Replace loop over image stack calculations?
jjweimer
Fri, 04/03/2020 - 06:29 pm
What is the best way to do the calculations below without a for loop?
// assume these two waves exist already
make/N=(100,100,200) imgwave= // ... (filled with some image data)
make/N=(200)/D ifrac
// how do I handle this part without a for loop?
variable ic
for (ic = 0;ic<200;ic+=1)
WaveStats/Q/M=1 imgwave[][][ic]
ifrac[ic] = V_sum/(V_npnts*V_max)
variable ic
For reference, I am computing the fraction of white level in a threshold image going through each plane in a stack.
How about this:
make/O/N=(100,100,200) ImageWave=gnoise(1)
make/O/N=(200)/D ifrac
Variable t=StartMSTimer
Redimension/N=(100*100*200) ImageWave
Redimension/N=(100*100,200) ImageWave
MultiThread ifrac[]=DoStuffFunction(ImageWave, p)
Print(StopMSTimer(t)/1000)
Threadsafe Function DoStuffFunction(ImageWave, col)
Wave ImageWave
Variable col
Duplicate/O/FREE/R=[][col] ImageWave, SingleColWave
Return Mean(SingleColWave)/WaveMax(SingleColWave)
April 4, 2020 at 01:31 am - Permalink
I guess I could have done it without the redimension, but I initially tried to make it work with MatrixOP, and for that the redimension was convenient.
April 4, 2020 at 01:36 am - Permalink
just as example to use MatrixOP without Redimension:
make/O/N=(100,100,200) imgwave= p+r
make/O/D/N=(200) iFrac
Multithread iFrac = WorkerFunc(imgwave,p)
Threadsafe function WorkerFunc(w, n)
wave w
variable n
MatrixOP/FREE val = mean(layer(w,n)) / maxVal(layer(w,n))
return val[0]
April 4, 2020 at 03:23 am - Permalink
Neat. Thanks!!!
April 4, 2020 at 05:40 am - Permalink
