WaveStats/PCST and column dimension labels in M_WaveStats
I really like the new IP7 PCST flag on Wavestats! Thanks for this!
Is there any chance for an additional feature that also copies the column dimension labels from the source wave to M_WaveStats, maybe a /DL flag?
Igor
This has been implemented for IP8.
If you like using dimension labels check out the new CopyDimLabels operation.
ChrLie
Igor wrote: This has been implemented for IP8.
Awesome!!
I DO like DimLabels a lot and it seems that my CloneDimLabels snippet (http://www.igorexchange.com/node/7731) can be retired.
Thanks a lot!
Christian
hegedus
I did a quick look at the help browser/command help and do not see a CopyDimLabels operation. I have IP 7.06 installed. Is the operation something for IP8?
Igor
Yes, it is new in Igor 8.
In reply to by Igor
ChrLie
Hello A.G.
Transferring the column DimLabels from SourceWave to M_WaveStats, is that a feature that is maybe not documented? It would still be nice to have, maybe for IP9.
Also related to DimLabels: The reverse of Concatenate/DL, i.e. SplitWave/DL could be useful as well.
Best
Christian
