Replace Waves In Table
//	ShowWavesInTable(tableName, title, waveNames)
//	Used to display a list of waves in a table which may or may not already exist.
//	The listed waves replace any waves already displayed in the table.
//	If the table does not already exist, it is created.
//	If the table does already exist, replaces the currently displayed waves in the table with the listed waves.
static Function ShowWavesInTable(tableName, title, waveNames)
	String tableName
	String title
	String waveNames			// Semicolon-separated list
	Variable numNewWaves = ItemsInList(waveNames)
	Variable i
	String name
	DoWindow $tableName
	if (V_flag == 0)
		Edit /N=$tableName /W=(25,60,1200,700) /K=3 as title
		for(i=0; i<numNewWaves; i+=1)
			name = StringFromList(i, waveNames)
			AppendToTable /W=$tableName $name
			Wave w = $name
			if (CmpStr(WaveUnits(w,-1),"dat")==0 && WaveType(w)==4)		// Is data wave?
				ModifyTable /W=$tableName format($name)=6				// Date format
		ModifyTable /W=$tableName autosize={1, 0, -1, 0, 0}
		String options = "WIN:" + tableName
		String tableWaveList = WaveList("*", ";", options)			// List of waves already in table
		if (CmpStr(tableWaveList,waveNames) != 0)				// Do nothing if table already contains the right waves in the right order
			Variable numOldWaves = ItemsInList(tableWaveList)
			for(i=0; i<numOldWaves; i+=1)					// Remove all old waves
				name = StringFromList(i, tableWaveList)
				Wave w = $name
				RemoveFromTable /W=$tableName w.i, w.l, w.d
			for(i=0; i<numNewWaves; i+=1)						// Append all new waves
				Wave w = $name
RGerkin
If you want to use this code as a "ReplaceWave allincdf" for tables, you will need to do something like provide full paths in your wave name list, or otherwise distinguish the list of your waves from the list of waves already in the table, because the
line will prevent anything from happening if the exisiting wave list and the new wave list match.
hrodstein
That's the intention so that, if you have displayed a wave in the table and the same wave is in the waveNames list, it will be left as is in the table to preserve any formatting changes that were made to the column.
waveNames is assumed to contain simple names of waves in the current data folder. I have not tested it with full paths and would not expect it to work with full paths.
hegedus
How would you modify this to handle subframe tables?
I have a panel hosting a table and I would like to include a popup menu where the user selects a wave for editing.
