VaspUtilities
Yuan Fang
Tue, 11/03/2020 - 05:05 am
#pragma TextEncoding = "UTF-8"
#pragma rtGlobals=3 // Use modern global access method and strict wave access.
function vaspbands(path1,fname1,path2,fname2,fermilevel)
string path1,fname1,path2,fname2
variable fermilevel //fermilevel
variable a,i,t,j,k
string str,fword,nkpts,nbnds
Open/R a path1 + ":" + fname1
for(i=0;i<5;i++)
FReadLine a, str
FReadLine a, str
i=0
t=0
do
fword=stringfromlist(i,str," ")
if (stringmatch(fword,"")!=1)
t=t+1
if(t==2)
nkpts=fword
if(t==3)
nbnds=fword
i=i+1
while(t<3)
make/d/n=(str2num(nkpts),str2num(nbnds)) w
for(i=0;i<str2num(nkpts);i++)
FReadLine a, str
FReadLine a, str
for(j=0;j<str2num(nbnds);j++)
FReadLine a, str
k=0
t=0
do
fword=stringfromlist(k,str," ")
t=t+1
if(t==2)
w[i][j]=str2num(fword)
k=k+1
while(t<2)
for(i=0;i<str2num(nbnds);i++)
make/d/n=(str2num(nkpts)) tmp
tmp=w[p][i]-fermilevel
duplicate tmp $"wave"+num2str(i)
killwaves tmp
killwaves w
close a
Open/R a path2 + ":" + fname2
make/d/n=3 kold,knew
make/d/n=(str2num(nkpts)) kpt
do
FReadLine a, str
if(strlen(str)==0)
break
if(stringmatch(str,"*k-points in units of 2pi/SCALE*")==1)
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==1)
kold[0]=str2num(fword)
elseif(t==2)
kold[1]=str2num(fword)
elseif(t==3)
kold[2]=str2num(fword)
i=i+1
while(t<3)
kpt[0]=0
for(i=1;i<str2num(nkpts);i++)
FReadLine a, str
k=0
t=0
do
t=t+1
if(t==1)
knew[0]=str2num(fword)
elseif(t==2)
knew[1]=str2num(fword)
elseif(t==3)
knew[2]=str2num(fword)
k=k+1
while(t<3)
if(mod(i,100)==0)
kpt[i]=kpt[i-1]
kpt[i]=kpt[i-1]+sqrt((knew[0]-kold[0])^2+(knew[1]-kold[1])^2+(knew[2]-kold[2])^2)
kold=knew
while(1)
killwaves kold,knew
close a
if(i==0)
display $"wave"+num2str(i) vs kpt
appendtograph $"wave"+num2str(i) vs kpt
function vaspbands_mbj(path1,fname1,path2,fname2,fermilevel)
variable a,i,t,j,k
variable cc=120
for(i=0;i<5;i++)
FReadLine a, str
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==2)
nkpts=fword
if(t==3)
nbnds=fword
i=i+1
while(t<3)
FReadLine a, str
FReadLine a, str
FReadLine a, str
k=0
t=0
do
t=t+1
if(t==2)
k=k+1
while(t<2)
killwaves tmp
killwaves w
close a
do
FReadLine a, str
if(strlen(str)==0)
break
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==1)
elseif(t==2)
elseif(t==3)
i=i+1
while(t<3)
kpt[0]=0
FReadLine a, str
k=0
t=0
do
t=t+1
if(t==1)
elseif(t==2)
elseif(t==3)
k=k+1
while(t<3)
if(mod(i,100)==0)
kpt[i]=kpt[i-1]
kold=knew
while(1)
killwaves kold,knew
close a
DeletePoints 0,cc, $"wave"+num2str(i)
DeletePoints 0,cc,kpt
if(i==0)
function splitdos(path1,fname1,path2,fname2) //fname1=DOSCAR,fname2=POSCAR
variable a,b,i,t,j,k
string str,fword,natms,nspin
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==1)
natms=fword
if(t==3)
nspin=fword
i=i+1
while(t<3)
for(i=0;i<4;i++)
FReadLine a, str
printf "Number of atoms: %d\r Number of spin: %d\r" str2num(natms),str2num(nspin)
Open/R b path2 + ":" + fname2
for(i=0;i<5;i++)
FReadLine b, str
FReadLine b, str
i=0
variable/g nspec=0
do
nspec=nspec+1
i=i+1
while(i<strlen(str))
make/t/n=(nspec)/o atmnam
i=0
t=0
do
t=t+1
if(t==nspec)
variable memory=strlen(fword)
string lastnm
sscanf fword[0,memory-1],"%s",lastnm
atmnam[t-1]=lastnm
atmnam[t-1]=cleanupname(fword,0)
i=i+1
while(t<nspec)
make/d/n=(nspec)/o atmnum
FReadLine b, str
i=0
t=0
do
t=t+1
atmnum[t-1]=str2num(fword)
i=i+1
while(t<nspec)
close b
printf "Number of species: %d\r" nspec
variable temp=0
for(i=0;i<nspec;i++)
temp+=atmnum[i]
if(str2num(natms)!=temp)
printf "DOSCAR info & POSCAR does not match!\r"
close a
return -1
FReadLine a, str
i=0
t=0
do
fword=stringfromlist(i,str," ",32)
t=t+1
if(t==1)
variable/g nedos=str2num(fword)
if(t==2)
variable/g efermi=str2num(fword)
i=i+1
while(t<2)
for(i=0;i<nedos;i++)
FReadLine a, str
if(i==0)
j=0
variable tl=0
do
fword=stringfromlist(j,str," ")
tl=tl+1
j=j+1
while(j<strlen(str))
make/o/n=(nedos,tl)/d pdos_tot
j=0
t=0
do
t=t+1
pdos_tot[i][t-1]=str2num(fword)
j=j+1
while(t<tl)
for(j=0;j<atmnum[i];j++)
FReadLine a, str
for(k=0;k<nedos;k++)
FReadLine a, str
if(k==0)
variable in=0
tl=0
do
fword=stringfromlist(in,str," ")
tl=tl+1
in=in+1
while(in<strlen(str))
make/o/n=(nedos,tl)/d tempwave
in=0
t=0
do
t=t+1
tempwave[k][t-1]=str2num(fword)
in=in+1
while(t<tl)
duplicate/o tempwave, $"pdos_"+atmnam[i]+"_"+num2str(j+1)
killwaves tempwave
function splitdosif(path1,fname1,path2,fname2)
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==1)
natms=fword
if(t==3)
nspin=fword
i=i+1
while(t<3)
for(i=0;i<4;i++)
FReadLine a, str
for(i=0;i<5;i++)
FReadLine b, str
FReadLine b, str
i=0
variable/g nspec=0
do
nspec=nspec+1
i=i+1
i=0
t=0
do
t=t+1
if(t==nspec)
string lastnm
atmnam[t-1]=lastnm
i=i+1
while(t<nspec)
FReadLine b, str
i=0
t=0
do
t=t+1
i=i+1
while(t<nspec)
close b
variable temp=0
temp+=atmnum[i]
close a
return -1
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==1)
if(t==2)
i=i+1
while(t<2)
FReadLine a, str
if(i==0)
j=0
variable tl=0
do
tl=tl+1
j=j+1
j=0
t=0
do
t=t+1
j=j+1
while(t<tl)
FReadLine a, str
for(k=0;k<(2*nedos);k++)
FReadLine a, str
if(k==0)
variable in=0
tl=0
do
tl=tl+1
in=in+1
if(k==1)
in=0
variable tll=0
do
tll=tll+1
in=in+1
redimension/n=(nedos,(tl+tll))/d tempwave
in=0
t=0
if(mod(k,2)==0)
do
t=t+1
tempwave[(k/2)][t-1]=str2num(fword)
in=in+1
while(t<tl)
do
t=t+1
tempwave[floor(k/2)][tl+t-1]=str2num(fword)
in=in+1
while(t<tll)
killwaves tempwave
function sumdos()
variable i,j
variable/g nspec,nedos
wave atmnum
wave/t atmnam
if(j==0)
duplicate/o $"pdos_"+atmnam[i]+"_"+num2str(j+1),tempwave
duplicate/o/r=[][0] $"pdos_"+atmnam[i]+"_"+num2str(j+1),energywave
duplicate/o $"pdos_"+atmnam[i]+"_"+num2str(j+1),tempwave2
tempwave+=tempwave2
killwaves tempwave2
variable k
tempwave[k][0]=energywave[k]
duplicate/o tempwave $"pdos_"+atmnam[i]+"_tot"
killwaves tempwave,energywave
function plotdosif()
variable i
variable/g nspec
wave/t atmnam
variable j
for(j=0;j<65;j++)
if(j==1)
duplicate/o/r=[][j] $"pdos_"+atmnam[i]+"_tot" $"pdos_"+atmnam[i]+"_tot_s"
if(j==5)
duplicate/o/r=[][j] $"pdos_"+atmnam[i]+"_tot" temp_p
if(j==9)
duplicate/o/r=[][j] $"pdos_"+atmnam[i]+"_tot" temp_p_t
temp_p+=temp_p_t
if(j==13)
temp_p+=temp_p_t
duplicate/o temp_p,$"pdos_"+atmnam[i]+"_tot_p"
killwaves temp_p_t,temp_p
if(j==17)
duplicate/o/r=[][j] $"pdos_"+atmnam[i]+"_tot" temp_d
if(j==21)
duplicate/o/r=[][j] $"pdos_"+atmnam[i]+"_tot" temp_d_t
temp_d+=temp_d_t
if(j==25)
temp_d+=temp_d_t
if(j==29)
temp_d+=temp_d_t
if(j==33)
temp_d+=temp_d_t
duplicate/o temp_d,$"pdos_"+atmnam[i]+"_tot_d"
killwaves temp_d_t,temp_d
if(j==37)
duplicate/o/r=[][j] $"pdos_"+atmnam[i]+"_tot" temp_f
if(j==41)
duplicate/o/r=[][j] $"pdos_"+atmnam[i]+"_tot" temp_f_t
temp_f+=temp_f_t
if(j==45)
temp_f+=temp_f_t
if(j==49)
temp_f+=temp_f_t
if(j==53)
temp_f+=temp_f_t
if(j==57)
temp_f+=temp_f_t
if(j==61)
temp_f+=temp_f_t
duplicate/o temp_f,$"pdos_"+atmnam[i]+"_tot_f"
killwaves temp_f_t,temp_f
if(i==0)
display $"pdos_"+atmnam[i]+"_tot_s" vs $"pdos_"+atmnam[i]+"_tot"[][0]
appendtograph $"pdos_"+atmnam[i]+"_tot_s" vs $"pdos_"+atmnam[i]+"_tot"[][0]
appendtograph $"pdos_"+atmnam[i]+"_tot_p" vs $"pdos_"+atmnam[i]+"_tot"[][0]
appendtograph $"pdos_"+atmnam[i]+"_tot_d" vs $"pdos_"+atmnam[i]+"_tot"[][0]
appendtograph $"pdos_"+atmnam[i]+"_tot_f" vs $"pdos_"+atmnam[i]+"_tot"[][0]
function plotdoslf()
variable i
variable/g nspec
wave/t atmnam
variable j
for(j=0;j<65;j++)
if(j==1)
if(j==5)
if(j==9)
temp_p+=temp_p_t
if(j==13)
temp_p+=temp_p_t
if(j==17)
if(j==21)
temp_d+=temp_d_t
if(j==25)
temp_d+=temp_d_t
if(j==29)
temp_d+=temp_d_t
if(j==33)
temp_d+=temp_d_t
if(i==0)
function Findbands(numbnds,efermi)
variable numbnds,efermi
variable i
make/o/n=(numbnds) mini,maxm
for(i=0;i<numbnds;i++)
loadwave/a/o/d/g/L={0,21+1030302*i,1030301,0,0} "C:\Users\Lenovo\Desktop\wannier90.bxsf"
wavestats $"wave"+num2str(i)
mini[i]=V_min
maxm[i]=V_max
killwaves $"wave"+num2str(i)
if((efermi>mini[i])&&(efermi<maxm[i]))
print i+1
function extract_fs(path1,fname1,path2,fname2,nstart,nend) //fname1 read;fname2 write
variable nstart,nend
string str,temp,fword
variable nx,ny,nz
Open b path2 + ":" + fname2
for(i=0;i<14;i++)
FReadLine a, str
temp=str[0,strlen(str)-2]
fprintf b,temp
fprintf b,"\n"
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==1)
temp=fword[0,strlen(fword)-2]
i=i+1
while(t<1)
if((nend<nstart)||(str2num(temp)<nend))
fprintf b,"Wrong indices,exit...\n"
close a
close b
return -1
fprintf b,"%15d\n",nend-nstart+1
FReadLine a, str
fprintf b,temp
fprintf b,"\n"
i=0
t=0
do
t=t+1
if(t==1)
temp=fword[0,strlen(fword)-1]
nx=str2num(temp)
if(t==2)
ny=str2num(temp)
if(t==3)
nz=str2num(temp)
i=i+1
while(t<3)
for(i=0;i<4;i++)
FReadLine a, str
fprintf b,temp
fprintf b,"\n"
for(i=1;i<nstart;i++)
for(j=0;j<(nx*ny*nz+1);j++)
FReadLine a, str
for(i=0;i<(nend-nstart+1);i++)
FReadLine a, str
fprintf b,"BAND:%12d\n",i+1
for(j=0;j<(nx*ny*nz);j++)
FReadLine a, str
fprintf b,temp
fprintf b,"\n"
fprintf b," END_BANDGRID_3D\n"
fprintf b," END_BLOCK_BANDGRID_3D\n"
close a
close b
function vaspbands_proj(path1,fname1,atoms,orbitals) //read procar non-soc
wave atoms
wave orbitals
string path1,fname1
variable a,i,t,j,k,u
variable s
variable inner,np,ccc
string str,fword,nkpts,nbnds,nions
FReadLine a, str
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==4)
nkpts=fword
if(t==8)
nbnds=fword
if(t==12)
nions=fword
i=i+1
while(t<12)
make/o/d/n=(str2num(nkpts),str2num(nbnds)) tem
for(u=0;u<str2num(nkpts);u++)
for(i=0;i<3;i++)
FReadLine a, str
for(k=0;k<str2num(nbnds);k++)
for(i=0;i<3;i++)
FReadLine a, str
s=0
for(np=0;np<numpnts(atoms);np++)
if(np==0)
if(atoms[0]==1)
FReadLine a, str
j=0
t=0
do
t=t+1
for(ccc=0;ccc<numpnts(orbitals);ccc++)
if(t==orbitals[ccc])
s+=str2num(fword)
j=j+1
while(t<orbitals[numpnts(orbitals)-1])
if(atoms[0]>1)
for(inner=0;inner<(atoms[0]-1);inner++)
FReadLine a, str
FReadLine a, str
j=0
t=0
do
t=t+1
s+=str2num(fword)
j=j+1
if((atoms[np]-atoms[np-1])==1)
FReadLine a, str
j=0
t=0
do
t=t+1
s+=str2num(fword)
j=j+1
if((atoms[np]-atoms[np-1])>1)
for(inner=0;inner<(atoms[np]-atoms[np-1]-1);inner++)
FReadLine a, str
FReadLine a, str
j=0
t=0
do
t=t+1
s+=str2num(fword)
j=j+1
if(str2num(nions)==atoms[numpnts(atoms)-1])
FReadLine a, str
FReadLine a, str
for(i=0;i<(str2num(nions)-atoms[numpnts(atoms)-1]);i++)
FReadLine a, str
FReadLine a, str
FReadLine a, str
tem[u][k]=s
duplicate/o/r=[0,str2num(nkpts)-1][i,i] tem $"weight"+num2str(i)
close a
function vaspbands_projsoc(path1,fname1,atoms,orbitals) //read procar soc
wave atoms
wave orbitals
string path1,fname1
variable s
FReadLine a, str
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==4)
nkpts=fword
if(t==8)
nbnds=fword
if(t==12)
nions=fword
i=i+1
while(t<12)
for(i=0;i<3;i++)
FReadLine a, str
for(i=0;i<3;i++)
FReadLine a, str
s=0
if(np==0)
if(atoms[0]==1)
FReadLine a, str
j=0
t=0
do
t=t+1
s+=str2num(fword)
j=j+1
if(atoms[0]>1)
FReadLine a, str
FReadLine a, str
j=0
t=0
do
t=t+1
s+=str2num(fword)
j=j+1
FReadLine a, str
j=0
t=0
do
t=t+1
s+=str2num(fword)
j=j+1
FReadLine a, str
FReadLine a, str
j=0
t=0
do
t=t+1
s+=str2num(fword)
j=j+1
variable jjj
for(jjj=0;jjj<(3*(str2num(nions)+1+1));jjj++)
FReadLine a, str
FReadLine a, str
FReadLine a, str
FReadLine a, str
FReadLine a, str
FReadLine a, str
FReadLine a, str
FReadLine a, str
tem[u][k]=s
close a
function projbulkbnds(m,n,p) //projected bulk bands plot.m:the number of points between two kpoints;
//n:number of different kzs;p:numberof bands.
variable m,n,p
variable i,j,k
wave kpt
make/n=(2*m) refer
for(i=0;i<(2*m);i++)
refer[i]=kpt[i]
make/n=(2*m) tem1
for(i=0;i<p;i++)
duplicate $"wave"+num2str(i),tem2
for(j=i;j<i+p*(n-1)+1;j=j+p)
for(k=0;k<(2*m);k++)
tem1[k]=tem2[k]
duplicate tem1,$"w"+num2str(j)
if(j==0)
display $"w"+num2str(j) vs refer
appendtograph $"w"+num2str(j) vs refer
DeletePoints 0,3*m, tem2
killwaves tem2
killwaves tem1
function difkzplot(nbnds,nkz,ymin,ymax,j)
variable nbnds
variable nkz
variable ymin,ymax //display range
variable j //j can take value 0-20,corresponding to kz=j/(nkz-1)*(gamma-z)
variable kz=j/(nkz-1)
wave xwave
variable i
for(i=0;i<nbnds;i++)
if(i==0)
display $"w"+num2str(j*nbnds) vs xwave
TextBox/C/N=text0/F=0/A=MC num2str(kz)+"*G-Z"
SetAxis left ymin,ymax
appendtograph $"w"+num2str(j*nbnds+i) vs xwave
function fcc111() //for writing fcc 111 KPOINTS
variable a,b,c
a= 5.429
make/o/d/n=3 a1={0,a/2,a/2}
make/o/d/n=3 a2={a/2,0,a/2}
make/o/d/n=3 a3={a/2,a/2,0}
cross a2,a3
variable vprim
wave W_Cross
vprim=matrixDot(a1,W_Cross)
make/o/d/n=3 b1,b2,b3
b1=2*pi*W_Cross/vprim
cross a3,a1
b2=2*pi*W_Cross/vprim
cross a1,a2
b3=2*pi*W_Cross/vprim
Concatenate/O {b1,b2,b3},primbasis
make/o/d/n=3 aa1={-a/2,a/2,0}
make/o/d/n=3 aa2={0,-a/2,a/2}
make/o/d/n=3 aa3={a,a,a}
cross aa2,aa3
variable vconv
vconv=matrixDot(aa1,W_Cross)
make/o/d/n=3 bb1,bb2,bb3
bb1=2*pi*W_Cross/vconv
cross aa3,aa1
bb2=2*pi*W_Cross/vconv
bb3=1/2*(b1+b2+b3)
Concatenate/O {bb1,bb2,bb3},convbasis
matrixinverse primbasis
wave M_inverse
matrixop/o matC=M_inverse x convbasis
print vprim
print vprim/vconv
cross b2,b3
variable kvprim
kvprim=matrixDot(b1,W_Cross)
cross bb2,bb3
variable kvconv
kvconv=matrixDot(bb1,W_Cross)
print kvprim/kvconv
function simplecubic111() //for writing simple cubic 111 KPOINTS
variable a,b,c
a= 2.3537117117709037*2
make/o/d/n=3 a1={a,0,0}
make/o/d/n=3 a2={0,a,0}
make/o/d/n=3 a3={0,0,a}
cross a2,a3
variable vprim
wave W_Cross
cross a3,a1
cross a1,a2
make/o/d/n=3 aa1={a,-a,0}
make/o/d/n=3 aa2={0,a,-a}
cross aa2,aa3
variable vconv
cross aa3,aa1
bb3=1/2*(b1+b2+b3)
wave M_inverse
print vprim/vconv
cross b2,b3
variable kvprim
cross bb2,bb3
variable kvconv
print kvprim/kvconv
function hr111() //for writing hr 111 KPOINTS
variable a,c
a= 3.6281/sqrt(3)
c=26.233/3
make/o/d/n=3 a1={-a/2,sqrt(3)/2*a,c}
make/o/d/n=3 a2={-a/2,-sqrt(3)/2*a,c}
make/o/d/n=3 a3={a,0,c}
cross a2,a3
variable vprim
wave W_Cross
cross a3,a1
cross a1,a2
make/o/d/n=3 aa1=a2-a3
make/o/d/n=3 aa2=a3-a1
make/o/d/n=3 aa3=a1+a2+a3
cross aa2,aa3
variable vconv
wave W_cross
cross aa3,aa1
bb3=1/2*(b1+b2+b3)
wave M_inverse
print vprim
print vprim/vconv
cross b2,b3
variable kvprim
cross bb2,bb3
variable kvconv
print kvprim/kvconv
function changecoord() //for KPOINTS coordinate transformation
variable x,y,z
variable m,n,l
wave matC
variable i
variable k=0
for(i=0;i<21;i++)
x=1/2;y=0;z=i/20 // M bar point
m=matC[0][0]*x+matC[0][1]*y+matC[0][2]*z
n=matC[1][0]*x+matC[1][1]*y+matC[1][2]*z
l=matC[2][0]*x+matC[2][1]*y+matC[2][2]*z
if(i==0)
printf "%.12f %.12f %.12f\r" m, n, l
x=0;y=0;z=i/20 //gamma bar point
x=1/3;y=1/3;z=i/20 //K bar point
if(i==20)
function fcc111slab(nlayer,a) //for writing fcc 111 slab POSCAR
variable nlayer,a
make/o/d matA={{-1/2,1/2,0},{0,-1/2,1/2},{1,1,1}}
matrixinverse matA
wave M_inverse
make/o/d matB={{0,1/2,1/2},{1/2,0,1/2},{1/2,1/2,0}}
matrixop/o matC=M_inverse x matB
make/o/d/n=(3,3) Cefilm
variable x,y,z,m,n,l,i
for(i=0;i<3;i++)
x=0;y=0;z=i
do
if(m<0)
m=m+1
elseif((m>1)||(m==1))
m=m-1
while((m<0)||(m>1)||(m==1))
do
if(n<0)
n=n+1
elseif((n>1)||(n==1))
n=n-1
while((n<0)||(n>1)||(n==1))
do
if(l<0)
l=l+1
elseif((l>1)||(l==1))
l=l-1
while((l<0)||(l>1)||(l==1))
Cefilm[i][0]=m ;Cefilm[i][1]=n ;Cefilm[i][2]=l
bubble(Cefilm,3)
redimension/n=(nlayer,3) Cefilm
for(i=3;i<nlayer;i++)
Cefilm[i][0]=Cefilm[i-3][0]
Cefilm[i][1]=Cefilm[i-3][1]
Cefilm[i][2]=Cefilm[i-3][2]+1
for(i=0;i<nlayer;i++)
printf "%.12f %.12f %.12f\r",Cefilm[i][0],Cefilm[i][1], (Cefilm[i][2]*a*sqrt(3)/((Cefilm[nlayer-1][2]-Cefilm[0][2])*a*sqrt(3)+18))
print "\r"
printf "%.12f\r" (Cefilm[nlayer-1][2]-Cefilm[0][2])*a*sqrt(3)+18
function bubble(w,n)
wave w
variable n
variable i,j,k,t1,t2,t3
for(i=1;i<n;i++)
k=0
for(j=0;j<(n-i);j++)
if(w[j][2]>w[j+1][2])
t1=w[j][0];w[j][0]=w[j+1][0];w[j+1][0]=t1
t2=w[j][1];w[j][1]=w[j+1][1];w[j+1][1]=t2
t3=w[j][2];w[j][2]=w[j+1][2];w[j+1][2]=t3
k++
if(k==(n-i))
break
function xcoordi()
wave b1,b2
make/o/d/n=200 xwave
variable i
for(i=0;i<100;i++)
xwave[i]=1/2*sqrt(b1[0]^2+b1[1]^2+b1[2]^2)/99*(i-99)
for(i=100;i<200;i++)
xwave[i]=1/3*sqrt((b1[0]+b2[0])^2+(b1[1]+b2[1])^2+(b1[2]+b2[2])^2)/99*(i-100)
variable a,i,t,j,k
for(i=0;i<5;i++)
FReadLine a, str
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==2)
nkpts=fword
if(t==3)
nbnds=fword
i=i+1
while(t<3)
FReadLine a, str
FReadLine a, str
FReadLine a, str
k=0
t=0
do
t=t+1
if(t==2)
k=k+1
while(t<2)
killwaves tmp
killwaves w
close a
do
FReadLine a, str
if(strlen(str)==0)
break
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==1)
elseif(t==2)
elseif(t==3)
i=i+1
while(t<3)
kpt[0]=0
FReadLine a, str
k=0
t=0
do
t=t+1
if(t==1)
elseif(t==2)
elseif(t==3)
k=k+1
while(t<3)
if(mod(i,100)==0)
kpt[i]=kpt[i-1]
kold=knew
while(1)
killwaves kold,knew
close a
if(i==0)
variable a,i,t,j,k
variable cc=120
for(i=0;i<5;i++)
FReadLine a, str
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==2)
nkpts=fword
if(t==3)
nbnds=fword
i=i+1
while(t<3)
FReadLine a, str
FReadLine a, str
FReadLine a, str
k=0
t=0
do
t=t+1
if(t==2)
k=k+1
while(t<2)
killwaves tmp
killwaves w
close a
do
FReadLine a, str
if(strlen(str)==0)
break
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==1)
elseif(t==2)
elseif(t==3)
i=i+1
while(t<3)
kpt[0]=0
FReadLine a, str
k=0
t=0
do
t=t+1
if(t==1)
elseif(t==2)
elseif(t==3)
k=k+1
while(t<3)
if(mod(i,100)==0)
kpt[i]=kpt[i-1]
kold=knew
while(1)
killwaves kold,knew
close a
if(i==0)
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==1)
natms=fword
if(t==3)
nspin=fword
i=i+1
while(t<3)
for(i=0;i<4;i++)
FReadLine a, str
for(i=0;i<5;i++)
FReadLine b, str
FReadLine b, str
i=0
variable/g nspec=0
do
nspec=nspec+1
i=i+1
i=0
t=0
do
t=t+1
if(t==nspec)
string lastnm
atmnam[t-1]=lastnm
i=i+1
while(t<nspec)
FReadLine b, str
i=0
t=0
do
t=t+1
i=i+1
while(t<nspec)
close b
variable temp=0
temp+=atmnum[i]
close a
return -1
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==1)
if(t==2)
i=i+1
while(t<2)
FReadLine a, str
if(i==0)
j=0
variable tl=0
do
tl=tl+1
j=j+1
j=0
t=0
do
t=t+1
j=j+1
while(t<tl)
FReadLine a, str
FReadLine a, str
if(k==0)
variable in=0
tl=0
do
tl=tl+1
in=in+1
in=0
t=0
do
t=t+1
in=in+1
while(t<tl)
killwaves tempwave
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==1)
natms=fword
if(t==3)
nspin=fword
i=i+1
while(t<3)
for(i=0;i<4;i++)
FReadLine a, str
for(i=0;i<5;i++)
FReadLine b, str
FReadLine b, str
i=0
variable/g nspec=0
do
nspec=nspec+1
i=i+1
i=0
t=0
do
t=t+1
if(t==nspec)
string lastnm
atmnam[t-1]=lastnm
i=i+1
while(t<nspec)
FReadLine b, str
i=0
t=0
do
t=t+1
i=i+1
while(t<nspec)
close b
variable temp=0
temp+=atmnum[i]
close a
return -1
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==1)
if(t==2)
i=i+1
while(t<2)
FReadLine a, str
if(i==0)
j=0
variable tl=0
do
tl=tl+1
j=j+1
j=0
t=0
do
t=t+1
j=j+1
while(t<tl)
FReadLine a, str
FReadLine a, str
if(k==0)
variable in=0
tl=0
do
tl=tl+1
in=in+1
if(k==1)
in=0
variable tll=0
do
tll=tll+1
in=in+1
in=0
t=0
if(mod(k,2)==0)
do
t=t+1
in=in+1
while(t<tl)
do
t=t+1
in=in+1
while(t<tll)
killwaves tempwave
function sumdos()
variable i,j
wave atmnum
wave/t atmnam
if(j==0)
tempwave+=tempwave2
killwaves tempwave2
variable k
variable i
variable/g nspec
wave/t atmnam
variable j
for(j=0;j<65;j++)
if(j==1)
if(j==5)
if(j==9)
temp_p+=temp_p_t
if(j==13)
temp_p+=temp_p_t
if(j==17)
if(j==21)
temp_d+=temp_d_t
if(j==25)
temp_d+=temp_d_t
if(j==29)
temp_d+=temp_d_t
if(j==33)
temp_d+=temp_d_t
if(j==37)
if(j==41)
temp_f+=temp_f_t
if(j==45)
temp_f+=temp_f_t
if(j==49)
temp_f+=temp_f_t
if(j==53)
temp_f+=temp_f_t
if(j==57)
temp_f+=temp_f_t
if(j==61)
temp_f+=temp_f_t
if(i==0)
variable i
variable/g nspec
wave/t atmnam
variable j
for(j=0;j<65;j++)
if(j==1)
if(j==5)
if(j==9)
temp_p+=temp_p_t
if(j==13)
temp_p+=temp_p_t
if(j==17)
if(j==21)
temp_d+=temp_d_t
if(j==25)
temp_d+=temp_d_t
if(j==29)
temp_d+=temp_d_t
if(j==33)
temp_d+=temp_d_t
if(i==0)
variable i
mini[i]=V_min
maxm[i]=V_max
print i+1
variable nx,ny,nz
for(i=0;i<14;i++)
FReadLine a, str
fprintf b,temp
fprintf b,"\n"
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==1)
i=i+1
while(t<1)
close a
close b
return -1
FReadLine a, str
fprintf b,temp
fprintf b,"\n"
i=0
t=0
do
t=t+1
if(t==1)
nx=str2num(temp)
if(t==2)
ny=str2num(temp)
if(t==3)
nz=str2num(temp)
i=i+1
while(t<3)
for(i=0;i<4;i++)
FReadLine a, str
fprintf b,temp
fprintf b,"\n"
FReadLine a, str
FReadLine a, str
FReadLine a, str
fprintf b,temp
fprintf b,"\n"
close a
close b
wave atoms
wave orbitals
string path1,fname1
variable s
FReadLine a, str
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==4)
nkpts=fword
if(t==8)
nbnds=fword
if(t==12)
nions=fword
i=i+1
while(t<12)
for(i=0;i<3;i++)
FReadLine a, str
for(i=0;i<3;i++)
FReadLine a, str
s=0
if(np==0)
if(atoms[0]==1)
FReadLine a, str
j=0
t=0
do
t=t+1
s+=str2num(fword)
j=j+1
if(atoms[0]>1)
FReadLine a, str
FReadLine a, str
j=0
t=0
do
t=t+1
s+=str2num(fword)
j=j+1
FReadLine a, str
j=0
t=0
do
t=t+1
s+=str2num(fword)
j=j+1
FReadLine a, str
FReadLine a, str
j=0
t=0
do
t=t+1
s+=str2num(fword)
j=j+1
FReadLine a, str
FReadLine a, str
FReadLine a, str
FReadLine a, str
FReadLine a, str
tem[u][k]=s
close a
wave atoms
wave orbitals
string path1,fname1
variable s
FReadLine a, str
FReadLine a, str
i=0
t=0
do
t=t+1
if(t==4)
nkpts=fword
if(t==8)
nbnds=fword
if(t==12)
nions=fword
i=i+1
while(t<12)
for(i=0;i<3;i++)
FReadLine a, str
for(i=0;i<3;i++)
FReadLine a, str
s=0
if(np==0)
if(atoms[0]==1)
FReadLine a, str
j=0
t=0
do
t=t+1
s+=str2num(fword)
j=j+1
if(atoms[0]>1)
FReadLine a, str
FReadLine a, str
j=0
t=0
do
t=t+1
s+=str2num(fword)
j=j+1
FReadLine a, str
j=0
t=0
do
t=t+1
s+=str2num(fword)
j=j+1
FReadLine a, str
FReadLine a, str
j=0
t=0
do
t=t+1
s+=str2num(fword)
j=j+1
variable jjj
FReadLine a, str
FReadLine a, str
FReadLine a, str
FReadLine a, str
FReadLine a, str
FReadLine a, str
FReadLine a, str
FReadLine a, str
tem[u][k]=s
close a
variable m,n,p
variable i,j,k
wave kpt
make/n=(2*m) refer
refer[i]=kpt[i]
make/n=(2*m) tem1
for(i=0;i<p;i++)
tem1[k]=tem2[k]
if(j==0)
killwaves tem2
killwaves tem1
variable nbnds
variable nkz
wave xwave
variable i
if(i==0)
variable a,b,c
a= 5.429
cross a2,a3
variable vprim
wave W_Cross
cross a3,a1
cross a1,a2
cross aa2,aa3
variable vconv
cross aa3,aa1
bb3=1/2*(b1+b2+b3)
wave M_inverse
print vprim
print vprim/vconv
cross b2,b3
variable kvprim
cross bb2,bb3
variable kvconv
print kvprim/kvconv
variable a,b,c
cross a2,a3
variable vprim
wave W_Cross
cross a3,a1
cross a1,a2
cross aa2,aa3
variable vconv
cross aa3,aa1
bb3=1/2*(b1+b2+b3)
wave M_inverse
print vprim/vconv
cross b2,b3
variable kvprim
cross bb2,bb3
variable kvconv
print kvprim/kvconv
variable a,c
a= 3.6281/sqrt(3)
c=26.233/3
cross a2,a3
variable vprim
wave W_Cross
cross a3,a1
cross a1,a2
cross aa2,aa3
variable vconv
wave W_cross
cross aa3,aa1
bb3=1/2*(b1+b2+b3)
wave M_inverse
print vprim
print vprim/vconv
cross b2,b3
variable kvprim
cross bb2,bb3
variable kvconv
print kvprim/kvconv
variable x,y,z
variable m,n,l
wave matC
variable i
variable k=0
for(i=0;i<21;i++)
if(i==0)
if(i==20)
variable nlayer,a
matrixinverse matA
wave M_inverse
for(i=0;i<3;i++)
x=0;y=0;z=i
do
if(m<0)
m=m+1
m=m-1
do
if(n<0)
n=n+1
n=n-1
do
if(l<0)
l=l+1
l=l-1
bubble(Cefilm,3)
print "\r"
wave w
variable n
for(i=1;i<n;i++)
k=0
k++
if(k==(n-i))
break
function xcoordi()
wave b1,b2
variable i
for(i=0;i<100;i++)
Vasp utilities written in Igor. It can be used to plot bands, projected dos, weighted bands and find bands cross the fermi level. It can also be used to write POSCAR and KPOINTS for several crystal structures.
November 3, 2020 at 05:47 am - Permalink
Would you be so kind to do two things: Package this as an Igor Pro pxp file and provide an example of the plots that it can produce.
November 3, 2020 at 09:25 am - Permalink
In reply to Would you be so kind to do… by jjweimer
I don't quite understand what is meant by "Package this as an Igor Pro pxp file". Could you explain it to me? If you want to do some plot, you can just run one of the functions, e.g. vaspbands("D","EIGENVAL","D","OUTCAR",1.2). As for the plots it can give, I can show some graphs I have done later.
November 3, 2020 at 05:45 pm - Permalink
slab bands plot
dos
weighted bands read from EIGENVAL and PROCAR
Fermi surface extracted using Igor and plotted using Fermisurfer
November 3, 2020 at 06:20 pm - Permalink
In reply to I don't quite understand… by Yuan Fang
Well, it seems that some files are required which many of the forum users will not have readily available.
November 4, 2020 at 12:04 am - Permalink
In reply to Yuan Fang wrote: If you… by ChrLie
Yes. It requires output files from Vienna Ab initio Simulation Package (VASP). And for function extract_fs(), it requires output file from Wannier90.
November 4, 2020 at 12:12 am - Permalink
* Open Igor Pro.
* Copy the code into the procedure window.
* Save the Igor Pro experiment (e.g. as VASP Utitlities Code.pxp).
* Post the pxp file.
The better approach for long code that does something specific such as your example is to create an Igor Pro project rather than post the raw code as forum discussion. See the brief information and longer list here. https://www.wavemetrics.com/projects
Finally, it would be helpful when the pxp project file contained sample raw data so that the functions could be run to create example plots directly. Then, it could be called VASP Utilities Demo.pxp by example.
November 4, 2020 at 06:07 am - Permalink
In reply to > I don't quite understand… by jjweimer
Thank you! I think if I create a project for this code maybe I will also need to upload some demo input files generated by VASP onto this site. Is it possible? Maybe I can do this when I have time later.
November 10, 2020 at 09:58 pm - Permalink
Here is a synopsis of the steps to make what you have posted into a project on Igor Exchange.
Create an Igor Pro experiment (pxp file) with the code. Include example data in the experiment. Make plots using the example data. Save that file as VASP Demo. Compress that file as a ZIP archive. Create a NEW PROJECT on this site. Upload the ZIP archive.
November 11, 2020 at 08:20 am - Permalink
In reply to Here is a synopsis of the… by jjweimer
I have created a new project based on your suggestion. Now the input and output of the files containing band information can be realized through a panel.
January 8, 2022 at 08:40 pm - Permalink
