Printing multiple layouts into one single PDF file
I can print layout to PDF at the command line by setting the PDF printer as default printer but how I can print more than one layout into one single PDF?
I have lots of data and need to general reports automatically. If this can be done then I can avoid copying the layout and paste them into one Word file to make a report.
Thanks.
What you might be able to do is to insert pictures of the layouts into a notebook and the print the notebook. To find documentation on this, execute:
and then scroll down to the text "Inserts a picture based on the specified object" which is in the section "Writing notebook graphics parameters".
For an example of using a notebook for a report choose File->Example Experiments->Feature Demos->Notebook Demo #1.
May 9, 2013 at 09:54 pm - Permalink
On the Mac, you can use Preview to pull PDF files together in to one document. You can also use a command line tool ...
http://gotofritz.net/blog/howto/joining-pdf-files-in-os-x-from-the-comm…
... programmed via ExecuteScript for example.
On Windows, you might be able to find a free tool with names like PDFMerge or PDFCombine.
May 10, 2013 at 10:17 am - Permalink
Now I have another question in creating the header and footer in the command line. How can I create header and footer in command line for the notebook?
THanks!
May 10, 2013 at 10:14 pm - Permalink
Instead create a notebook with the desired header and footer. Save it as a template file. To create a new notebook open the template file.
To learn about template files execute:
May 11, 2013 at 06:37 am - Permalink
Is the best solution still to use a notebook for this ?
Or are there new functionalities to export the multiple page of a layout directly into a pdf ?
April 25, 2023 at 10:51 am - Permalink
SavePICT can export a multi-page layout into a multi-page PDF file. You can control which pages of the layout are exported using the /PGR flag.
April 25, 2023 at 11:54 am - Permalink
Thanks !
April 25, 2023 at 01:10 pm - Permalink
