How to correctly do a curve fitting
I am trying to do an exponential fit for a x and y dataset (see attached Figure, upper one). I used the exp (or exp_XOffset) function under "Analysis"--"Curve fitting" and got something weird (se attached Figure, lower one). Did I use the wrong function or? Or is there a way to simply draw a line (y=0.4 exp(0.05x)) manually?
Thanks!!
johnweeks
You are trying to fit a growing exponential (an exponential with negative decay constant). The auto-guessing routines can't handle that, you need to select Manual Guesses on the Coefficients tab of the Curve Fit dialog and enter your own guesses in the Coefficients list.
shen2
Ok. I thought it was easier. Thank you! Still want to know, is there a way to simply draw a line (y=0.4 exp(0.05x)) manually on the figure?
shen2
jjweimer
shen2 wrote: ... Still want to know, is there a way to simply draw a line (y=0.4 exp(0.05x)) manually on the figure?
make/N=160 ewave
SetScale/I x, 0,16, "", ewave
appendtograph ewave
ewave = 0.4*exp(0.05*x)
hrodstein
Is there a way to simply draw a line (y=0.4 exp(0.05x)) manually?
Make/O/N=200 demo
SetScale x 0, 16, "", demo
demo=0.4 * exp(0.05*x)
Display demo
For details execute
DisplayHelpTopic "Function Plotting"
