Thermocouples: temperature to emf (or vice verca)
#pragma rtGlobals=1		// Use modern global access method.
//The function emf2T converts a thermocouple electromotive force (emf, in milli volts  to temperature (in Celsius) or vice verca;
//currently for B, S and C-Type thermocouples. All coefficients taken from ASTM E-230.
//syntax:		        emf2T(TC_string, temp, emf)
//Parameters:     	TC_string	is a string indicating the thermocouple type, here B, S or C
//				tmp			is temperature in Celsius
//				emf			is the emf in mV
//							The value that needs to be calculated must be entered as NaN
//To convert a temperature into an emf value use e.g. 	print 	emf2T("B", 1400, nan)
//To convert emf to temperature use e.g.			print 	emf2T("B", nan, 8.956)
function emf2T(type, Tmp, emf)
	string type
	variable Tmp, emf
	variable c0, c1,c2,c3,c4,c5,c6,c7,c8, c9
	c1 = 0		//if not assigned later make sure they are all zero
	c2 = 0
	c3 = 0
	c4 = 0
	c5 = 0
	c6 = 0
	c7 = 0
	c8 = 0
	c9 = 0
	// ***********************       B- Type thermocouples Pt6%Rh / Pt30%Rh          *************************
	strswitch(type)
		case "B":
		if (numtype(Tmp) == 0 && numtype(emf) == 2)		// this is a temperature to EMF conversion
			if (tmp >= 0 && tmp <= 630.615)
				c0 = 0.000000000000E+00
				c1 =-0.246508183460E-03
				c2 = 0.590404211710E-05
				c3 =-0.132579316360E-08
				c4 = 0.156682919010E-11
				c5 =-0.169445292400E-14
				c6 = 0.629903470940E-18
				c7 = 0
				c8 = 0
				return c0*tmp^0 + c1*tmp^1 +c2*tmp^2 +c3*tmp^3 +c4*tmp^4 +c5*tmp^5 +c6*tmp^6  +c7*tmp^7  +c8*tmp^8
			if (tmp > 630.615 && tmp <= 1820)
				c0 = -0.389381686210E+01
				c1 = 0.285717474700E-01
				c2 =-0.848851047850E-04
				c3 = 0.157852801640E-06
				c4 =-0.168353448640E-09
				c5 = 0.111097940130E-12
				c6 =-0.445154310330E-16
				c7 = 0.989756408210E-20
				c8 =-0.937913302890E-24
		if (numtype(Tmp) == 2 && numtype(emf) == 0)		// this is a EMF to temperature conversion
			if (emf >= 0.291 && emf <= 2.431)
				c0 = 	 9.8423321E+01
     			  	c1 =   6.9971500E+02
			   	c2 =     -8.4765304E+02
				c3 =        1.0052644E+03
				c4 =       -8.3345952E+02
				c5 =       4.5508542E+02
				c6 =      -1.5523037E+02
				c7 =        2.9886750E+01
				c8 =       -2.4742860E+00
				return  c0 + c1*emf^1 +c2*emf^2 +c3*emf^3 +c4*emf^4 +c5*emf^5 +c6*emf^6  +c7*emf^7  +c8*emf^8
			if (emf > 2.431 && emf <= 13.82)
				c0 = 	2.1315071E+02
   				c1 =    2.8510504E+02
    				c2 =    -5.2742887E+01
  				c3 =     9.9160804E+00
   				c4 =     -1.2965303E+00
  				c5 =      1.1195870E-01
   				c6 =     -6.0625199E-03
   				c7 =       1.8661696E-04
  				c8 =    -2.4878585E-06
		break
		// ***********************       S- Type thermocouples Pt / Pt10%Rh          ******************************
		case "S":
			if (tmp >= -50  && tmp <= 1064.18)
				c1 =0.540313308631E-02
				c2 = 0.125934289740E-04
				c3 =-0.232477968689E-07
				c4 = 0.322028823036E-10
				c5 =-0.331465196389E-13
				c6 = 0.255744251786E-16
				c7 =-0.125068871393E-19
				c8 = 0.271443176145E-23
			if (tmp > 1064.18 && tmp <= 1664.5)
				c0 = 0.132900444085E+01
				c1 =  0.334509311344E-02
				c2 =  0.654805192818E-05
				c3 = -0.164856259209E-08
				c4 =  0.129989605174E-13
			if (tmp > 1664.5  && tmp <= 1768.1)
				c0 = 	0.146628232636E+03
				c1 = -0.258430516752E+00
				c2 =  0.163693574641E-03
				c3 = -0.330439046987E-07
				c4 = -0.943223690612E-14
			if (emf >= -0.235 && emf <= 1.874)
				c0	=	0
				c1	=	1.84949460E+02
				c2	=	-8.00504062E+01
				c3	=	1.02237430E+02
				c4	=	-1.52248592E+02
				c5	=	1.88821343E+02
				c6	=	-1.59085941E+02
				c7	=	8.23027880E+01
				c8	=	-2.34181944E+01
				c9	=	2.79786260E+00
				return  c0 + c1*emf^1 +c2*emf^2 +c3*emf^3 +c4*emf^4 +c5*emf^5 +c6*emf^6  +c7*emf^7  +c8*emf^8 +c9*emf^9
			if (emf > 1.874 && emf <=11.950)
				c0	=	1.291507177E+01
				c1	=	1.466298863E+02
				c2	=	-1.534713402E+01
				c3	=	3.145945973
				c4	=	-4.163257839E-01
				c5	=	3.187963771E-02
				c6	=	-1.291637500E-03
				c7	=	2.183475087E-05
				c8	=	-1.447379511E-07
				c9	=	8.211272125E-09
			if (emf > 11.950 && emf <= 17.536)
				c0	=	-8.087801117E+01
				c1	=	1.621573104E+02
				c2	=	-8.536869453E+00
				c3	=	4.719686976E-01
				c4	=	-1.441693666E-02
				c5	=	2.081618890E-04
			if (emf > 17.536 && emf <= 18.693)
				c0	=	5.333875126E+04
				c1	=	-1.235892298E+04
				c2	=	1.092657613E+03
				c3	=	-4.265693686E+01
				c4	=	6.247205420E-01
		break
		// ***********************    C- Type thermocouples W5%Re / W26%Re     *****************************
		case "C":
				c0 = 0.0000000
				c1 = 1.34060323e-2
				c2 = 1.19249923e-5
				c3 = -7.98063543e-9
				c4 = -5.07875153e-12
				c5 = 1.31641973e-14
				c6 = -7.91973323e-18
			if (tmp > 630.615 && tmp <= 2315)
				c0 =  4.05288233e-1
				c1 =  1.15093553e-2
				c2 =  1.56964533e-5
				c3 =  -1.37044123e-8
				c4 =  5.22908733e-12
				c5 =  -9.20827583e-16
				c6 = 4.52451123e-20
			c0 = 0.0
			c1 = 7.4124732e1
			c2 = -4.28082813
			c3 = 5.21138920e-1
			c4 = -4.57487201e-2
			c5 = 2.80578284e-3
			c6 = -1.13145137e-4
			c7 = 2.85489684e-6
			c8 = -4.07643828e-8
			c9 = 2.51358071e-10
		break
		default:
			break
	endswitch
	return NaN   // if non of the other if-statements are entered, return NaN
johnweeks
That's terrific! A lot of effort typing in all those constants!
I would comment that the straightforward method of evaluating a polynomial has potential problems caused by floating-point truncation errors. A better way to do it is outlined in Numerical Recipes. This method is followed by the Igor poly() function, so I would recommend poly(). To use it, you need to create a wave with the coefficients, something like this fragment that implements just one part of your function:
 				Make/D/FREE cw = {4.05288233e-1,  1.15093553e-2,   1.56964533e-5, -1.37044123e-8, 5.22908733e-12, -9.20827583e-16, 4.52451123e-20}
				return poly(cw, tmp)
tony
There's a GUI for thermocouple emf calculations here: https://www.wavemetrics.com/node/21411
It does S, B, R, K, T, E, J, N, C, and D types, and includes cold junction compensation. It should convert between emf and temperature in either direction, depending on which setvariable you adjust.
tony
Himmelkreuzdonnerwetter! I've just noticed the identity of the original poster - Hi Christian! I guess there aren't so many people out there using types C and D :) I wonder, was it I who introduced you to the delights of Igor back in Hannover in the late 90s, or did you pick it up somewhere further on down the line?
Tanay
Heyy. Anyone know how to apply the cold junction compensation for the thermocouple. Thanks
