Specs for IP 10 on ARM-based macOS
As we hear more about folks running IP 10 on ARM-based macOS machines, I am starting a thread for posting spec comparisons.
To set a baseline, this is 21 trials with IP 9 on an 8 core i9 MBP with 32 GB 2667 MHz DDR4, 256 kB L2, and 16 MB L3.
Create new graph time: 166.02ms, relative speed= 1.04
big data update time: 34.90ms, relative speed= 1.00
curve fit time: 252.03µs, relative speed= 0.95
user curve fit time: 2.86ms, relative speed= 1.01
double complex fft time: 294.03µs, relative speed= 1.08
single complex fft time: 260.89µs, relative speed= 1.09
double real fft time: 136.18µs, relative speed= 0.97
single real fft time: 137.59µs, relative speed= 0.99
5 pass smooth time: 207.55µs, relative speed= 0.97
Sort 8192 points time: 5.06ms, relative speed= 1.00
WaveStats time: 78.35µs, relative speed= 1.03
simple eqn time: 143.20µs, relative speed= 0.99
exp eqn time: 185.66µs, relative speed= 1.00
sqrt eqn time: 161.97µs, relative speed= 0.99
sin eqn time: 130.14µs, relative speed= 1.00
User fit fctn time: 102.02µs, relative speed= 0.98
MatrixOp eqn time: 35.38µs, relative speed= 1.00
**** done ****
total test time= 6.31326I am especially interested in seeing specs using the M5 chips (when they are available in the Mac-mini computers later this year).
I don't think that the benchmarking suite is particular useful with current machines. The benchmark was developed for a `Dual 2 GHz PowerPC G5 Mac Pro` according to the documentation.
March 17, 2026 at 04:48 pm - Permalink
I can test MBP M1 Pro 32GB RAM. IP10 in W11 Parallels VM, with 2 processors & 6GB RAM allocated to it. I'll get to test M5 when they deliver my new MBP M5 Pro I ordered yesterday. I am not sure if this test is really that meaningful, but why not? I am also interested in seeing what the new M5 improvement is in this case.
March 17, 2026 at 05:27 pm - Permalink
Is there a better benchmark to spec IP 10 in emulation on ARM-based Macs? Especially in comparison to IP 10 on an Intel Windows?
I will be curious to see the performance improvements. For various reasons, I'm leaning now to wait for the M5 mini. Same power (or more), lower cost.
March 17, 2026 at 06:11 pm - Permalink
I ran the tests on an M1 Pro (16 GB, 10 cores). I compared Igor Pro 9 (Rosetta 2) with Igor Pro 10 (Crossover 26).
Igor Pro benchmark 2.02 (File -> Example Experiments -> Testing -> benchmark 2.02)
Igor 9 (Rosetta 2):
Igor 10 (Crossover 26):
However, I wonder if this test is useful for this type of processor. A Mac with 10 cores would benefit greatly from multi-core-optimized processes. I can't find the keyword "threadsafe" in the procedure of the benchmark.
Additional information for MacBook Air, 24 GB RAM, M4 (Crossover 26):
MacBook Air, 24 GB RAM, M4 (Crossover 27 Preview, ARM without using Rosetta):
March 21, 2026 at 06:27 am - Permalink
It's an ancient benchmark. We need to write a new one, but we prefer spending our time on nice new features and bug fixes 😏
March 23, 2026 at 09:46 am - Permalink
Finally got the M5. Unluckily, this is VMWare Fusion, not Parallels.
**** test on Microsoft Windows 11 Pro (25H2)10.0.26200.8457 using 10.02 and 21 passes;
**** 2026 M5 Max 64GB RAM MBP, 6 processors, 6GB RAM assigned to VM
Create new graph time: 56.31ms, relative speed= 5.32
big data update time: 46.48ms, relative speed= 3.08
curve fit time: 519.56µs, relative speed= 3.63
user curve fit time: 3.48ms, relative speed= 10.20
double complex fft time: 122.95µs, relative speed= 11.98
single complex fft time: 118.00µs, relative speed= 10.07
double real fft time: 59.09µs, relative speed= 9.55
single real fft time: 64.31µs, relative speed= 7.65
5 pass smooth time: 124.82µs, relative speed= 4.35
Sort 8192 points time: 4.62ms, relative speed= 8.28
WaveStats time: 118.88µs, relative speed= 2.24
simple eqn time: 209.44µs, relative speed= 6.66
exp eqn time: 325.18µs, relative speed= 6.18
sqrt eqn time: 257.12µs, relative speed= 6.88
sin eqn time: 287.19µs, relative speed= 4.05
User fit fctn time: 121.94µs, relative speed= 10.60
MatrixOp eqn time: 27.70µs, relative speed= 0.86
**** done ****
total test time= 3.75903
May 28, 2026 at 10:40 am - Permalink
MatrixOP on M-based emulations appears consistently to be at a disadvantage.
May 28, 2026 at 01:30 pm - Permalink
MatrixOP is optimized for Intel processors, multiple cores and large data sets. The test includes a simple
MatrixOP/O a=b which would not require any processing other than a direct copy.
July 9, 2026 at 01:47 pm - Permalink
