Is there a way to hide a drawing layer?
I would like to either hide an entire drawing layer (so any drawings/pictures in it are invisible), or hide individual items in a drawing layer. By "hide" I mean all the items are still there, so that a simple "unhide" command shows them again.
jjweimer
One option is to capture the contents of the drawings using SetDrawEnv gstart, name=... (your drawing commands) SetDrawEnv gstop. You can delete or restore this captured environment as you need. As an easier approach, you might consider drawing a non-transparent box on top of the existing items to hide them, and then remove the box cover as needed to unhide them.
tony
You can also use
DrawAction/L=userfront commands
to save the commands needed to redraw a layer, then
DrawAction/L=userfront delete
to delete the layer.
To recreate the layer, step through the lines of s_recreation and execute each in sequence:
function RecreateLayer(string s_recreation) wave/T w = ListToTextWave(s_recreation, "\r") for (string s : w) Execute s endfor end
