Code to take input from Keyboard
Hello Again,
I want to write a code that will execute when a key is pressed by the user (for example arrow keys). I have already written the code to be executed but just can't make it to work only when the key is pressed.
I am guessing
 Prompt
is the one to use but I'm not sure.
Help me out please.
Thanks.
Prompt - DoPrompt creates a window for the user to provide values (variables or strings).
If you want code that responds to a key press (like the down arrow), you will need to write a hook function.
A window hook can, in fact, respond to key presses. But it requires a window and will only receive key presses when the window has keyboard focus.
You can also use GetKeyState(), but you have to poll for the input.
Execute this for a window hook function example:
DisplayHelpTopic "Window Hook Functions"
For a detailed example of a keyboard hook function, look in procedure file for the Scroll Traces package for the code segment that starts with ...
// hook function that handles keyboard events in non-movie mode
Function ScrollTracesKeyboardHook(sh)
	STRUCT WMWinHookStruct &sh
The relevant code segment is attached as a txt file.
keyboardhook.txt (2.33 KB)
