Playing image stack as a movie?
I have an image stack of a microscopic time-lapse. To help determine regions showing intensity changes over time I would like to run through this stack. I have already created a means of clicking myself through plane-by-plane as well as a slider that allows me to scroll through the whole stack. What I really want is to be able to control the playback as if it was a movie without actually converting the stack to a QuickTime movie. And that is where I am hitting a wall.
At the moment I have a "Play" button, that simply starts a for-endfor loop advancing one frame at a time using:
ModifyImage/W=DataViewer tStack, plane=(vCurrentFrame)
If I want to "stop" the playback, I need to interrupt using 'Cmd-.'
The only alternative I can think of is to have "play" start a background task that is called every few ticks (depending on the intended frame rate) and have "stop" stop that task.
Am I missing a more obvious means of achieving this? The forum and mailing list archives don't seem to hold the answer.
Many thanks, Chris
I think I handled this in the Scroll Traces package through some tricks with hook functions to capture mouse events. I believe it only handles traces not existing movie stacks. Perhaps it may have something to help you determine how to do what you want.
http://www.igorexchange.com/project/ScrollTracesPanel
[quote]
[/quote]
Check the Igor User Manual, Chapter IV-6 "Interacting with the User" on p. IV-140. There is example code for a function PressEscapeToAbort( ) that monitors the keyboard for the Esc key, and takes whatever action you program, particularly stopping your function in a more controlled manner than the usual Abort button.
[quote=chris]If I want to "stop" the playback, I need to interrupt using 'Cmd-.'
The only alternative I can think of is to have "play" start a background task that is called every few ticks (depending on the intended frame rate) and have "stop" stop that task[/quote]
Yes, if you want a control panel with a Stop button to be active during playback, that would be a way to do it.
You might also consider a Progress Panel:
DisplayHelpTopic "Progress Windows"
That is an advanced technique and relatively new to Igor that requires some tricky code inside Igor...
Thanks for all the helpful replies. I will give hook functions another look and see how this is solved in ScrollTraces. I am currently already using a hook function to scroll through the stacks using the arrow keys. Almost what I want, but not quite.
[quote=johnweeks]
[/quote]
I have a control panel containing the slider and buttons for stepping through the stack plane by plane so I will just be adding the buttons there.
It appears that I will finally get to use background tasks in Igor :)
