HDF5 Browser error on upgrade to Igor Pro 7
I recently upgraded to version 7 (current version is 7.0.8.1, build 31118, 64-but version) and am running into problems compiling the HDF5 browser at line 41 which reads:
#if (HDF5LibraryInfo(0) <= 010805) // If you get an error here, you need HDF5 XOP 1.15 or later
I have double checked the instructions on how to load the HDF5 XOP and browser and have set up everything accordingly (shortcut of HDF5 XOP to Igor 64-bit extensions folder and shortcut of browser to Igor procedures folder). The browser version that I am working with is v1.21.
I've tried everything that I can think of and still no luck.
What am I missing?
Do you have more than one entry for each HDF5 operation in the help menu? If yes, you have multiple HDF5 XOPs installed and Igor is picking the wrong one.
[quote]shortcut of HDF5 XOP to Igor 64-bit extensions folder[/quote]
You need to create a shortcut of "HDF5-64.xop" and put it in the Igor 64-bit extensions folder. Then restart Igor64.
In Igor64, choose Help->Show Igor Pro User Files to verify that your Igor Pro User Files folder is where you think it is.
Thank you both for replying!
I missed loading the 64-bit HDF5 browser into the 64-bit extensions folder.
Moved the shortcut and now back up and running.
