outcomes of these two - forward and backward - functions, but I run into problems in trying to do so. In fact I try to change two 2D waves ('FWSummedSqValues' and 'BWSummedSqValues') with one row and 18 columns to two 1D waves with one column and 18 rows so that I can combine them in a calculation with the wave 'NumbSegments', a 1D wave with one column and 18 rows. Any help is highly welcome. Below are the attempts from my side.
August 7, 2012 at 01:24 am - Permalink
August 7, 2012 at 05:40 am - Permalink
Hope the above gives any idea of what might be the problem. Thanks in advance on any suggestion to solve this problem.
Eduard
August 7, 2012 at 06:28 am - Permalink
Based on ForwardFluct being (18,1) in dimension, I think the indexing is to be as below
If I might also suggest a brief modification to your other function as follows:
August 7, 2012 at 07:21 am - Permalink
ForwardFluct is (18,1) or (18,0) in Igor-speak, but, I think, FWSummedSqValues and BWSummedSqValues are (1,18), thus
ForwardFluct = FWSummedSqValues[0][p] //reference 0th row, cols based on pUnless I'm being brain dead... always possible.
About the wave reference failure, are you certain that you are passing a valid reference and that the wave exists at run time? I tried to duplicate the problem and only generated an error about attempting to operate on a null or missing wave, not an invalid wave reference.***
Hope this helps.
***Note: If wave checking is turned on in the debugger, the wave reference failed error will be given.
August 7, 2012 at 09:02 am - Permalink
Oops. I meant to say, the starting function shows
Make/O/N=(18,1) FWSummedSqValuesSo it seems to me, the indexing has to be
ForwardFluct = FWSummedSqValues[p][0]Unless I have also missed something obvious too.
August 7, 2012 at 08:35 am - Permalink
You are correct. The code states...
I was paying attention to the description...
August 7, 2012 at 08:52 am - Permalink
In the second lines I attempted to define 'FWSummedSqValues' and 'BWSummedSqValues' as waves with 18 rows and 1 column. However, the waves that appeared are of a 1 row and 18 columns nature.
Eduard
August 7, 2012 at 12:59 pm - Permalink
From the Help ...
So, perhaps you want sumRows rather than sumCols. I have to admit though that someone with a better understanding of MatrixOp could probably help you better than me.
August 7, 2012 at 01:48 pm - Permalink
However, to my surprise there remained a problem in the next function when I tried to add the outcomes of two functions - FWSummedSqValues and BWSummedSqValues - in a third function, which I simplified along the following lines:
Debugger continues to show: WAVE error: "WAVE reference to "FWSummedSqValues" failed." However both waves do have vales. This time at the line Make/N=18 SumSqValues = FWSummedSqValues+BWSummedSqValues.
Other information that might be relevant: In the Debugger the Stack FluctMagn is selected and six local and global variables are shown. Four of these - BWSummedSqValues, Fluctuation, FWSummedSqValues and SumSqValues - are shown with a null denotation.
Hope this gives an idea of what might cause the problem.
August 8, 2012 at 01:21 am - Permalink
It sounds like the reference you pass to FluctMagn is not valid, given both the error message and the fact that the debugger shows them as null. Do you change directories in your code? If you get the wave reference using
Wave wave1 = wave2this will fail if the wave doesn't exist in the current directory. You could try
Wave wave1 = pathtowave:wave2That is give the full path to the wave you want to reference.
You could also try setting a break point somewhere before the call to FluctMagn and step through your code line by line. Often this helps make clear the source of problems. Look to see if your wave references are valid before the call is made.
August 8, 2012 at 06:04 am - Permalink
August 8, 2012 at 07:46 am - Permalink
Apart form the problem with the FWSummedSqValues and BWSummedSqValues waves the residuals of the two CurveFits in the LocalForward and LocalBackward behave in a strange way. Although the Y-values of the Curve Fits (Cumulative and New Cumulative, respectively) are different, the FWSummedSqValues and BWSummedSqValues waves are identical. (This should not be the case, as NewCumulative is Cumulative in reverse order.)
Instead of the R/ flags in the CurveFits I earlier used the R/Res_Cumulative and R_Res_NewCumulative denotations. However, when I use these denotations, Debugger shows an error at the first curve fit.
Hope that you can discover what went wrong in the procedure.
August 8, 2012 at 12:56 pm - Permalink
This seems to run without errors now, though obviously I can't tell whether the results are meaningful or not.
August 9, 2012 at 12:43 am - Permalink
A quick look at the changes you made learns me that I missed on some required initialisations, while the loops were placed at the wrong place.
Eduard
August 9, 2012 at 01:52 am - Permalink
Of course, now we all want to know how we can apply your procedures to enhance our own stock option holdings. :-)
August 9, 2012 at 08:02 am - Permalink
