how to extract code after manually editing graphs
HI,
Save the recreation macro. Control-Y to bring up the dialog. All the code used to create the graph as currently displayed is now in the procedure window.
One side note: The image shows the graph in tools mode. If you save recreation marco it will also save the tools mode open. When I build GUI I have remember to turn off tool mode before saving.
September 15, 2018 at 07:15 am - Permalink
In reply to HI, Save the recreation… by hegedus
BlackwidowThank you for the response.
I don't think I am doing this right though.
As can be seen in the image attached, I do get a block of code I can add to my ipf but when I run it again, it doesnt produce a plot and subplots in the same settings.
September 15, 2018 at 07:28 am - Permalink
BlackwidowAlso, I thought it was generally not good practice to use macro. I thought it would be better to hard code it in my user defined function..
September 15, 2018 at 07:37 am - Permalink
First, you only need the Graph Macro. You do not need the Graph Style.
Secondly, yes ... the recreation code is a macro. You can change it to a function call with no real problems. One way is to change the entry and exit points, for example from `Window Graph..` to `Function myGraph()` with `end` rather than `EndMacro`. The other way is to copy + paste segments of the window recreation code in to your own function as appropriate to what parts you need your function to do.
September 15, 2018 at 07:45 am - Permalink
