Adjusting spacing between letters in text?
In an annotation, text object, etc. (anything using a text string), is there a way to adjust the spacing between letters? This is called "kerning" when applied between 2 characters or "tracking" when evenly applied across a word. Being able to adjust the tracking for a text string seems to be the cleanest solution. Some of the fonts I want to use on graph have the characters a bit too crowded, especially when using things like colons or other symbols. I'm using version 10.00.
Is the problem better handled by avoiding the offending font face altogether? Also not just for the specific issue that you raise. I am becoming more aware of requests that published content should be readable by wider audiences (meaning it should meet US ADA compliance standards). Part of this push, as well as the push to meet stricter PDF/A standards, includes the demand that the final electronic document contains all font specs. With all the convolutions to meet these conditions, I find myself reverting back simply to the two old-school standards of either serif Times or sans serif Helvetica as the safest bets for everything.
Also, as someone who can be a pedantic pest about such things, I typically wag my finger angrily at graphs that go overboard with esoteric variations in color, in font face, in font sizes, or in font styles (let alone combinations of all these factors all at once). Are you really making the message of the graph content stand out better, or is the flare distracting?
Otherwise, if IP10 does not include a kern setting for display text, could it be munged by typing the text in a kern-aware editor (e.g. LaTeX), generating an image box of the result, and pasting the image box in the graph? I've done such things for complex math content that is to be added as annotations.
Just a few thoughts.
February 11, 2026 at 09:35 am - Permalink
The graph is fairly simple, but I'm under a corporate template for this poster that needs to use all the same font (it's called EuroStyle font). As far as 3rd party software, I can easily do this to the text in Photoshop, then insert that onto the graph, but I was wondering if there was something easier I was missing in Igor.
Here's a screenshot.
February 11, 2026 at 11:20 am - Permalink
My apologies. My lecture on the evils of those making uncharacteristically non-standard font choices is probably better passed to your corporate administration. If you will allow, I attach a recommendation for improving the visual separation of data (the lines), context (the title), and parameters (the other annotations). One recommendation that is not shown -- change the lines to "color safe" colors and/or use different line styles. For example, folks with certain color-blind traits will see three black lines on your graph.
February 11, 2026 at 12:14 pm - Permalink
It's funny, we have corporate requirements for the font/colors/logos, the "common look and feel", but nothing to support things like color blind folks. Figures!
The details of the 3 lines isn't particularly important, just the fact that there are 3 and they average to the correct value. The ambient is called out as an annotation because the X-axis is time, not temperature.
Thank you.
February 11, 2026 at 12:16 pm - Permalink
The US academic world faces an April deadline. Any electronic document posted thereafter for student consumption must be ADA compliant. A concern from this deadline is that all content in an electronic document must be able to be parsed to read-aloud for the visually impaired. So, while your original figure may not be flagged as non-compliant for using non-color safe colors, it would be flagged if it did not include an embedded alt text description in the electronic document itself. As to why I mention color-safe demands, some time ago, I had a student call me out on my slide content because I tended to use the basic three RGB + black color scheme. He could not distinguish the differences between various (important) aspects of my graphs because they were all the same to him. I'm returning now to that lesson as I seek to compile my notes into a publishable book or booklet format.
I might wonder in closing, if you would want something to consider as a way to leave a lasting legacy before retirement in a US corporation, start asking whether failing to heed to strict PDF/A and US ADA standards when generating electronic corporate documents, especially when documenting what should be archival resources about company standards, could put anyone in legal jeopardy later. If you want to make a change happen, aggravate the lawyers, not the visual marketing folks.
Hope your poster meets with good acclaim!
February 11, 2026 at 01:25 pm - Permalink
May I suggest an incredible dirty hack? You could add a very small space character in-between every character (or selected characters) of the text via a script to fake kerning. For tracking it is even easier, since you only need to replace the space characters. Something like this (adjust the percentage to your liking):
Note that the \M escape also resets any subscript, superscript and other related font settings, so it is more complicated in general. I think you don't have that in your labels. So you just need a script which...
If you have a small example experiment, I could give it a try.
February 11, 2026 at 06:58 pm - Permalink
I can also suggest a hack - I would not call it dirty, but rather arduous. You can insert the different kerning spaces with Unicode characters. Look for the UTF-16 encodings of Em space, En Space, Third Space, Quarter space, Sixth space, thin space and hair space. You can then insert these in the "Add Annotation" window by choosing "Character" and "Enter Character".
I hope that this also works for the font that you have to use.
Best,
Klaus
Edit: I found this collection - probably more space than you want: https://www.compart.com/en/unicode/category/Zs
February 12, 2026 at 03:45 am - Permalink
Clever. Perhaps storing the command to apply only where needed would avoid the resetting issue `\[0\Zr050 \M\[1`?
February 12, 2026 at 09:33 am - Permalink
JJ, I almost thought you had a solution, but unfortunately the font info is very minimal and does not contain, e.g., the subscript state of the text. See here:
February 12, 2026 at 06:29 pm - Permalink
Apologies chozo. I was immediately inclined only to suggest adding the push/pop codes \[0 \]0 and \[1 \]1 (and so on if needed) because I imagined you were already working diligently on crafting a function call to handle any case that came forward. :-)
If I was crafting such a generic function, I'd likely try to push all characters into a text wave, parse out the escape codes, pad all characters with a space after each one, bracket the text segments with the replacement call, and reassemble the entire thing back to a string. Or I'd go one character at a time through the text string using some type of switch or strswitch parsing. Or there is probably a REGEX method.
My head hurts already.
It is probably easier to adjust each label and annotation manually.
Ugh!
February 12, 2026 at 06:58 pm - Permalink
To be honest, I already do a similar thing in my Graph Tools ( https://www.wavemetrics.com/node/21562 ). In the Graph Size panel I have controls to add and modify annotations on the fly. The solution to changing font properties is as you describe: I have to disassemble the whole text into its components, shove in escape codes into the exact right positions and reassemble the whole thing without hiccups. If I would list all the details you have to watch out for, I think I would exceed the comment limit. It has been a real pain and involves a lot of SplitString calls and other such unholy code, and I think it is still not perfect. But similar to you, my head hurts just from thinking about this particular feature, so I will not touch it again until really necessary.
February 12, 2026 at 07:24 pm - Permalink
If you are adjusting the kerning/tracking yourself instead of using what is encoded in the font's tables, doesn't that already defeat the purpose to some extent?
In any case, as far as I can tell, the Qt framework that Igor uses defaults to using a font's kerning information and only allows one to disable using that information, not to use different kerning.
I asked Copilot about this particular situation and it gave me a lot of smack talk against various versions of the Eurostile/EuroStyle font, and then said that I could confidently tell my user:
“If you need Eurostile with correct kerning in Qt, use Eurostile Next or Eurostile LT Std from Linotype/Monotype. Free or older clones often have broken kerning tables, which causes the overlapping letters you’re seeing.”
I then asked it to provide a citation I could provide that discusses these known issues with the font, and it said:
"Absolutely — and you’re right to ask for something you can point to, rather than relying on “an AI said so.” The tricky part is that there’s no single canonical article titled “Eurostile kerning is broken in many versions”, but there are reputable, citable sources that document..."
Then it gave me some links which were either dead or linked to pages that didn't say what Copilot said the page said.
I also searched for "are there known problems with kerning in the EuroStyle font?" and its AI response also seemed to indicate that there are known issues with the font's kerning, but I don't think the sources it cites reflect that.
If you're going to use Igor for the text, I think that Klaus's suggestion is probably the best alternative to getting a different version of the font with better kerning tables. Copilot gave some downsides of using this approach:
"Should you tell the user to insert Unicode spaces?
You can, but you’re right — it’s a hack, and it will break:
It’s better to avoid this unless they’re doing a one‑off graphic layout."
Igor can't do text reflow and I doubt localization is an issue but depending on how you plan to use the output the rest of those might be issues.
February 13, 2026 at 09:05 am - Permalink
