WaveStats/PCST and column dimension labels in M_WaveStats
ChrLie
Thu, 10/19/2017 - 09:26 am
I really like the new IP7 PCST flag on Wavestats! Thanks for this!
Is there any chance for an additional feature that also copies the column dimension labels from the source wave to M_WaveStats, maybe a /DL flag?
October 19, 2017 at 10:37 am - Permalink
If you like using dimension labels check out the new CopyDimLabels operation.
October 25, 2017 at 02:56 pm - Permalink
Awesome!!
I DO like DimLabels a lot and it seems that my CloneDimLabels snippet (http://www.igorexchange.com/node/7731) can be retired.
Thanks a lot!
Christian
October 25, 2017 at 11:04 pm - Permalink
I did a quick look at the help browser/command help and do not see a CopyDimLabels operation. I have IP 7.06 installed. Is the operation something for IP8?
October 26, 2017 at 06:27 am - Permalink
Yes, it is new in Igor 8.
October 27, 2017 at 08:06 am - Permalink
In reply to by Igor
Hello A.G.
Transferring the column DimLabels from SourceWave to M_WaveStats, is that a feature that is maybe not documented? It would still be nice to have, maybe for IP9.
Also related to DimLabels: The reverse of Concatenate/DL, i.e. SplitWave/DL could be useful as well.
Best
Christian
May 8, 2020 at 12:53 pm - Permalink
OK, I will look into it.
May 8, 2020 at 02:51 pm - Permalink
This is already implemented with /CCL (for copy column lables).
May 8, 2020 at 02:57 pm - Permalink
Great, thanks!
May 9, 2020 at 10:14 am - Permalink
