I have 4 experiments and want to combine the same waves in each of the experiments into a single experiment so I can display them all together. What is the easiest way to do this.
One way to start is to use the browse experiment function within the data browser. Start with one experiment and then open another via browse. Then drag the waves of interest to the base experiment. Rinse and repeat.
If you hold the 'alt' key while selecting the File menu an additional option for completely merging experiments will appear. This may be useful if you want to have everything together in one file, including graphs etc. Also, if you want to just 'copy-paste' one graph between experiments, there is a small script which does this reasonably well (for not too complicated cases):
April 20, 2023 at 12:22 pm - Permalink
In reply to Hi, One way to start is… by hegedus
ssmith911Thanks Andy. Exactly what I was looking for. New user naivety.
ssmith
April 20, 2023 at 12:49 pm - Permalink
https://www.wavemetrics.com/code-snippet/quick-graph-transfer-between-experiment-sessions
April 20, 2023 at 11:43 pm - Permalink
