How does overriding constant outside of main procedure file work?
I occasionally use constants in procedure files for setting certain values that I need to modify only every once in a while.
This way I can decrease the number of magic-numbers, global variables and arguments of my user functions, without losing an easy way to change certain numbers in my code, which is nice.
Recently, I have been writing a module that I will include in other procedure files and now I am trying to figure out how to use constants in them.
On one hand, I would like to write the module in such a way that, once it is complete, I don't have to modify it at all.
On the other hand, there are some numbers that I would like to change when I use it for different purposes.
To satisfy both, overriding the constant in the file which includes the module seems like a good idea, however this is not necessarily recommended in the igor pro manual.
The manual also does not give a detailed description of which non-main procedure can override the constants in which procedure.
It only says that it is decided by the order of compilation of procedure files, but doesn't say which non-main procedure becomes compiled first.
I actually tried simple tests to see how the override of constants work when I include a procedure from another non-main procedure, and under certain conditions it does work.
Is overriding a constant (or a strConstant or a function if anybody is interested) really a bad idea to do outside of the main procedure file?
And how does igor decide which procedure becomes compiled first?
jjweimer
Have you considered to use a STRUCTURE to store your constants? Call that structure to initialize the values.
STRUCTURE myconstants
	variable stp
	variable etp
	string sname
ENDSTRUCTURE
Function Initialize(myc)
	STRUCT myconstants &myc
	myc.stp = 0
	myc.etp = 8.314
	myc.sname = "Hello World!"
Function DoSomething()
	STRUCT  myconstants myc
	Initialize(myc)
	print myc.sname
You can even store the structure and recall it later. I use this in many of my independent modules with no problem.
thomas_braun
I would also consider overriding constants as bad practice. This can quickly lead to difficult to understand code.
One addition to jjweimer's approach would be to have in each procedure file a static function
InitializeStruct
which holds all settings/constants you might want to change. And then you can set the struct in each procedure file to your expected values.
Alternatively you can also have a look at optional function parameters
Constant paramDefault = 1 // explanation for the value
Function doStuff([param])
   variable param
   if(ParamIsDefault(param))
      param = paramDefault
// default usage of doStuff
doStuff()
// special use case
doStuff(param=2)
JellyGem
Hi jjweimer, thomas_braun,
Thank you for your comments.
Using structs sounds like a fantastic idea, I will definetily check this out.
Optional parameters is something that I use quite often and yes they are handy as well.
