Advice on breaking bad programming habits
I would like advice on the how to improve my programming and use of user functions and procedures.    I put my hands up and admit that I have been using Igor Pro since version 4 and never done anything but build and build experiments, adding procedures within the experiment with more and more functions and macros.  Nowadays, (last 7 or so years) there has just been one major experiment that has grown like topsy.  I have never stored functions or procedures  in user folders and as a consequence I have many massive experiments.  I do occasionally prune defunct functions and start a new experiment series after a major code rewrite.  So, I would welcome advice on where/how  to start  following good practice in storing and including functions, procedures and macros outside the experiment.
jjweimer
As a starting point, consider moving the procedure file in a representative experiment to a stand-alone procedure.
  • Open an experiment with the most recent or most reliable procedure file.
  • Open the main procedure window.
  • Choose the menu option File->Save Procedure Copy.
  • Save the copy of the procedure in a folder in the User Procedures folder of the WaveMetrics folder. Title the folder with a respectable, short name to represent the theme of the entire procedure. For example, Analysis Tools or Curve Fitting Process or ... Title the procedure with a respectable, short name to represent it, for example also Main Analysis Procedure or equivalent.
  • Start a new Igor Pro experiment.
  • Open the main procedure window and put the #include "Main Analysis Procedure" statement in the beginning portion of the window.
  • Recompile the code.
You should now have the equivalent of access to the procedures without having to duplicate the experiment containing the main procedure.
The next step begins the process for development. At the top portion of the Main Analysis Procedure, include the pragma #version=1.00. Save the experiment that you just opened with a name equivalent to below.
-> Develop Main Analysis v1.00.pxp
You now have an experiment where you devote your efforts solely to developing and improving the procedures for analysis, not to muck about in the code while analyzing data. The work you do on the #include procedure in the Develop experiment transfers to all future experiments that have the #include "Main Analysis Procedure" pragma.
At this point, each time before you open the Develop experiment, decide what target you will resolve. Targets can include such things as ->add a feature, ->fix a bug, ->streamline a certain code segment, or ->remove clutter in something. Also, every time before you open the Develop ... experiment, create a ZIP archive of the main procedure file as a backup. When you reach a desired milestone in development or improvement, increment the version number in the procedure file and save the experiment with the incremented version number. Approaches vary on setting incremental version numbers. I typically increment by steps of 0.10 for bug fixes or new features, and I increment all other work by steps of 0.01.
To summarize, the important points to prevent being overwhelmed are a) extract the cores procedures to a separate procedure file that can be called by #include, b) develop a set of milestones that you attack one at a time, c) hold to a robust approach to capture snapshot backups of the main procedure file before you undertake any revisions on it, and d) maintain a systematic approach to versioning the main procedure file (and development experiment) to mark your success after reaching a milestone.
I hope my suggestions might help you get started on a more structured approach to your coding efforts.
Mike German
Thomas,
the problem for me is one of managing my programming developments which have become unwieldy: for example in 2024 with developments over 50 experiments totally over 13 GB.  Present version is 0.5GB with 20 procedures and hundreds of functions, some used and some defunct.  No control on function versions and modifcations ( only commented changes) .  I am the sole user.
Keeping tabs on updates to functions is probably the biggest issue.
pawel.wzietek
"...maintain a systematic approach to versioning the main procedure file (and development experiment) to mark your success after reaching a milestone."
Yes, as Jeffrey pointed out versioning is particularly important in this kind of projects.  I remember when I started developing in Igor one of my first projects dealed with processing data files issued by a custom acquisition program originally written by someone else.  As the experiment evolved new informations were added to the files and I was updating the processing routines accordingly. However initially there was no version info in the custom files so that at some point the latest version of my processing software was no longer compatible with older files which posed many problems. Since then when I develop my own aquisition programs  the file format/acquisition software versions are coded within the first lines (or bytes) of the file, my processing software starts reading those bytes and selects the appropriate version of the loader/processing routines.   Now I can semlessly load and process files stored 15 years ago, even when I don't remember which file format version was used at the time.
jjweimer
As a follow up, you might also want to consider whether you can improve on how you track your modifications. One method is to keep the records of changes in the procedure files themselves. For example, you could include a section near the start of a procedure file that keeps track of every modification that you make on it. Another method is to keep versioning records in a separate document system. Whichever approach you take, be systematic. Note the changes promptly when they are made, categorize the general type of change made (e.g. bug fix, code improvement, UI improvement, new feature, code pruning, ...) in addition to putting at least a brief note about the specific change(s), and date stamp the change record.
jtigor
A very minor addition to the suggestions given so far is to take advantage of the Code Marker Comments tool in the built in code editor.   It can be accessed by the sort of map marker icon in the upper left of the editor just to the right of the back and forward arrows..
This can be used to jump around to significant locations in your code.  I use it to mark the end of my header comments and the locations of other things such as structure, menu, and constant definitions.
see:
DisplayHelpTopic "Code Marker Comments"
tony
I find that the best motivation for writing cleaner code is to share code with others.
My advice would be to break everything down into as-compact-as-possible procedure files and store these in User Procedures. This really echoes the advice of others, and the wording of your question suggests that that is where you are heading anyway. If, as the sole user, you work always on the same computer, I cannot see any drawback to doing things this way. If you currently move your self-contained pxp files between computers, you will need to think about how to keep the User Procedures folders synchronized, but it's not a very formidable task.
A system that I find helpful is to keep a 'default includes' procedure file in the Igor Procedures folder. This ensures that my personal selection of go-to packages is always loaded. I also use that file to add a handful of useful one-liner menu items that I like to have available, like this:
#pragma version=1.02
// Procedure files to load at startup.
// #include "file name" for user procedures,
// #include <file name> for WaveMetrics procedure files
// *** programming & procedure file maintenance ***
#include "UserProcLoader"
// and so on, a list of file loaders and other utility functions to be included
// *** menu definitions ***
menu "Misc", hideable
	"Prepare project release...", /Q, updater#PrepareProjectRelease()
	"Disable Threadsafe Support", Execute/P/Q "SetIgorOption poundDefine=THREADING_DISABLED"; Execute/P/Q "SetIgorOption DisableThreadsafe=1"
	"Enable Threadsafe Support",  Execute/P/Q "SetIgorOption poundUnDefine=THREADING_DISABLED"; Execute/P/Q "SetIgorOption DisableThreadsafe=0"
I strongly recommend sticking with the default User Procedures folder for storing all other procedures.
jcor
That's a good idea, thanks Tony.
...Alternatively, I just put a shortcut in User Procedures that points to my procedures. Those are saved in a separate, automatically backed up folder.
One other addition to the advice above: when coding for scientific work, it is often especially important to keep track of what version was used for what calculation / at what time. For this, I backup my code folder at major milestones, and also version-number with the calendar date to avoid confusion (e.g. this post is version 20251028).
kris
Just to piggyback on the excellent advice from everyone. Version control, version control, version control. And something that others haven't brought up is writing unit tests. If you write tests for each non-static function that can execute automatically and call the function without calling any other non-static function, it will force you to write cleaner code. The combo of version control and easy to run tests is the key to excellent process.
-Kris
Mike German
A bit late coming back to this but has anyone written a function to do the menu option File->Save Procedure Copy on all user procedures?
hrodstein
I'm not sure if, by "user procedures", you mean procedures in the "User Procedures" folder or any non-Igor procecure file.
Assuming the former, here is an approach:
// *** Note *** If your "User Procedure Files" folder contains aliases or shortcuts,
// this copies the aliases or shortcuts, not the original files
Function CopyUserProceduresFolder()
	String sourcePath = SpecialDirPath("Igor Pro User Files", 0, 0, 0)
	sourcePath += "User Procedures"
	String destPath = SpecialDirPath("Documents", 0, 0, 0)
	destPath += "Igor Pro User Files Copy"
	destPath += " " + Secs2Date(DateTime,-2)	// YYYY-MM-DD
	// Overwrites any pre-existing copy
	CopyFolder/O sourcePath as destPath
Mike German
 Didn't explain that too well.
From an open pxp experiment rather than using the File>Save Procedure Copy... key entry on all of my "user written" procedures, I was looking for a function that would take each of my procedures and save to a subfolder in the designated Igor Pro User files folder.
This function creates a list of all of my  procedures in (26 off) for a basis ....
Function ListUserProcedures()
	// MTG 18 July 2015 v2
	variable i,j, lenProcItem, match
	String FullProcList = WinList("*",";","WIN:128")	// list of all procedure windows
	string UserProcList =""								// List of user procedures
	Notebook UserFunctionMacroLists text = "#User Procedures\r"
	variable numItems = ItemsInList(FullProcList)
	string procItem
	// remove .ipf files from list
	for(i=0;i<numItems;i+=1)
		procItem = stringFromList(i, FullProcList)
		lenprocItem = strlen(procItem)
		match = cmpstr(procItem[lenProcItem-4], ".")
		if (match > 0)
			UserProcList +=ProcItem+"\r"
	Notebook UserFunctionMacroLists text = UserProcList+"\r\r"
jcor
@Mike
@Mike
Mike, why not just Adopt all the procedures (CTRL+SHIFT+File menu) into the file. Then you don't need to keep track of external files, and can be sure what version was used.
Alternatively, if you are using #include for your files, then you can automatically/manually backup the included folder periodically.
tony
That doesn't look like a very robust way to identify user procedures.
Do you want to make copies of all procedure files in the current experiment that are not wavemetrics procedures and not the procedure window (this could include files stored anywhere other than Igor Procedures), or perhaps all open procedure files that are stored in User Procedures folder? Do you need to retain folder structure?
I would check file path against Igor Procedures (for first option), or else against User Procedures, to refine the list.
get file paths using GetWindow/Z $strWin file
identify files of interest, probably using SpecialDirPath("Igor Pro User Files",0,0,0)
Use NewPath if you want user to select a destination folder, then use CopyFile for each procedure in the refined list.
You might want to check for unsaved changes, using GetWindow $strWin needupdate
If you want to back up User Procedures folder, that's probably most easily done outside of Igor.
If you're interested in synchronising folders from within Igor, there's a code snippet here. It's not designed for copying files into subfolders, though.
hrodstein
This comment from your "ListUserProcedures" function:
makes me think that you want to save a copy of only packed procedure files (stored in the experiment file). By excluding procedure windows whose titles include ".", you are excluding WaveMetrics procedure files (e.g., "HDF5 Utilities.ipf") and also your own standalone procedure files.
Is my understanding of your intent correct?
Mike German
The reason for wanting the 26 procedures into one folder on disk is that, because of my bad habits I have 3 experiments which are nominally identical other than mods to different procedures.  If I had just these procedures containing code saved to separate folders on a PC I can use WinMerge to compare and identify differences.
As this is a one off (hopefully) I guess I bite the bullet and do it manually.  I was just interested in how it could be done.
Thanks for all advice
tony
Attached is a procedure for comparing different ipfs, written by James Allan in the pre-git era. Perhaps this is useful for identifying differences.
Compare ipfs.ipf (10.28 KB)
In reply to by tony
Mike German
Yes that would be helpful when I have extracted to windows folders all of the 26 procedures from  3 or 4 experiments.
I've just come across DoIgorMenu which "allows an Igor programmer to invoke Igor's built-in menu items. This is useful for bringing up Igor's built-in dialogs under program control"  (I found it in Help file: "C:Program Files:WaveMetrics:Igor Pro 10 Folder:Igor Help Files:Igor Reference.ihf" (Topic: DoIgorMenu)
 I tried  DolgorMenu "File", "Save procedure Copy"  from the command line but this doesn't work.  The hope would be to use this in a macro to save all procedures to a named folder.
Ben Murphy-Baum
In place of trying to use 'Save Procedure Copy' programmatically, you can hack your way around this with the sometimes-very-handy ProcedureText() function, which extracts the text of the procedure file, and then you can just write that text to a new file:
function saveProcedure(String procedureName, String savePath)
	String text = ProcedureText("", 0, procedureName)
	Variable ref
	Open ref as savePath  // savePath is: "path/to/new/proc.ipf"
	FBinWrite ref, text
	Close ref
tony
Ben, would this not strip out the byte order mark from the 'duplicated' procedure file?
In reply to by Ben Murphy-Baum
Mike German
Tony, I don't understand what was meant by "byte order mark"   Does this mean files copied like this are not legitimate .ipf file or something is missing?
Ben,  I cobbled something together around your function and the ListUserProcedures() i gave previously.  This nicely generated a windows folder of files with extension .ipf for the several of the experiments of interest.  I compared them using a Windows app, WInMerge, and the James Alan "Compare ipf routine" that Tony suggested.  The saved files also opened when #included in an experiment.
Very useful advice chaps - I'm now starting to get my house in order.
In reply to by Mike German
tony
Unlikely to have any effect for you, but the files will not necessarily be bit-perfect copies (BOM is first 2 or 3 bytes of file where it is present). As I understand it, the output file will always be UTF-8 because that's what Igor uses internally, and it shouldn't cause problems. I don't know what happens in the edge case where you have opened a legacy file with, say, Japanese JIS encoding and saved in UTF-8. Probably both files can be read by Igor, but the new file is not a true duplicate.
For anyone who wants to inspect the binary content of a file, I attach a binary reader procedure. I can't remember who wrote this, but I've found it very useful over the years.
BinaryReader.ipf (14.77 KB)
Ben Murphy-Baum
Tony, you're right about the BOM getting stripped out, and yes the output file will be UTF-8 and get read back by Igor that way -- this is definitely a quick and dirty solution for UTF-8 based files. I think if you save a different text encoding as UTF-8, basically you'll get all the ASCII characters read back by Igor normally, but if there are non-ascii characters, those will be misinterpreted.
In reply to by tony
Mike German
It is interesting that the procedures created with Windows>New>procedure in an experiment are displayed in the Procedures Browser without a file extension.  It is not until saving a copy form the File menu or  the function with  ProcedureText form and then fetching back with #include, that the extension is shown. It was a useful way of identify user and Igor procedures.
tony
I see now that your main concern is unsaved procedures, ones that exist only in the experiment and haven't been saved to a file. That's a blind spot for me because I always work with procedure files. hrodstein noted this above and Ben's solution seems ideal.
In reply to by tony
Mike German
... and now I see that I have always done something different to the norm!
I now have (a version) of the development regime based on advice from this topic.
It will have been noticed I am not a professional programmer.  I code for personal research conducted at home.  I am the only one using the experiments and there is essentially one experiment that is used. Data are downloaded locally from my various systems and from the internet, processed, analysed and collated. The downloads can be lengthy.  I had kept separate experiments for each month of download with the on-going development and bug-fixing in the experiment being worked on at the time. That meant when reviewing past data it was necessary to copy and paste from later experiments for comparison etc.
Now, with one common base experiment with all functions, panels, macros, menus etc are in ipf procedure files included as advised, all changes are applied across the board.  Monthly experiments are still saved with separate experiment names.
At times I have a number of instances from various months open at the same time.  Are there any pitfalls in doing this, in particular if editing the code in one of the instances?
