Abort from function called by live updating SetVariable or Slider
First, in the function that creates the GUI, I have (for example):
SetVariable $("setvar0"+windownum) title="X-Index/Position",pos={115,10},size={135,20},value=xnumlocal,disable=2,win=$(windowname)#btm;
SetVariable $("setvar0"+windownum) limits={0,dimsize(matrixin,0)-1,1},proc=kviewsetvarproc_0,live=1
This calls the procedure:
Function kviewSetVarProc_0(ctrlName,varNum,varStr,varName) : SetVariableControl
String ctrlName
Variable varNum
String varStr
String varName
setdatafolder root:kview
SVAR windowname=windowname
windowname=winname(0,1)
SVAR windownum=windownum
windownum=windowname[12,strlen(windowname)]
NVAR roworcol=$("roworcol"+windownum)
kviewupdate(roworcol)
setdatafolder root:
Which calls (most of the function omitted):
Function kviewupdate(roworcol)
variable roworcol // 0 for column, 1 for row, 2 for stack
NVAR oldlocal=$("old"+windownum)
if(oldlocal==0)
setdatafolder root:
Abort "This Kview window will not work properly.\rPlease run the macro 'ConvertKviewWindows' to fix."
Any ideas how to get the Abort window to pop up only once and nicely abort this function?
The code that detects the obsolete windows could remove the action procedure from the control that's calling the action procedure. I tried it with a button instead:
This makes a button that only clicks once.
Another possibility (that's not really very good) is to create a global variable that flags the fact that you already put up the alert. You have to check it every time the action procedure runs.
November 18, 2013 at 04:56 pm - Permalink
As a general note, you might also try trapping the cycle by using the structure form of setvariable or slider control functions and checking for mouse up or mouse down sequences before doing things inside of the control function.
November 18, 2013 at 05:47 pm - Permalink
November 19, 2013 at 07:36 am - Permalink
Detecting the obsolete window before there is any chance to interact with the GUI is a good idea; however, I don't see how to do this. If I could get some code to execute upon compiling the procedure file, it would be easy... is there a way to do this?
Your second suggestion could be possible, but is not very efficient or practical for me, since there are many controls that would need to be updated.
The third suggestion I was able to implement with some success. Still, the behaviour is a little strange: the Abort window pops up only once now, but the SetVariable or Slider is still reacting as if I was holding down the mouse button (i.e. continues updating) until I close the Abort window and click once more. I'm guessing this is because the control reacts immediately when I press the button down, and the Abort statement is encountered before the button release occurs. Do you see any way around this?
November 24, 2013 at 08:16 am - Permalink
November 24, 2013 at 08:19 am - Permalink
November 24, 2013 at 08:22 am - Permalink
I don't think this is available with the old style calling method. Would it be difficult to wrap your existing function with a new function using the structure style calling method? The new function could extract the relevant parameters from the structure and pass them on to the old function. The old function wouldn't know it wasn't being called directly and the new function might be able to block the multiple calls.
Another thought would be to call your fixit function (ConvertKviewWindows) from your code instead of aborting and having the user call it. Don't know enough about your code to know if this is feasible.
Finally, your question to John about running code on compile... there may be an onCompile hook (I don't recall), but this would run anytime you compile any function (I think) as long as the code using the hook is loaded and may not be what you want. Could you do a check for a bad window in some kind of an initialization routine when your GUI is created?
November 24, 2013 at 09:57 am - Permalink
Igor does not have an onCompile hook. It would probably be difficult to implement without causing lots of issues; I don't really know.
One solution could be to have a window hook- handle the Activated event to check if the window is an old version. But since your original code didn't install a window hook (or did it?) it would require a time machine to install it...
You might try using Execute/P to actually put up the alert. That will cause it to be put up only when nothing else is happening. Create a function to put up the alert (using DoAlert instead of Abort). Call that function using Execute/P; have that function also create a global variable that flags the fact that the alert has already been displayed:
You can now put a line like this in your code:
Your code can now exit without interfering with anything; the alert will pop up shortly. The /Q flag prevents littering the history with the invocations of ObsoleteKViewVersionAlert().
The only feasible way I can think of to make your obsolete windows stop working would be to rename all your action procedures. That way, the old controls can't call their action procedures. You could provide new versions of the old action procedures that simply contain the Execute/P invocation. The new versions of the window will install the new-named action procedures. I don't know if that is more intrusive than you want.
November 25, 2013 at 02:11 pm - Permalink
Igor 6.20 *does* have an AfterCompiledHook. Using it is pretty hardcore, though.
November 25, 2013 at 05:49 pm - Permalink
jeez. It's the first one in the list of hooks (DisplayHelpTopic "User-Defined Hook Functions"). I looked at that list yesterday before writing that reply...
November 26, 2013 at 09:21 am - Permalink
November 27, 2013 at 08:49 am - Permalink
