executescripttext with file name
I am working on some cross platform issues integrating with Python.
I am using (or attempting to use) ExecuteScriptText to run a shell script on the Mac and a bat file on Windows
On the Mac I create a string:
Do shell script "'fullpath/to/file.sh'" with single quotes to accommodate
On Windows I use parsefilepath(5,thelocation,"\\",0,0) to define the file path but am running into trouble.
The file path  is "C:Users\andy.hegedus\Desktop\Texture Classifier\Run_Python.bat" as the string.
Do I have to worry that the slashes are being interpreted as escape codes such as the \R into the operation, ExecuteTextScript or will it be interpreted as a legal file path?
tony
Here is a snippet of code that I used LONG ago for creating and running batch files. Not sure if this is helpful, but it did work for me. There are likely built-in functions that can replace the ugly path conversion functions.
function DL_SendToWeb(S_filelist)
	string S_filelist
	// files must be on disk at LoggerPath
	// uses external scp program to transfer files
	// Runs in the background. uses ssh user key.
	wave /T configTxt=root:Packages:RS232Logger:configTxt
	string s_filename
	variable refnum, numfiles=0
	do
		s_filename = StringFromList(numfiles, S_filelist)
		if (strlen(s_filename)==0)
			break
		refnum=0
		open /Z /R/P=LoggerPath refnum as s_filename // s_filename is changed here
		if (V_flag==0) // file exists
			close refnum
			numfiles+=1
			S_filelist=RemoveListItem(numfiles,S_filelist)
		// need to check that this always works as planned...
	while(1)
	if (numfiles <1)
	PathInfo LoggerPath
	string batPath=DL_MacPath2WinPath(S_path)
	string cmd
	string UnixPathStr=DL_MacPath2ForwardSlashPath(S_Path)
	// create a new batch file
	string s_batname
	variable i=1, maxbats=10
	refnum=0
	do
		sprintf s_batname, "uploader%d.bat", i
		open /Z /P=LoggerPath refnum as s_batname
		if (refnum) // file is open
			break
		i+=1
	while (i<=maxbats)
	if (i>maxbats)
		printf "%s   %s   ERROR: File upload failed - too many unwriteable batch files\r", date(), time()
	// write to the batch file
	// pscp usage:
	// pscp [options] source [source...] [user@]host:target
	// pscp [options]
	fprintf refnum, "\"%s\" %s", DL_MacPath2WinPath(ConfigTxt[%scpPathStr]), ConfigTxt[%scpFlags]
	// source [source...]
	for (i=0;i<numfiles;i+=1)
		fprintf refnum, " \"%s%s\"", UnixPathStr, StringFromList(i, S_filelist)
	// [user@]host:target
	fprintf refnum, " %s\r\n", ConfigTxt[%ServerAddress]
	fprintf refnum, "attrib -R %0\r\n" // make THIS batch file writeable
	fprintf refnum, "exit\r\n"
	close refnum
	SetFileFolderInfo /Z/RO batPath+s_batname  // make bat file read only so that we don't overwrite it before it has executed
	// the batch file is invoked using start so that we don't have to wait for completion
	sprintf cmd, "cmd.exe /C start \"\" /min \"%s%s\" ", batPath, s_batname
	ExecuteScriptText /W=0.5 /B/Z cmd
	if (V_flag)
		printf "%s   %s   ERROR: File upload failed at ExecuteScriptText\r", date(), time()
	return 1
// converts C:Program Files:Wavemetrics: to C:\\Program Files\\Wavemetrics\\
// double backslashes are needed when building commands as strings
function /T DL_MacPath2WinPath(str)
	string str
	variable i=3
	str[1,1]=":\\"
	do
		if (stringmatch (str[i], ":"))
			str[i,i]="\\"
		i+=1
	while(i<strlen(str))
	return str
function /T DL_MacPath2ForwardSlashPath(str)
	string str
	variable i=3
	str[1,1]=":/"
	do
			str[i,i]="/"
		i+=1
	return str
jtigor
Andy,
I haven't used "ExecuteScriptText" for quite some time, so relying on the help file it looks like you need to escape the backslashes in the file path:
When calling a batch file or other non-*.exe file, supply the full path. If the path (or file name) contains spaces, you must quote the path:
ExecuteScriptText "\"C:\\Program Files\\my.bat\""
The outer double-quotes are consumed by ExecuteScriptText. The inner double quotes, represented by the \" escape sequence, remain in the command passed to the operating system.
I thought there was a function to convert a path to the escaped version, but could not find such a thing.  You could try "ReplaceString" to replace a single backslash with a double backslash.
ReplaceString("\", thelocation, "\\")
