fitting log normal
Hello
I would like to fit a lognormal curve to my data. Igor can do it, but it uses it's weird equation for fitting and it's confounding to extract sigma, miu values.
I created my own fitting function that uses the "normal" log-normal expression and I can't fit it to my data points. Here is the expression:
f(x) = (B/(S*x*(2*PI)^0.5))*EXP(-((LN(x)-M)^2)/(2*(S)^2))
where M is miu and S is sigma,
What is wrong with this expression? Why can't it fit?
Here are the parameters from fitting using igor's lognormal equation
  fit_wave1= W_coef[0]+W_coef[1]*exp(-(ln(x/W_coef[2])/W_coef[3])^2)
  W_coef={1.5577,58.237,33.619,0.44161}
  V_chisq= 3.27861e-15;V_npnts= 199;V_numNaNs= 0;V_numINFs= 0;
  V_startRow= 0;V_endRow= 198;
  W_sigma={3.59e-10,1.13e-09,2.42e-10,1.06e-11}
  Coefficient values ± one standard deviation
  	y0   	= 1.5577 ± 3.59e-10
  	A    	= 58.237 ± 1.13e-09
  	x0   	= 33.619 ± 2.42e-10
  	width	= 0.44161 ± 1.06e-11
How do I change A,x0 and width into more commonly known values?
ChrLie
 Why can't it fit?
Have you tried if your user defined function produces the desired curve shape?
jjweimer
You are confusing the use of second wave iks for the x axis and the x value of a wave itself. Look for help on the SetScale operation.
make/N=101/D igrek
SetScale/P x 0,0.1,"", igrek
display igrek
igrek = (1/(4*x*(2*Pi)^0.5))*exp(-((ln(x) - 0)^2)/(2*(0.25)^2))
ChrLie
not sure if line 10 does what you expect: you have x and iks on the right-hand-side and the are not the same. I assume you want only one of them.
But how does your user-defined fit function look like that is created by the curve fitting dialogue?
ChrLie
you should have something like
Function myLogNormal(w,x) : FitFunc
	Wave w
	Variable x
	//CurveFitDialog/ Equation:
	//CurveFitDialog/ f(x) = (1 / (x * sigma * sqrt(2*pi))) * exp(-(ln(x) - mu)^2/ (2 * sigma^2) )
	//CurveFitDialog/ x
	//CurveFitDialog/ Coefficients 2
	//CurveFitDialog/ w[0] = sigma
	//CurveFitDialog/ w[1] = mu
	return (1 / (x * w[0] * sqrt(2*pi))) * exp(-(ln(x) - w[1])^2/ (2 * w[0]^2) )
you can test the validity:
make/D fitCheck
SetScale x 0, 10, FitCheck
Make/D testCoefs ={0.25,1}
FitCheck = myLogNormal(testCoefs,x)
display fitCheck
Innuendo
Yes you are right. I used both x and "iks" wave in the equation.
Regardless the equation in correct:
Y = (1/(0.25*x*(2*Pi)^0.5))*exp(-((ln(x) - 0)^2)/(2*(0.25)^2))
or
Y = (1/(0.25*iks*(2*PI)^0.5))*EXP(-((LN(iks)-0)^2)/(2*(0.25)^2))
And it produces lognormal distribution.
But that is beside the point. I can fit using igor's lognormal fitting, but I can't extract commonly used parameters. I read the help file, but the parameters I get, don't make any sense.
igor explanation.png (103.67 KB)
In reply to by ChrLie
Innuendo
    Wave w
    Variable x
    //CurveFitDialog/ x
make/D fitCheck
display fitCheck
Thank you, but it doesn't work. It requires initial coefficient values and fails to fit the line.
jjweimer
Certainly you will need initial guesses. Otherwise you are asking to fit the equation starting from nothing. Or, equivalently, you are asking Igor to find the right answer from an infinite possibility of answers. Igor is smart, but not all knowing.
Post your example data set in the experiment that you used. It seems that somehow your problem is more complex than simply a mistake in the fitting function itself.
Also, I might address some sense of negative undertones in your postings (with apologies if you don't overtly mean them in this way). As far as extracting "commonly used parameters", consider an alternate. In spectroscopy, the Gaussian distribution is defined for a peak is defined by position, peak height, and peak full width at half maximum. In probability, the distribution uses mean, standard deviation, and area. Which one should you want us to have WaveMetrics define as "common"? And should the other half of the community raise an outcry when their choice is not provided?
ChrLie
If I plot the results from Igors curve fit, it does not look like it can be fitted with, say 0.5 and 1, as initial guesses in myLogNormal (although I don't know what the x-scaling of fit_wave1 is).
Can there be some scaling issues with your data?
In reply to by Innuendo
tony
The answer is in the help file screenshot that you posted.
Function logn(w,x) : FitFunc
	Wave w
	Variable x
	//CurveFitDialog/ variable mu = ln(x0) + w^2/2
	//CurveFitDialog/ variable sigma = w/sqrt(2)
	//CurveFitDialog/ variable B = A*x0*sigma*sqrt(2*pi)/exp(-w^2/4)
	//CurveFitDialog/
	//CurveFitDialog/
	//CurveFitDialog/ f(x) = y0 + B/(x*sigma*sqrt(2*pi))*exp(-(ln(x) - mu)^2/(2*sigma^2))
	//CurveFitDialog/ x
	//CurveFitDialog/ Coefficients 4
	//CurveFitDialog/ w[0] = A
	//CurveFitDialog/ w[1] = w
	//CurveFitDialog/ w[2] = x0
	//CurveFitDialog/ w[3] = y0
	variable mu = ln(w[2]) + w[1]^2/2
	variable sigma = w[1]/sqrt(2)
	variable B = w[0]*w[2]*sigma*sqrt(2*pi)/exp(-w[1]^2/4)
	return w[3] + B/(x*sigma*sqrt(2*pi))*exp(-(ln(x) - mu)^2/(2*sigma^2))
this uses the lognormal PDF equation and produces the same curve as the lognormal fit function.
you can do the same thing in reverse if you want to use sigma and mu as fit coefficients.
In reply to by tony
tony
	Wave w
	Variable x
	//CurveFitDialog/ variable width = sqrt(2)*sigma
	//CurveFitDialog/ variable x0 = exp(mu - width^2/2)
	//CurveFitDialog/ variable A = 1/x0 * exp(-(width^2/4)) * B/(sigma*sqrt(2*pi))
	//CurveFitDialog/
	//CurveFitDialog/ f(x) = y0 + A * exp(- (ln(x/x0)/width)^2 )
	//CurveFitDialog/ x
	//CurveFitDialog/ w[0] = y0
	//CurveFitDialog/ w[1] = B
	//CurveFitDialog/ w[2] = mu
	//CurveFitDialog/ w[3] = sigma
	int usePDF = 1
	if (usePDF)
		return w[0] + w[1]/(x*w[3]*sqrt(2*pi))*exp(-(ln(x) - w[2])^2/(2*w[3]^2))
		variable width = sqrt(2)*w[3]
		variable x0 = exp(w[2] - width^2/2)
		variable A = 1/x0 * exp(-(width^2/4)) * w[1]/(w[3]*sqrt(2*pi))
		return w[0] + A * exp(- (ln(x/x0)/width)^2 )
y0   	= 1.5577
B    	= 1609.1
mu   	= 3.6126
sigma	= 0.31227
edit: I changed the fit function so that you can switch between the two equations and see for yourself that the results are the same.
johnweeks
An Igor experiment file with a data set you are trying to fit and your fitting function would allow us to more fully investigate your problem. It seems like Tony has provided you with a pretty good answer.
