Printing multiple layouts into one single PDF file
I want to know if it is possible to print, say, 12 layouts into one single PDF file.
I can print layout to PDF at the command line by setting the PDF printer as default printer but how I can print more than one layout into one single PDF?
I have lots of data and need to general reports automatically. If this can be done then I can avoid copying the layout and paste them into one Word file to make a report.
Thanks.
You can not print multiple layouts to a single PDF.
What you might be able to do is to insert pictures of the layouts into a notebook and the print the notebook. To find documentation on this, execute:
DisplayHelpTopic "Notebook"
and then scroll down to the text "Inserts a picture based on the specified object" which is in the section "Writing notebook graphics parameters".
For an example of using a notebook for a report choose File->Example Experiments->Feature Demos->Notebook Demo #1.
In case you prefer to merge the PDF files directly rather than print from a Notebook in Igor ...
On the Mac, you can use Preview to pull PDF files together in to one document. You can also use a command line tool ...
http://gotofritz.net/blog/howto/joining-pdf-files-in-os-x-from-the-comm…
... programmed via ExecuteScript for example.
On Windows, you might be able to find a free tool with names like PDFMerge or PDFCombine.
Thank you and I have tried both and it seems that creating a notebook with multiple page of graphics is the best for me.
Now I have another question in creating the header and footer in the command line. How can I create header and footer in command line for the notebook?
THanks!
Unfortunately it is not possible to set the header and footer from the command line.
Instead create a notebook with the desired header and footer. Save it as a template file. To create a new notebook open the template file.
To learn about template files execute:
DisplayHelpTopic "Notebook Template Files"
Is the best solution still to use a notebook for this ?
Or are there new functionalities to export the multiple page of a  layout directly into a pdf ?
SavePICT can export a multi-page layout into a multi-page PDF file. You can control which pages of the layout are exported using the /PGR flag.
