HDF5 Browser error on upgrade to Igor Pro 7
#if (HDF5LibraryInfo(0) <= 010805) // If you get an error here, you need HDF5 XOP 1.15 or later
I have double checked the instructions on how to load the HDF5 XOP and browser and have set up everything accordingly (shortcut of HDF5 XOP to Igor 64-bit extensions folder and shortcut of browser to Igor procedures folder). The browser version that I am working with is v1.21.
I've tried everything that I can think of and still no luck.
What am I missing?
March 8, 2018 at 12:54 pm - Permalink
You need to create a shortcut of "HDF5-64.xop" and put it in the Igor 64-bit extensions folder. Then restart Igor64.
In Igor64, choose Help->Show Igor Pro User Files to verify that your Igor Pro User Files folder is where you think it is.
March 8, 2018 at 12:55 pm - Permalink
I missed loading the 64-bit HDF5 browser into the 64-bit extensions folder.
Moved the shortcut and now back up and running.
March 12, 2018 at 09:48 am - Permalink
