Loading JSON File
I am trying to use the JSON XOP - my first time trying to use an XOP - but having problems with the instructions. The instructions are clear after loading the JSON file into a string.
Question: How do I load the JSON file to a JSON string to then use JSONXOP_GetValue to pass the data into waves?
Thank you!
Best,
thomas_braun
Loading an arbitrary file is not exactly straightforward. Something like the following should do the trick:
#include "json_functions"
Function JsonLoadFromFile(string path)
	variable refNum
	string contents
	Open/R/Z refNum as path
	if(V_Flag)
		return NaN
	FStatus refNum
	contents = PadString("", V_LogEOF, 0)
	FBinRead refNum, contents
	Close refNum
	return JSON_Parse(contents, ignoreErr = 1)
This returns  NaN on error or a valid jsonID in the sucess case.
silvan.roth
Hi
I have a large json file (see attachment). I want to have the values put in igor waves. How can I use the function above in order to do that? Where do I load the file? How can I get this to run?
Cheers
Silvan
json file as txt (2.86 MB)
thomas_braun
@Silvan:
You need the JSON-XOP from https://docs.byte-physics.de/json-xop/. Install it.
And then you can use the below code as a starting point:
Function/WAVE JsonLinesLoadFromFile(string path)
    variable refNum
    string contents
    if(V_Flag)
        return $""
    FStatus refNum
    Close refNum
    WAVE/T wv = ListToTextWave(contents, "\n")
    return wv
Function ExtractFromLine(string JSONText)
	variable jsonID, temp
	// fixup non-conformant JSON with NaNs as numbers to NaNs as strings
	JSONText = ReplaceString(": NaN,",JSONText, ": \"NaN\", ")
	jsonID = JSON_Parse(JSONText, ignoreErr = 1)
	if(numtype(jsonID) != 0)
		return NaN
	temp = JSON_GetVariable(jsonID, "cpu_temperature")
	JSON_Release(jsonID)
	return temp
Function Parse()
	WAVE/T contents = JsonLinesLoadFromFile("E:\\walk_A2.txt")
	Make/N=(DimSize(contents, 0))/O cpuTemp = ExtractFromLine(contents[p])
This is not a pure JSON file, it is in JSONLines format, https://jsonlines.org/, where each line is its own JSON document.
Whoever produced that file did also not create a standards-compliant file, as you can not use NaN when a number is expected. I've added some hacky fix for that.
