Negative sign for positive value x scale
In the photoelectron spectroscopy studies, we always measure spectra in energy vs intensity. So, the loaded x-scale is by default positive number. But for presentation, we have to show as negative number. For the same, I have to put negative sign in front of the x-scale number. It is also possible to multiply with -1 to get the same, but for analysis process positive number is easy. I presently use drawing text tool to get "-" sign. This works good as long as I unchanged the size of the graph. When size is changed position of the text moves, I have even try to use coordinate system option like absolute, relative and plot relative.
So, I would like to know is there any option to give just "-" sign in-front of the x-scale value?
Something like "Units in Every tick Label", so that one can give "-" sign.
I thank you in advance for your help.
Regards,
Maniraj
[Edit: actually chozo's solution below is better --Jim]
July 15, 2014 at 12:26 pm - Permalink
Just curious. As far as I know, and certainly in the US, photoelectron spectroscopy is shown as intensity versus binding energy, where binding energy runs in reverse (highest to lowest). Some times I do run across graphs of photoelectron spectra plotted with binding energy running from low to high. This seems always to happen in European-related publications.
I have NEVER seen photoelectron spectra presented with an energy scale that has negative signs. So, can you cite a reference for me to see what you mean.
Also, in case you are interested, SetAxis/A/R will reverse the axis scaling from typical low to high to the reverse high to low.
July 15, 2014 at 07:10 pm - Permalink
July 15, 2014 at 07:40 pm - Permalink
chozo is the winner for best solution!
July 16, 2014 at 09:50 pm - Permalink
July 16, 2014 at 10:16 pm - Permalink
jjweimer: You are right, in all the publication which only contains photoemission data, binding energy scale is shown in positive number. Since, it is binding energy one suppose to scale from high to low (in the sense that the Fermi edge position is at your right hand side), but some publication show it in low to high. But, as far as I know, the core photoemission group always show high to low.
Since, I am working with photoemission, inverse photoemission and two photon photoemission spectroscopy, I have to show photoemission spectra in negative scale to make it clear that it is binding energy.
chozo: I thank you again for most simplest solution, which give full degree of freedom to change the scale at any time.
July 17, 2014 at 03:35 am - Permalink
