Non-negative matrix factorization
In developing the hyperspectral browser project I have been playing a bit with various methods of dimension reduction, including principal components analysis and non-negative matrix factorization. Here is the base algorithm for NMF. For my application this gives interesting results with a randomly seeded input, but the solutions it finds are always local minima. It looks like there are some interesting methods for adding constraints to this algorithm, but I haven't yet been able to figure out any of the more advanced algorithms. If anyone has experience with these, please let me know!
Here is the simple version. The input is a 3D wave, and the output components describe the layers dimension of the input data.
// the rows of matrix H contain the estimated components // the output matrix NMFcomponents maps the proportions of components function NMF(wave w3D, variable components) variable rows = DimSize(w3D, 0) variable cols = DimSize(w3D, 1) variable layers = DimSize(w3D, 2) variable pixels = rows * cols variable mincycles = 1000, maxcycles = 2000 Duplicate/free w3D w_input Redimension/E=1/N=(pixels, layers) w_input w_input = max(0, w_input) // rows of W are pixels of w3D, columns are z-dimension of w3D Make/O/N=(pixels, components)/Y=(WaveType(w_input)) W Make/O/N=(components, layers)/Y=(WaveType(w_input)) H W = abs(gnoise(1)) H = abs(gnoise(1)) int i variable err_old = Inf variable start = ticks for (i=0;i<maxcycles;i++) MatrixOP/O W = W * ((w_input x H^t) / ((W x H) x H^t)) MatrixOP/O H = H * ((W^t x w_input) / ((W^t x W) x H)) if ((ticks-start)/60>10) Make/N=(rows, cols, components)/O NMFcomponents NMFcomponents = W[p + q * rows][r] DoUpdate DoAlert 1, num2str(i) + " iterations completed.\r\rContinue?" if (v_flag == 2) break endif start = ticks endif if (i >= mincycles) MatrixOP/O err = sqrt(sum(sq(w_input-(W x H)))) if(err[0][0]/err_old > 0.9995) break endif err_old = err[0][0] endif endfor Make/N=(rows, cols, components)/O NMFcomponents NMFcomponents = W[p + q * rows][r] return i end
Hi Tony,
I assume that you are aware of the MatrixFactor operation with /out=2. Considering that the results are non-unique (subject to constraints), have you tried to compare the results of your algorithm with the built-in operation?
AG
June 2, 2025 at 04:25 pm - Permalink
I didn't know about the built-in operation. I'm trying initially to reduce data sets of say 1000 rows and 500 columns to just 3 components. The built-in operation, which I am sure is much more robust than my naive two-line matrix multiplication, complains about non-convergence and reseeds the random inputs a few times before giving up.
Looking at the components output from MatrixFactor (factorBmat after MatrixFactor gives up), they are mostly not as nice a solution as the ones I typically get from my test code, and MatrixFactor is much slower. What I mean by nice is how much they look like the components used to create a fake dataset.
I'll explore a bit more by varying the adjustable parameters for MatrixFactor.
June 3, 2025 at 03:59 am - Permalink
Hi Tony,
Can you please email me the examples you tried so I can look into them in more detail.
AG
June 3, 2025 at 12:25 pm - Permalink
