VaspUtilities
#pragma TextEncoding = "UTF-8"
#pragma rtGlobals=3     // Use modern global access method and strict wave access.
function vaspbands(path1,fname1,path2,fname2,fermilevel)
    string path1,fname1,path2,fname2
    variable fermilevel  //fermilevel
    variable a,i,t,j,k
    string str,fword,nkpts,nbnds
    Open/R a path1 + ":" + fname1
    for(i=0;i<5;i++)
         FReadLine a, str
     FReadLine a, str
     i=0
     t=0
     do
         fword=stringfromlist(i,str," ")
         if (stringmatch(fword,"")!=1)
            t=t+1
            if(t==2)
                nkpts=fword
            if(t==3)
                nbnds=fword
         i=i+1
     while(t<3)
     make/d/n=(str2num(nkpts),str2num(nbnds)) w
     for(i=0;i<str2num(nkpts);i++)
         FReadLine a, str
         FReadLine a, str
         for(j=0;j<str2num(nbnds);j++)
             FReadLine a, str
              k=0
              t=0
              do
                  fword=stringfromlist(k,str," ")
                      t=t+1
                      if(t==2)
                          w[i][j]=str2num(fword)
                  k=k+1
              while(t<2)
     for(i=0;i<str2num(nbnds);i++)
         make/d/n=(str2num(nkpts)) tmp
         tmp=w[p][i]-fermilevel
         duplicate tmp $"wave"+num2str(i)
         killwaves tmp
     killwaves w
     close a
     Open/R a path2 + ":" + fname2
     make/d/n=3 kold,knew
     make/d/n=(str2num(nkpts)) kpt
     do
         FReadLine a, str
         if(strlen(str)==0)
             break
         if(stringmatch(str,"*k-points in units of 2pi/SCALE*")==1)
             FReadLine a, str
             i=0
             t=0
             do
                     t=t+1
                     if(t==1)
                         kold[0]=str2num(fword)
                     elseif(t==2)
                         kold[1]=str2num(fword)
                     elseif(t==3)
                         kold[2]=str2num(fword)
                 i=i+1
             while(t<3)
             kpt[0]=0
             for(i=1;i<str2num(nkpts);i++)
                 FReadLine a, str
                 k=0
                 t=0
                 do
                         t=t+1
                         if(t==1)
                             knew[0]=str2num(fword)
                         elseif(t==2)
                             knew[1]=str2num(fword)
                         elseif(t==3)
                             knew[2]=str2num(fword)
                     k=k+1
                 while(t<3)
                 if(mod(i,100)==0)
                     kpt[i]=kpt[i-1]
                     kpt[i]=kpt[i-1]+sqrt((knew[0]-kold[0])^2+(knew[1]-kold[1])^2+(knew[2]-kold[2])^2)
                 kold=knew
     while(1)
     killwaves kold,knew
     close a
         if(i==0)
             display $"wave"+num2str(i) vs kpt
             appendtograph $"wave"+num2str(i) vs kpt
function vaspbands_mbj(path1,fname1,path2,fname2,fermilevel)
    variable a,i,t,j,k
    variable cc=120
    for(i=0;i<5;i++)
         FReadLine a, str
     FReadLine a, str
     i=0
     t=0
     do
            t=t+1
            if(t==2)
                nkpts=fword
            if(t==3)
                nbnds=fword
         i=i+1
     while(t<3)
         FReadLine a, str
         FReadLine a, str
             FReadLine a, str
              k=0
              t=0
              do
                      t=t+1
                      if(t==2)
                  k=k+1
              while(t<2)
         killwaves tmp
     killwaves w
     close a
     do
         FReadLine a, str
         if(strlen(str)==0)
             break
             FReadLine a, str
             i=0
             t=0
             do
                     t=t+1
                     if(t==1)
                     elseif(t==2)
                     elseif(t==3)
                 i=i+1
             while(t<3)
             kpt[0]=0
                 FReadLine a, str
                 k=0
                 t=0
                 do
                         t=t+1
                         if(t==1)
                         elseif(t==2)
                         elseif(t==3)
                     k=k+1
                 while(t<3)
                 if(mod(i,100)==0)
                     kpt[i]=kpt[i-1]
                 kold=knew
     while(1)
     killwaves kold,knew
     close a
         DeletePoints 0,cc, $"wave"+num2str(i)
     DeletePoints 0,cc,kpt
         if(i==0)
function splitdos(path1,fname1,path2,fname2) //fname1=DOSCAR,fname2=POSCAR
    variable a,b,i,t,j,k
    string str,fword,natms,nspin
     FReadLine a, str
     i=0
     t=0
     do
            t=t+1
            if(t==1)
                natms=fword
            if(t==3)
                nspin=fword
         i=i+1
     while(t<3)
     for(i=0;i<4;i++)
         FReadLine a, str
     printf "Number of atoms: %d\r  Number of spin: %d\r" str2num(natms),str2num(nspin)
     Open/R b path2 + ":" + fname2
     for(i=0;i<5;i++)
         FReadLine b, str
     FReadLine b, str
     i=0
     variable/g nspec=0
     do
            nspec=nspec+1
         i=i+1
     while(i<strlen(str))
     make/t/n=(nspec)/o atmnam
     i=0
     t=0
     do
            t=t+1
            if(t==nspec)
                variable memory=strlen(fword)
                string lastnm
                sscanf fword[0,memory-1],"%s",lastnm
                atmnam[t-1]=lastnm
                atmnam[t-1]=cleanupname(fword,0)
         i=i+1
     while(t<nspec)
     make/d/n=(nspec)/o atmnum
     FReadLine b, str
     i=0
     t=0
     do
            t=t+1
            atmnum[t-1]=str2num(fword)
         i=i+1
     while(t<nspec)
     close b
     printf "Number of species: %d\r" nspec
     variable temp=0
     for(i=0;i<nspec;i++)
         temp+=atmnum[i]
     if(str2num(natms)!=temp)
         printf "DOSCAR info & POSCAR does not match!\r"
         close a
         return -1
    FReadLine a, str
    i=0
    t=0
    do
        fword=stringfromlist(i,str," ",32)
            t=t+1
            if(t==1)
                variable/g nedos=str2num(fword)
            if(t==2)
                variable/g efermi=str2num(fword)
         i=i+1
     while(t<2)
     for(i=0;i<nedos;i++)
         FReadLine a, str
         if(i==0)
             j=0
             variable tl=0
             do
                 fword=stringfromlist(j,str," ")
                      tl=tl+1
                 j=j+1
             while(j<strlen(str))
             make/o/n=(nedos,tl)/d pdos_tot
         j=0
         t=0
         do
                  t=t+1
                  pdos_tot[i][t-1]=str2num(fword)
             j=j+1
         while(t<tl)
         for(j=0;j<atmnum[i];j++)
             FReadLine a, str
             for(k=0;k<nedos;k++)
                 FReadLine a, str
                 if(k==0)
                     variable in=0
                     tl=0
                     do
                         fword=stringfromlist(in,str," ")
                              tl=tl+1
                         in=in+1
                     while(in<strlen(str))
                     make/o/n=(nedos,tl)/d tempwave
                 in=0
                 t=0
                 do
                         t=t+1
                         tempwave[k][t-1]=str2num(fword)
                     in=in+1
                 while(t<tl)
             duplicate/o tempwave, $"pdos_"+atmnam[i]+"_"+num2str(j+1)
     killwaves tempwave
function splitdosif(path1,fname1,path2,fname2)
     FReadLine a, str
     i=0
     t=0
     do
            t=t+1
            if(t==1)
                natms=fword
            if(t==3)
                nspin=fword
         i=i+1
     while(t<3)
     for(i=0;i<4;i++)
         FReadLine a, str
     for(i=0;i<5;i++)
         FReadLine b, str
     FReadLine b, str
     i=0
     variable/g nspec=0
     do
            nspec=nspec+1
         i=i+1
     i=0
     t=0
     do
            t=t+1
            if(t==nspec)
                string lastnm
                atmnam[t-1]=lastnm
         i=i+1
     while(t<nspec)
     FReadLine b, str
     i=0
     t=0
     do
            t=t+1
         i=i+1
     while(t<nspec)
     close b
     variable temp=0
         temp+=atmnum[i]
         close a
         return -1
    FReadLine a, str
    i=0
    t=0
    do
            t=t+1
            if(t==1)
            if(t==2)
         i=i+1
     while(t<2)
         FReadLine a, str
         if(i==0)
             j=0
             variable tl=0
             do
                      tl=tl+1
                 j=j+1
         j=0
         t=0
         do
                  t=t+1
             j=j+1
         while(t<tl)
             FReadLine a, str
             for(k=0;k<(2*nedos);k++)
                 FReadLine a, str
                 if(k==0)
                     variable in=0
                     tl=0
                     do
                              tl=tl+1
                         in=in+1
                 if(k==1)
                     in=0
                     variable tll=0
                     do
                              tll=tll+1
                         in=in+1
                     redimension/n=(nedos,(tl+tll))/d tempwave
                 in=0
                 t=0
                 if(mod(k,2)==0)
                     do
                             t=t+1
                             tempwave[(k/2)][t-1]=str2num(fword)
                         in=in+1
                     while(t<tl)
                     do
                             t=t+1
                             tempwave[floor(k/2)][tl+t-1]=str2num(fword)
                         in=in+1
                     while(t<tll)
     killwaves tempwave
function sumdos()
    variable i,j
    variable/g nspec,nedos
    wave atmnum
    wave/t atmnam
             if(j==0)
                 duplicate/o $"pdos_"+atmnam[i]+"_"+num2str(j+1),tempwave
                 duplicate/o/r=[][0] $"pdos_"+atmnam[i]+"_"+num2str(j+1),energywave
                 duplicate/o $"pdos_"+atmnam[i]+"_"+num2str(j+1),tempwave2
                 tempwave+=tempwave2
                 killwaves tempwave2
         variable k
             tempwave[k][0]=energywave[k]
         duplicate/o tempwave $"pdos_"+atmnam[i]+"_tot"
     killwaves tempwave,energywave
function plotdosif()
variable i
variable/g nspec
wave/t atmnam
    variable j
    for(j=0;j<65;j++)
        if(j==1)
            duplicate/o/r=[][j] $"pdos_"+atmnam[i]+"_tot" $"pdos_"+atmnam[i]+"_tot_s"
        if(j==5)
            duplicate/o/r=[][j] $"pdos_"+atmnam[i]+"_tot" temp_p
        if(j==9)
            duplicate/o/r=[][j] $"pdos_"+atmnam[i]+"_tot" temp_p_t
            temp_p+=temp_p_t
        if(j==13)
            temp_p+=temp_p_t
            duplicate/o temp_p,$"pdos_"+atmnam[i]+"_tot_p"
            killwaves temp_p_t,temp_p
        if(j==17)
            duplicate/o/r=[][j] $"pdos_"+atmnam[i]+"_tot" temp_d
        if(j==21)
            duplicate/o/r=[][j] $"pdos_"+atmnam[i]+"_tot" temp_d_t
            temp_d+=temp_d_t
        if(j==25)
            temp_d+=temp_d_t
        if(j==29)
            temp_d+=temp_d_t
        if(j==33)
            temp_d+=temp_d_t
            duplicate/o temp_d,$"pdos_"+atmnam[i]+"_tot_d"
            killwaves temp_d_t,temp_d
        if(j==37)
            duplicate/o/r=[][j] $"pdos_"+atmnam[i]+"_tot" temp_f
        if(j==41)
            duplicate/o/r=[][j] $"pdos_"+atmnam[i]+"_tot" temp_f_t
            temp_f+=temp_f_t
        if(j==45)
            temp_f+=temp_f_t
        if(j==49)
            temp_f+=temp_f_t
        if(j==53)
            temp_f+=temp_f_t
        if(j==57)
            temp_f+=temp_f_t
        if(j==61)
            temp_f+=temp_f_t
            duplicate/o temp_f,$"pdos_"+atmnam[i]+"_tot_f"
            killwaves temp_f_t,temp_f
    if(i==0)
        display $"pdos_"+atmnam[i]+"_tot_s" vs $"pdos_"+atmnam[i]+"_tot"[][0]
        appendtograph $"pdos_"+atmnam[i]+"_tot_s" vs $"pdos_"+atmnam[i]+"_tot"[][0]
    appendtograph $"pdos_"+atmnam[i]+"_tot_p" vs $"pdos_"+atmnam[i]+"_tot"[][0]
    appendtograph $"pdos_"+atmnam[i]+"_tot_d" vs $"pdos_"+atmnam[i]+"_tot"[][0]
    appendtograph $"pdos_"+atmnam[i]+"_tot_f" vs $"pdos_"+atmnam[i]+"_tot"[][0]
function plotdoslf()
variable i
variable/g nspec
wave/t atmnam
    variable j
    for(j=0;j<65;j++)
        if(j==1)
        if(j==5)
        if(j==9)
            temp_p+=temp_p_t
        if(j==13)
            temp_p+=temp_p_t
        if(j==17)
        if(j==21)
            temp_d+=temp_d_t
        if(j==25)
            temp_d+=temp_d_t
        if(j==29)
            temp_d+=temp_d_t
        if(j==33)
            temp_d+=temp_d_t
    if(i==0)
function Findbands(numbnds,efermi)
variable numbnds,efermi
variable i
make/o/n=(numbnds) mini,maxm
for(i=0;i<numbnds;i++)
loadwave/a/o/d/g/L={0,21+1030302*i,1030301,0,0} "C:\Users\Lenovo\Desktop\wannier90.bxsf"
wavestats $"wave"+num2str(i)
mini[i]=V_min
maxm[i]=V_max
killwaves $"wave"+num2str(i)
    if((efermi>mini[i])&&(efermi<maxm[i]))
        print i+1
function extract_fs(path1,fname1,path2,fname2,nstart,nend) //fname1 read;fname2 write
    variable nstart,nend
    string str,temp,fword
    variable nx,ny,nz
    Open b path2 + ":" + fname2
    for(i=0;i<14;i++)
         FReadLine a, str
         temp=str[0,strlen(str)-2]
         fprintf b,temp
         fprintf b,"\n"
     FReadLine a, str
     i=0
     t=0
     do
            t=t+1
            if(t==1)
                temp=fword[0,strlen(fword)-2]
         i=i+1
     while(t<1)
     if((nend<nstart)||(str2num(temp)<nend))
         fprintf b,"Wrong indices,exit...\n"
         close a
         close b
         return -1
     fprintf b,"%15d\n",nend-nstart+1
     FReadLine a, str
     fprintf b,temp
     fprintf b,"\n"
     i=0
     t=0
     do
            t=t+1
            if(t==1)
                temp=fword[0,strlen(fword)-1]
                nx=str2num(temp)
            if(t==2)
                ny=str2num(temp)
            if(t==3)
                nz=str2num(temp)
         i=i+1
     while(t<3)
     for(i=0;i<4;i++)
         FReadLine a, str
         fprintf b,temp
         fprintf b,"\n"
     for(i=1;i<nstart;i++)
         for(j=0;j<(nx*ny*nz+1);j++)
             FReadLine a, str
     for(i=0;i<(nend-nstart+1);i++)
         FReadLine a, str
         fprintf b,"BAND:%12d\n",i+1
         for(j=0;j<(nx*ny*nz);j++)
             FReadLine a, str
             fprintf b,temp
             fprintf b,"\n"
    fprintf b," END_BANDGRID_3D\n"
    fprintf b,"  END_BLOCK_BANDGRID_3D\n"
    close a
    close b
function vaspbands_proj(path1,fname1,atoms,orbitals) //read procar non-soc
    wave atoms
    wave orbitals
    string path1,fname1
    variable a,i,t,j,k,u
    variable s
    variable inner,np,ccc
    string str,fword,nkpts,nbnds,nions
     FReadLine a, str
     FReadLine a, str
     i=0
     t=0
     do
            t=t+1
            if(t==4)
                nkpts=fword
            if(t==8)
                nbnds=fword
            if(t==12)
                nions=fword
         i=i+1
     while(t<12)
     make/o/d/n=(str2num(nkpts),str2num(nbnds)) tem
     for(u=0;u<str2num(nkpts);u++)
         for(i=0;i<3;i++)
             FReadLine a, str
         for(k=0;k<str2num(nbnds);k++)
             for(i=0;i<3;i++)
                 FReadLine a, str
             s=0
             for(np=0;np<numpnts(atoms);np++)
               if(np==0)
                 if(atoms[0]==1)
                     FReadLine a, str
                     j=0
                     t=0
                     do
                            t=t+1
                            for(ccc=0;ccc<numpnts(orbitals);ccc++)
                              if(t==orbitals[ccc])
                                s+=str2num(fword)
                         j=j+1
                     while(t<orbitals[numpnts(orbitals)-1])
                 if(atoms[0]>1)
                     for(inner=0;inner<(atoms[0]-1);inner++)
                         FReadLine a, str
                     FReadLine a, str
                     j=0
                     t=0
                     do
                            t=t+1
                                s+=str2num(fword)
                         j=j+1
                 if((atoms[np]-atoms[np-1])==1)
                     FReadLine a, str
                     j=0
                     t=0
                     do
                            t=t+1
                                s+=str2num(fword)
                         j=j+1
                 if((atoms[np]-atoms[np-1])>1)
                     for(inner=0;inner<(atoms[np]-atoms[np-1]-1);inner++)
                         FReadLine a, str
                     FReadLine a, str
                     j=0
                     t=0
                     do
                            t=t+1
                                s+=str2num(fword)
                         j=j+1
            if(str2num(nions)==atoms[numpnts(atoms)-1])
                 FReadLine a, str
                 FReadLine a, str
                 for(i=0;i<(str2num(nions)-atoms[numpnts(atoms)-1]);i++)
                     FReadLine a, str
                 FReadLine a, str
                 FReadLine a, str
                  tem[u][k]=s
         duplicate/o/r=[0,str2num(nkpts)-1][i,i] tem $"weight"+num2str(i)
     close a
function vaspbands_projsoc(path1,fname1,atoms,orbitals) //read procar soc
    wave atoms
    wave orbitals
    string path1,fname1
    variable s
     FReadLine a, str
     FReadLine a, str
     i=0
     t=0
     do
            t=t+1
            if(t==4)
                nkpts=fword
            if(t==8)
                nbnds=fword
            if(t==12)
                nions=fword
         i=i+1
     while(t<12)
         for(i=0;i<3;i++)
             FReadLine a, str
             for(i=0;i<3;i++)
                 FReadLine a, str
             s=0
               if(np==0)
                 if(atoms[0]==1)
                     FReadLine a, str
                     j=0
                     t=0
                     do
                            t=t+1
                                s+=str2num(fword)
                         j=j+1
                 if(atoms[0]>1)
                         FReadLine a, str
                     FReadLine a, str
                     j=0
                     t=0
                     do
                            t=t+1
                                s+=str2num(fword)
                         j=j+1
                     FReadLine a, str
                     j=0
                     t=0
                     do
                            t=t+1
                                s+=str2num(fword)
                         j=j+1
                         FReadLine a, str
                     FReadLine a, str
                     j=0
                     t=0
                     do
                            t=t+1
                                s+=str2num(fword)
                         j=j+1
            variable jjj
            for(jjj=0;jjj<(3*(str2num(nions)+1+1));jjj++)
               FReadLine a, str
                 FReadLine a, str
                 FReadLine a, str
                 FReadLine a, str
                     FReadLine a, str
                 FReadLine a, str
                 FReadLine a, str
                 FReadLine a, str
                  tem[u][k]=s
     close a
function projbulkbnds(m,n,p) //projected bulk bands plot.m:the number of points between two kpoints;
                             //n:number of different kzs;p:numberof bands.
    variable m,n,p
    variable i,j,k
    wave kpt
    make/n=(2*m) refer
    for(i=0;i<(2*m);i++)
        refer[i]=kpt[i]
    make/n=(2*m) tem1
    for(i=0;i<p;i++)
        duplicate $"wave"+num2str(i),tem2
        for(j=i;j<i+p*(n-1)+1;j=j+p)
            for(k=0;k<(2*m);k++)
                tem1[k]=tem2[k]
            duplicate tem1,$"w"+num2str(j)
            if(j==0)
                display $"w"+num2str(j) vs refer
                appendtograph $"w"+num2str(j) vs refer
            DeletePoints 0,3*m, tem2
       killwaves tem2
    killwaves tem1
function difkzplot(nbnds,nkz,ymin,ymax,j)
variable nbnds
variable nkz
variable ymin,ymax //display range
variable j  //j can take value 0-20,corresponding to kz=j/(nkz-1)*(gamma-z)
variable kz=j/(nkz-1)
wave xwave
variable i
for(i=0;i<nbnds;i++)
     if(i==0)
        display $"w"+num2str(j*nbnds) vs xwave
        TextBox/C/N=text0/F=0/A=MC num2str(kz)+"*G-Z"
        SetAxis left ymin,ymax
        appendtograph $"w"+num2str(j*nbnds+i) vs xwave
function fcc111()  //for writing fcc 111 KPOINTS
variable a,b,c
a=    5.429
make/o/d/n=3 a1={0,a/2,a/2}
make/o/d/n=3 a2={a/2,0,a/2}
make/o/d/n=3 a3={a/2,a/2,0}
cross a2,a3
variable vprim
wave W_Cross
vprim=matrixDot(a1,W_Cross)
make/o/d/n=3 b1,b2,b3
b1=2*pi*W_Cross/vprim
cross a3,a1
b2=2*pi*W_Cross/vprim
cross a1,a2
b3=2*pi*W_Cross/vprim
Concatenate/O {b1,b2,b3},primbasis
make/o/d/n=3 aa1={-a/2,a/2,0}
make/o/d/n=3 aa2={0,-a/2,a/2}
make/o/d/n=3 aa3={a,a,a}
cross aa2,aa3
variable vconv
vconv=matrixDot(aa1,W_Cross)
make/o/d/n=3 bb1,bb2,bb3
bb1=2*pi*W_Cross/vconv
cross aa3,aa1
bb2=2*pi*W_Cross/vconv
bb3=1/2*(b1+b2+b3)
Concatenate/O {bb1,bb2,bb3},convbasis
matrixinverse primbasis
wave M_inverse
matrixop/o matC=M_inverse x convbasis
print vprim
print vprim/vconv
cross b2,b3
variable kvprim
kvprim=matrixDot(b1,W_Cross)
cross bb2,bb3
variable kvconv
kvconv=matrixDot(bb1,W_Cross)
print kvprim/kvconv
function simplecubic111()  //for writing simple cubic 111 KPOINTS
variable a,b,c
a=    2.3537117117709037*2
make/o/d/n=3 a1={a,0,0}
make/o/d/n=3 a2={0,a,0}
make/o/d/n=3 a3={0,0,a}
cross a2,a3
variable vprim
wave W_Cross
cross a3,a1
cross a1,a2
make/o/d/n=3 aa1={a,-a,0}
make/o/d/n=3 aa2={0,a,-a}
cross aa2,aa3
variable vconv
cross aa3,aa1
bb3=1/2*(b1+b2+b3)
wave M_inverse
print vprim/vconv
cross b2,b3
variable kvprim
cross bb2,bb3
variable kvconv
print kvprim/kvconv
function hr111()  //for writing hr 111 KPOINTS
variable a,c
a=    3.6281/sqrt(3)
c=26.233/3
make/o/d/n=3 a1={-a/2,sqrt(3)/2*a,c}
make/o/d/n=3 a2={-a/2,-sqrt(3)/2*a,c}
make/o/d/n=3 a3={a,0,c}
cross a2,a3
variable vprim
wave W_Cross
cross a3,a1
cross a1,a2
make/o/d/n=3 aa1=a2-a3
make/o/d/n=3 aa2=a3-a1
make/o/d/n=3 aa3=a1+a2+a3
cross aa2,aa3
variable vconv
wave W_cross
cross aa3,aa1
bb3=1/2*(b1+b2+b3)
wave M_inverse
print vprim
print vprim/vconv
cross b2,b3
variable kvprim
cross bb2,bb3
variable kvconv
print kvprim/kvconv
function changecoord() //for KPOINTS coordinate transformation
variable x,y,z
variable m,n,l
wave matC
variable i
variable k=0
for(i=0;i<21;i++)
  x=1/2;y=0;z=i/20 // M bar point
  m=matC[0][0]*x+matC[0][1]*y+matC[0][2]*z
  n=matC[1][0]*x+matC[1][1]*y+matC[1][2]*z
  l=matC[2][0]*x+matC[2][1]*y+matC[2][2]*z
  if(i==0)
    printf "%.12f %.12f %.12f\r" m, n, l
  x=0;y=0;z=i/20 //gamma bar point
  x=1/3;y=1/3;z=i/20 //K bar point
  if(i==20)
function fcc111slab(nlayer,a) //for writing fcc 111 slab POSCAR
    variable nlayer,a
    make/o/d matA={{-1/2,1/2,0},{0,-1/2,1/2},{1,1,1}}
    matrixinverse matA
    wave M_inverse
    make/o/d matB={{0,1/2,1/2},{1/2,0,1/2},{1/2,1/2,0}}
    matrixop/o matC=M_inverse x matB
    make/o/d/n=(3,3) Cefilm
    variable x,y,z,m,n,l,i
        for(i=0;i<3;i++)
            x=0;y=0;z=i
            do
                if(m<0)
                    m=m+1
                elseif((m>1)||(m==1))
                    m=m-1
            while((m<0)||(m>1)||(m==1))
            do
                if(n<0)
                    n=n+1
                elseif((n>1)||(n==1))
                    n=n-1
            while((n<0)||(n>1)||(n==1))
            do
                if(l<0)
                    l=l+1
                elseif((l>1)||(l==1))
                    l=l-1
            while((l<0)||(l>1)||(l==1))
            Cefilm[i][0]=m ;Cefilm[i][1]=n ;Cefilm[i][2]=l
        bubble(Cefilm,3)
    redimension/n=(nlayer,3) Cefilm
    for(i=3;i<nlayer;i++)
        Cefilm[i][0]=Cefilm[i-3][0]
        Cefilm[i][1]=Cefilm[i-3][1]
        Cefilm[i][2]=Cefilm[i-3][2]+1
    for(i=0;i<nlayer;i++)
         printf "%.12f %.12f %.12f\r",Cefilm[i][0],Cefilm[i][1], (Cefilm[i][2]*a*sqrt(3)/((Cefilm[nlayer-1][2]-Cefilm[0][2])*a*sqrt(3)+18))
    print "\r"
    printf "%.12f\r" (Cefilm[nlayer-1][2]-Cefilm[0][2])*a*sqrt(3)+18
function bubble(w,n)
    wave w
    variable n
    variable i,j,k,t1,t2,t3
    for(i=1;i<n;i++)
        k=0
        for(j=0;j<(n-i);j++)
            if(w[j][2]>w[j+1][2])
                t1=w[j][0];w[j][0]=w[j+1][0];w[j+1][0]=t1
                t2=w[j][1];w[j][1]=w[j+1][1];w[j+1][1]=t2
                t3=w[j][2];w[j][2]=w[j+1][2];w[j+1][2]=t3
                k++
        if(k==(n-i))
            break
function xcoordi()
wave b1,b2
make/o/d/n=200 xwave
variable i
for(i=0;i<100;i++)
    xwave[i]=1/2*sqrt(b1[0]^2+b1[1]^2+b1[2]^2)/99*(i-99)
for(i=100;i<200;i++)
    xwave[i]=1/3*sqrt((b1[0]+b2[0])^2+(b1[1]+b2[1])^2+(b1[2]+b2[2])^2)/99*(i-100)
Vasp utilities written in Igor. It can be used to plot bands, projected dos, weighted bands and find bands cross the fermi level. It can also be used to write POSCAR and KPOINTS for several crystal structures.
Would you be so kind to do two things: Package this as an Igor Pro pxp file and provide an example of the plots that it can produce.
In reply to by jjweimer
I don't quite understand what is meant by "Package this as an Igor Pro pxp file". Could you explain it to me? If you want to do some plot, you can just run one of the functions, e.g. vaspbands("D","EIGENVAL","D","OUTCAR",1.2). As for the plots it can give, I can show some graphs I have done later.
In reply to by Yuan Fang
Well, it seems that some files are required which many of the forum users will not have readily available.
* Open Igor Pro.
* Copy the code into the procedure window.
* Save the Igor Pro experiment (e.g. as VASP Utitlities Code.pxp).
* Post the pxp file.
The better approach for long code that does something specific such as your example is to create an Igor Pro project rather than post the raw code as forum discussion. See the brief information and longer list here. https://www.wavemetrics.com/projects
Finally, it would be helpful when the pxp project file contained sample raw data so that the functions could be run to create example plots directly. Then, it could be called VASP Utilities Demo.pxp by example.
Here is a synopsis of the steps to make what you have posted into a project on Igor Exchange.
Create an Igor Pro experiment (pxp file) with the code. Include example data in the experiment. Make plots using the example data. Save that file as VASP Demo. Compress that file as a ZIP archive. Create a NEW PROJECT on this site. Upload the ZIP archive.
