Duplicate graph in a function
I have two (related) questions.
1. I would like to duplicate a graph using code, i.e. the equivalent of the menu item Edit/Duplicate Graph. The forum archive has a post (https://www.wavemetrics.com/code-snippet/clone-window) from 2010 with two functions by RGerkin that I cannot get to work because they include GetWinCoords, which I assume is a custom function. Before I write my own function to get window coordinates, is there a more direct command or function to duplicate a graph programmatically now?
(I thought of creating the graph's macro using the doWindow /R command, but the manual says "However, /R does nothing if a macro or function is running.")
2. The general task I am programming is to plot a long time series as 5 very wide graphs arranged in a vertical column on a layout. Each graph would show 1/5 of the full time series. If the time series' entire range is from x0 to x1:
- the top graph's range should be (x0, (x1-x0)/5)
- the second graph's range should be ((x1-x0)/5), 2*(x1-x0)/5)
...and so on. The approach I am taking is to start from a plot that has the entire range; duplicate it; set the range to the sub-range appropriate for that graph.
If anyone wants to suggest a better way, feel free.
Pietro
johnweeks
and then you can execute that recreation macro using Execute from your code.
Note that if the graph is a subwindow, you will have to go through some gyrations if want just the gaph.
In reply to by ilavsky
tony
Aha!
Then we have
function /S duplicateGraph(string win)
	win = SelectString(strlen(win)==0, win, WinName(0, 1))
	if (strlen(win) == 0)
		return ""
	DoWindow /F $win
	if (V_flag == 0)
		return ""
	DoIgorMenu "Edit", "Duplicate"
	return WinName(0, 1)
johnweeks
DoIgorMenu solves some nasty problems, but can create others...
And I'm pretty sure this is equivalent, explicitly using code that Edit->Duplicate uses internally:
Function dupgraph(string gname)
    gname = SelectString(strlen(gname)==0, gname, WinName(0, 1))
    if (strlen(gname) == 0)
        return nan
    String recstr = WinRecreation(gname, 0)
    Execute recstr
The new graph window winds up on top because the Display command in recstr just does that.
