Loading waves from "ragged" CSV files (Help!)
I'm trying to load what the internet is calling a "ragged" css file. Because of the collection method, it's missing data on various rows. There are no commas to indicate missing data.
In example:
I tell Igor that there are 5 columns, without headers, start loading data from the first row. I give it the column names A,B,C,D,E,F.
Data in the file looks like this:
1,2,3
1,2,3,4,5
1,2,3,4
1,2,3,4
1,2,3,4
1,2,3,4,5
1,2,3,4,5
1,2,3,4,5
1,2,3
I'm expecting it to load these waves:
A = [1,1,1,1,1,1,1,1,1]
B = [2,2,2,2,2,2,2,2,2]
C = [3,3,3,3,3,3,3,3,3]
D = [NaN,4,4,4,4,4,4,4,NaN]
E = [NaN,5,NaN,NaN,NaN,5,5,5,NaN]
F = [NaN,NaN,NaN,NaN,NaN,NaN,NaN,NaN,NaN]
My current loadwaves command looks like this:
LoadWave/A/J/D/O/E=0/B=columnInfoStr/E=1/L={0,1,0,0,0}/W/R={English,2,2,2,2,"Year-Month-DayOfMonth",40} path
You did not provide an example file, but pasting the numbers into a text file and using your LoadWave command on it loads the data just fine exactly as you want. You do not post what you input as columnInfoStr, so it is impossible to give advice here. Maybe you are confused by the treatment of rows and columns which is a bit different to some other programs. Igor is a column-major application. What is the issue here, i.e., what does not work for your?
July 21, 2026 at 08:12 pm - Permalink
Use FReadLine:
•LoadRaggedCSV("home", "RaggedDelimitedTextData.txt",2, 6) // load starting at second line, assume 6 columns
•Edit/K=0 root:A0,root:B0,root:C0,root:D0,root:E0,root:F0
July 21, 2026 at 09:03 pm - Permalink
The file I created from your example
July 21, 2026 at 09:06 pm - Permalink
The problem with LoadWave/J (Load Delimited Text) is that it determines the number of columns to load from the first line to be loaded. It also expects that there is a delimiter between each column. So, if your first line loaded is:
1,2,3
LoadWave will create three waves. To make it create 5 waves, you could change the first line to:
1,2,3,,
You don't need to change all of the lines, just the first one to be loaded.
Your LoadWave command uses /L={0,1,0,0,0}. The "1" means that the first line to be loaded is line 1 which is the second line in the file (since Igor uses 0-based numbering). Unless there is a blank line in the file above the first line of data, you can omit the /L flag.
July 21, 2026 at 10:18 pm - Permalink
Jim ... Off the top of my head, I wonder if you need two FReadLine passes. At the first FReadLine pass, read each line into a (one column) text wave. End with a text wave having as many rows Nr as the number of rows appearing in the CSV. Do the rest of the processing internally. Create a wave nValueswave with Nr to hold how many text entries are in each slot of the text wave. Find the maximum number in nValueswave -> This is the number of columns Nc to create. Create a matrix Nr x Nc with NaN entries. Fill only those slots needed in the matrix from the text wave using the entries in nValueswave. Finally, split the matrix to Nc waves of length Nr.
July 22, 2026 at 05:39 pm - Permalink
In reply to Jim ... Off the top of my… by jjweimer
JimProutyYou are right, of course. Mine was just a simple working example of how it could be done.
July 22, 2026 at 06:37 pm - Permalink
when loadwave doesn't offer a direct solution, i might go about it like this:
use grep to dump file into a textwave:
make a 2D wave with/N=(numpnts(textwave), numcolumns)
set wave2d = stringfromlist(q, textwave[p], ",")
use splitwave to create output waves
it's not tidy and it's not efficient, just another way to do the same thing.
July 23, 2026 at 02:56 am - Permalink
