Word wrap graphs in Igor
Hey team
Real simple question about graphing in Igor Pro 9.
I have tried googling the answer, and maybe I am not using the right keywords, but I havent had much luck.
I am making a bar graph and the names of each bar is quite long.
This means that when I resize the graph the words overlap each other (see image).
I was wondering if there was a way to word wrap (or carriage return) these names so that they take up multiple lines rather than a single line.
I tried putting the \r into the names in the table, but that keeps the names the same length but puts a return arrow in the name, which is not helpful (See image)
I also tried the \n into the names but it comes up with <??> in the name
Im sure theres some really easy way to fix this. But I am very new at Igor.
Thanks in advance
Daniel
Return symbol Graph with names
johnweeks
That carriage return symbol indicates that you have used "\\r". You need simply "\r". Escaping correctly can be challenging!
johnweeks
I was missing the fact that all this was happening in a table. Indeed, there isn't a good way to insert a carriage return into a table via the table's editor. You can use assignment to a text wave's cell- in that case, "\r" will put in a carriage return.
Sorry for my misunderstanding.
