Trying to load files from a folder
I am new to IGOR and trying to create a procedure to lad all csv files from a folder. The files all have two columns and I want them to be plotted. I have attached the code I have but the problem I'm facing is that the code only uploads two waves wave0 and wave1 and not all the files from the folder.
#pragma rtGlobals=3 // Use modern global access method and strict wave access.
// Get the folder path.
Menu Reactor;
Load Reactor, LoadDataFromCSV()
Function LoadDataFromCSV()
string folderPath
string fname
string wname
string sname
variable i
getfilefolderinfo/D
newpath/O GCFolderData S_path
string fileList= indexedfile(GCFolderData,-1,".csv")
do
//store the ith name in the list into wname.
fname = stringfromlist(i,fileList)
//!!!!!!!!!! change the next line if you want a different name for the waves that are created !!!!!!!!!!!!!!!
wname = fname
sname = stringfromlist(i,filelist)
wave wave0 = $wname
wave wave1 = $sname
//if the referenced wave does not exist, create it.
if (!waveexists(wave0)&!waveexists(wave1))
//The /L parameter tells IGOR to load no headers, and to load the 3rd column of data (indexed as 2) only
//!!!!!!!! You must change this next line to tell IGOR how to load the data in each file !!!!!!!!!!!!!!!
LoadWave/J/N=wave/P=GCFolderData/O/L={0,0,0,0,0} stringfromlist(i,filelist)
LoadWave/J/N=wave/P=GCFolderData/O/L={0,0,0,1,0} stringfromlist(i,filelist)
print "Loaded "+fname
rename wave0 $wname
rename wave1 $sname
print fname+" was previously loaded. Its corresponding wave exists."
i += 1 //move to next file
while(i<itemsinlist(filelist)) //end when all files are processed.
proceduretest.ipf (2.02 KB)
johnweeks
Execute this Igor command to see a help topic that might help with the "all the files" part of the problem: DisplayHelpTopic "Loading All of the Files in a Folder"
Then add to it the graphing part of the problem. You may wish to examine other examples within that help file.
tony
Menu Reactor;
Here you need quotes around the strings
// - snip -
wname = fname
in these lines you set fname, wname and sname to the same value.
& is a bitwise operator. In this instance it will work, but better to use && where you mean logical AND.
wave wave0 = $wname
if there is a chance the wave does not exist, use wave/Z
rename wave0 $wname
rename wave1 $sname
Here you use the /N=basename and the /O (overwrite) flag. Consider instead using the /A flag and extracting the wavename from S_waveNames in order to build your rename operation.
I suggest:
LoadWave/J/A/P=GCFolderData/L={0,0,0,0,2} stringfromlist(i,filelist) // load two columns into two waves
// check for success here
rename $StringFromList(0, s_wavenames) $wname
rename $StringFromList(1, s_wavenames) $sname
There may be other errors, these are what caught my eye.
Don't be afraid to experiment with the debugger early in your programming adventures!
execute DisplayHelpTopic "The Debugger"
