Specs for IP 10 on ARM-based macOS
As we  hear more about folks running IP 10 on ARM-based macOS machines, I am starting a thread for posting spec comparisons.
To set a baseline, this is 21 trials with IP 9 on an 8 core i9 MBP with 32 GB 2667 MHz DDR4, 256 kB L2, and 16 MB L3.
  Create new graph  time: 	166.02ms, relative speed= 	1.04
  big data update  time: 	34.90ms, relative speed= 	1.00
  curve fit  time: 	252.03µs, relative speed= 	0.95
  user curve fit  time: 	2.86ms, relative speed= 	1.01
  double complex fft  time: 	294.03µs, relative speed= 	1.08
  single complex fft  time: 	260.89µs, relative speed= 	1.09
  double real fft  time: 	136.18µs, relative speed= 	0.97
  single real fft  time: 	137.59µs, relative speed= 	0.99
  5 pass smooth  time: 	207.55µs, relative speed= 	0.97
  Sort 8192 points  time: 	5.06ms, relative speed= 	1.00
  WaveStats  time: 	78.35µs, relative speed= 	1.03
  simple eqn  time: 	143.20µs, relative speed= 	0.99
  exp eqn  time: 	185.66µs, relative speed= 	1.00
  sqrt eqn  time: 	161.97µs, relative speed= 	0.99
  sin eqn  time: 	130.14µs, relative speed= 	1.00
  User fit fctn  time: 	102.02µs, relative speed= 	0.98
  MatrixOp eqn  time: 	35.38µs, relative speed= 	1.00
  **** done ****
  total test time=   6.31326
I am especially interested in seeing specs using the M5 chips (when they are available in the Mac-mini computers later this year).
thomas_braun
I don't think that the benchmarking suite is particular useful with current machines. The benchmark was developed for a `Dual 2 GHz PowerPC G5 Mac Pro` according to the documentation.
ilavsky
I can test MBP M1 Pro 32GB RAM. IP10 in W11 Parallels VM, with 2 processors & 6GB RAM allocated to it. I'll get to test M5 when they deliver my new MBP M5 Pro I ordered yesterday. I am not sure if this test is really that meaningful, but why not? I am also interested in seeing what the new M5 improvement is in this case.
**** test on Microsoft Windows 11 Pro (25H2)10.0.26200.7840 using 10.00 and 21 passes;
**** 2 processors & 6GB RAM allocated on MBP M1, 32GB RAM.
  Create new graph  time: 	82.80ms, relative speed= 	3.62
  big data update  time: 	94.71ms, relative speed= 	1.51
  curve fit  time: 	836.57µs, relative speed= 	2.25
  user curve fit  time: 	10.68ms, relative speed= 	3.32
  double complex fft  time: 	212.57µs, relative speed= 	6.93
  single complex fft  time: 	204.52µs, relative speed= 	5.81
  double real fft  time: 	107.64µs, relative speed= 	5.24
  single real fft  time: 	111.06µs, relative speed= 	4.43
  5 pass smooth  time: 	172.94µs, relative speed= 	3.14
  Sort 8192 points  time: 	8.37ms, relative speed= 	4.57
  WaveStats  time: 	258.97µs, relative speed= 	1.03
  simple eqn  time: 	711.66µs, relative speed= 	1.96
  exp eqn  time: 	900.95µs, relative speed= 	2.23
  sqrt eqn  time: 	856.87µs, relative speed= 	2.06
  sin eqn  time: 	675.72µs, relative speed= 	1.72
  User fit fctn  time: 	407.73µs, relative speed= 	3.17
  MatrixOp eqn  time: 	37.79µs, relative speed= 	0.63
  **** done ****
  total test time=   6.67408
jjweimer
Is there a better benchmark to spec IP 10 in emulation on ARM-based Macs? Especially in comparison to IP 10 on an Intel Windows?
I will be curious to see the performance improvements. For various reasons, I'm leaning now to wait for the M5 mini. Same power (or more), lower cost.
ggermer
I ran the tests on an M1 Pro (16 GB, 10 cores). I compared Igor Pro 9 (Rosetta 2) with Igor Pro 10 (Crossover 26).
Igor Pro benchmark 2.02 (File -> Example Experiments -> Testing -> benchmark 2.02)
Igor 9 (Rosetta 2):
**** test on macOS26.3.1 using 9.05 and 21 passes;
  Create new graph  time: 	162.54ms, relative speed= 	1.84
  big data update  time: 	28.27ms, relative speed= 	5.06
  curve fit  time: 	244.43µs, relative speed= 	7.72
  user curve fit  time: 	4.18ms, relative speed= 	8.48
  double complex fft  time: 	154.16µs, relative speed= 	9.55
  single complex fft  time: 	125.10µs, relative speed= 	9.50
  double real fft  time: 	66.58µs, relative speed= 	8.48
  single real fft  time: 	69.04µs, relative speed= 	7.13
  5 pass smooth  time: 	161.03µs, relative speed= 	3.37
  Sort 8192 points  time: 	4.66ms, relative speed= 	8.20
  WaveStats  time: 	78.24µs, relative speed= 	3.41
  simple eqn  time: 	226.08µs, relative speed= 	6.17
  exp eqn  time: 	276.98µs, relative speed= 	7.26
  sqrt eqn  time: 	245.96µs, relative speed= 	7.19
  sin eqn  time: 	221.01µs, relative speed= 	5.26
  User fit fctn  time: 	123.23µs, relative speed= 	10.49
  MatrixOp eqn  time: 	26.84µs, relative speed= 	0.89
  **** done ****
  total test time=   6.0298
Igor 10 (Crossover 26):
**** test on Microsoft Windows 11 Pro 10.0.22000.588 using 10.00 and 21 passes;
  Create new graph  time: 	235.47ms, relative speed= 	1.27
  big data update  time: 	89.89ms, relative speed= 	1.59
  curve fit  time: 	295.30µs, relative speed= 	6.39
  user curve fit  time: 	4.19ms, relative speed= 	8.46
  double complex fft  time: 	162.34µs, relative speed= 	9.07
  single complex fft  time: 	135.54µs, relative speed= 	8.76
  double real fft  time: 	70.35µs, relative speed= 	8.02
  single real fft  time: 	72.10µs, relative speed= 	6.82
  5 pass smooth  time: 	222.81µs, relative speed= 	2.44
  Sort 8192 points  time: 	5.12ms, relative speed= 	7.46
  WaveStats  time: 	151.12µs, relative speed= 	1.77
  simple eqn  time: 	315.68µs, relative speed= 	4.42
  exp eqn  time: 	472.97µs, relative speed= 	4.25
  sqrt eqn  time: 	381.08µs, relative speed= 	4.64
  sin eqn  time: 	217.80µs, relative speed= 	5.34
  User fit fctn  time: 	160.86µs, relative speed= 	8.03
  MatrixOp eqn  time: 	32.98µs, relative speed= 	0.72
  **** done ****
  total test time=   9.97088
However, I wonder if this test is useful for this type of processor. A Mac with 10 cores would benefit greatly from multi-core-optimized processes. I can't find the keyword "threadsafe" in the procedure of the benchmark.
Additional information for MacBook Air, 24 GB RAM, M4 (Crossover 26):
**** test on Microsoft Windows 11 Pro 10.0.22000.588 using 10.03 and 21 passes; M4
  Create new graph  time: 	116.66ms, relative speed= 	2.57
  big data update  time: 	47.61ms, relative speed= 	3.01
  curve fit  time: 	276.55µs, relative speed= 	6.82
  user curve fit  time: 	2.39ms, relative speed= 	14.87
  double complex fft  time: 	111.25µs, relative speed= 	13.24
  single complex fft  time: 	89.05µs, relative speed= 	13.34
  double real fft  time: 	46.11µs, relative speed= 	12.24
  single real fft  time: 	45.35µs, relative speed= 	10.85
  5 pass smooth  time: 	145.83µs, relative speed= 	3.72
  Sort 8192 points  time: 	3.49ms, relative speed= 	10.97
  WaveStats  time: 	92.91µs, relative speed= 	2.87
  simple eqn  time: 	139.79µs, relative speed= 	9.98
  exp eqn  time: 	197.30µs, relative speed= 	10.19
  sqrt eqn  time: 	160.78µs, relative speed= 	11.00
  sin eqn  time: 	137.88µs, relative speed= 	8.43
  User fit fctn  time: 	85.19µs, relative speed= 	15.17
  MatrixOp eqn  time: 	22.03µs, relative speed= 	1.08
  **** done ****
  total test time=   4.80224
MacBook Air, 24 GB RAM, M4 (Crossover 27 Preview, ARM without using Rosetta):
**** test on Microsoft Windows 11 Pro 10.0.22000.588 using 10.03 and 21 passes; M4 Crossover 27 Preview
  Create new graph  time: 	97.49ms, relative speed= 	3.07
  big data update  time: 	53.29ms, relative speed= 	2.69
  curve fit  time: 	621.72µs, relative speed= 	3.03
  user curve fit  time: 	4.13ms, relative speed= 	8.60
  double complex fft  time: 	101.98µs, relative speed= 	14.44
  single complex fft  time: 	86.09µs, relative speed= 	13.80
  double real fft  time: 	43.91µs, relative speed= 	12.85
  single real fft  time: 	45.84µs, relative speed= 	10.73
  5 pass smooth  time: 	154.78µs, relative speed= 	3.51
  Sort 8192 points  time: 	9.51ms, relative speed= 	4.02
  WaveStats  time: 	166.33µs, relative speed= 	1.60
  simple eqn  time: 	155.62µs, relative speed= 	8.97
  exp eqn  time: 	227.14µs, relative speed= 	8.85
  sqrt eqn  time: 	185.36µs, relative speed= 	9.54
  sin eqn  time: 	161.82µs, relative speed= 	7.19
  User fit fctn  time: 	121.33µs, relative speed= 	10.65
  MatrixOp eqn  time: 	26.28µs, relative speed= 	0.91
  **** done ****
  total test time=   4.94536
johnweeks
It's an ancient benchmark. We need to write a new one, but we prefer spending our time on nice new features and bug fixes 😏
ilavsky
Finally got the M5. Unluckily, this is VMWare Fusion, not Parallels.
**** test on Microsoft Windows 11 Pro (25H2)10.0.26200.8457 using 10.02 and 21 passes;
**** 2026 M5 Max 64GB RAM MBP,    6 processors, 6GB RAM assigned to VM
 Create new graph  time:     56.31ms, relative speed=     5.32
 big data update  time:     46.48ms, relative speed=     3.08
 curve fit  time:     519.56µs, relative speed=     3.63
 user curve fit  time:     3.48ms, relative speed=     10.20
 double complex fft  time:     122.95µs, relative speed=     11.98
 single complex fft  time:     118.00µs, relative speed=     10.07
 double real fft  time:     59.09µs, relative speed=     9.55
 single real fft  time:     64.31µs, relative speed=     7.65
 5 pass smooth  time:     124.82µs, relative speed=     4.35
 Sort 8192 points  time:     4.62ms, relative speed=     8.28
 WaveStats  time:     118.88µs, relative speed=     2.24
 simple eqn  time:     209.44µs, relative speed=     6.66
 exp eqn  time:     325.18µs, relative speed=     6.18
 sqrt eqn  time:     257.12µs, relative speed=     6.88
 sin eqn  time:     287.19µs, relative speed=     4.05
 User fit fctn  time:     121.94µs, relative speed=     10.60
 MatrixOp eqn  time:     27.70µs, relative speed=     0.86
 **** done ****
 total test time=   3.75903
jjweimer
MatrixOP on M-based emulations appears consistently to be at a disadvantage.
Igor
  1. MatrixOP is optimized for Intel processors, multiple cores and large data sets.  The test includes a simple
    MatrixOP/O a=b which would not require any processing other than a direct copy.
  2. I agree with @thomas_braun's observation that the tests are too old and are inadequate to measure modern hardware.
