Bug?...Or Change in Igor Operation
This example from IGOR manual no longer seems to work:
Function DisplayXY(xWaveNameStr, yWaveNameStr)
	String xWaveNameStr, yWaveNameStr
	Display $yWaveNameStr vs $xWaveNameStr
I have two integer waves that I tried to graph with this function, but get a SyntaxError message that says "Expected text wave". Has something changed (I'm using Igor 6.31), or am I simply missing something?
Clayton
jjweimer
ctmckee wrote: This example from IGOR manual no longer seems to work: ...
Without actually testing, I wonder should this be the coding instead ...
        wave xwave = $xWaveNameStr
        wave ywave = $yWaveNameStr
	Display ywave vs xwave
Alternatively, are you certain that you are inside the folder containing the two waves (and not for example at root:).
proland
Also, since the function is expecting strings, make sure that's what you are sending.
DisplayXY(wave1, wave0)          //waves
DisplayXY("wave1", "wave0")    //names of waves as strings
hrodstein
This works for me in Igor Pro 6.31:
#pragma rtGlobals=3		// Use modern global access method and strict wave access.
Function Test()
	Make/O/I xwave=p, ywave=sin(p/8)
	DisplayXY("xwave", "ywave")
Possibly the error message is not coming from where you think it is. Try stepping through it with the Igor Debugger.
If you can't determine the problem post a complete example or attach an experiment file that illustrates the problem.
ctmckee
Thanks for all the comments. Solution was not putting " " around string entry when running the function from the command window.
C
