"Attempt to use a null string variable" for two different types of multidata
I have old igor procedure to load a group of multi olddata. now the newdata has been added an extra column named "Ionpump". I like to revised the igor procedure to load both group of multi old data and new data.
The idea I planned to do is to load a single file first and check whether there is the column named "Ionpump". If the wave"Ionpump" exists, start to load the multi newdata, if not, start to load multi old data. The new igor procedures works fine for loading both groups of old data and new data, but a "Function Execution Error" with "Attempt to use a null string varible" came out at the end.
Please see the part of igor in attached file.
old igor procedure:
Function Loadmultidata()
String fileName
String fileNameBase
String S_fileName = "" // This is set by LoadWave.
String S_path
String title
Variable fileNum
LoadWave/Q/K=0/J/W/L={0,1,0,0,0}/A/B="C=11;C=1,F=-2;C=1,F=-2;" // Load data from file, wavenames taken from first row
New Igor procedure:
Function Loadmultidata_ion()
String fileName
String fileNameBase
String S_fileName= "" // This is set by LoadWave.
String S_path
String title
Variable fileNum
//line
LoadWave/K=0/J/W/L={0,1,0,0,0}/A=wave // Load data from file, wavenames taken from first row
print S_filename
if (strlen(S_fileName) == 0)
return -1 // User cancelled
if (WaveExists(Ion_Pump_Pressure__Torr_)) // to check to see if there is a ion pump pressure
duplicate Ion_Pump_Pressure__Torr_, Ionpump // duplicate the the wave Ion_Pump_Pressure__Torr_ to ionpump
killwaves Ion_Pump_Pressure__Torr_
killwaves Reading
killwaves DateW
killwaves Current_1__A_
killwaves Current_2__A_
killwaves Pressure_CC__Torr_
killwaves Pressure_CG__Torr_
killwaves Voltage_1__V_
killwaves Voltage_2__V_
killwaves Resistance_1__Ohms_
killwaves Resistance_2__Ohms_
killwaves Temperature__F_
killwaves Temperature_TC__C_
killwaves Annotation_1
GetFileFolderInfo/Q/Z/P=filePath fileName // check if file exists
if(WaveExists(Ionpump)) // to check if there is ion pump pressure wave data
LoadWave/Q/P=filePath/K=0/J/W/L={0,1,0,0,0}/A/B="C=13;C=1,F=-2;C=1,F=-2;" fileName // load the data with ion pump pressure
LoadWave/Q/P=filePath/K=0/J/W/L={0,1,0,0,0}/A/B="C=11;C=1,F=-2;C=1,F=-2;" fileName //load the data without ion pump pressure
Use the debugger enable, the execution paused at line "if(waveexist(ionpump))" and said "attempt to use a null string vavariable". Since this line doesn't involve any
string variable, it confused me. It would be appreciated if anyone could give some suggestions. Thanks.
Bruce
The debugger often stops one line after the real problem. In this case the real problem is that the string variable fileName is uninitialized. Note that fileName is not the same as S_fileName which is automatically created and set by LoadWave.
BTW, I formatted the Igor code in your original post. See http://www.igorexchange.com/node/3221 for details.
April 5, 2013 at 02:47 pm - Permalink
Thanks very for your help. Can you please show me how to initialize the string variable filename in my case?
Best
Bruce
April 8, 2013 at 09:36 am - Permalink
I can't tell from your code what you want fileName to contain. Here are some possiblities:
In the latter case you would have to set fileName AFTER S_fileName is created, i.e., after LoadWave executes.d
April 8, 2013 at 11:05 am - Permalink
Instead, first define them as a local wave reference with the following code:
In this manner you can define multiple local wave references (wave1, wave2, wave3, etc.) for all of those that were imported, and act on them instead of the direct names of each wave. This allows for far easier and more universal programming as well.
Even in my example the wave1 reference is statically defined; however, you can embed it as a variable in the following way:
In this function, you can then pass a string of the wave name to load, such as the following:
...and it will load the data and process the named wave, which you can specify as another name if you have multiple data sets of different names to use.
April 8, 2013 at 02:43 pm - Permalink
