    igor NIDAQmx tutorial? support for USB cameras?
I recently downloaded the trial version of NIDAQmx tools(http://www.wavemetrics.com/products/nidaqtools/nidaqtools.htm) as it made it sound like I could create code to run USB devices. I have a USB camera which I want to make a program for to do time lapse imaging.
My problem is I can't find any good tutorials on programming with the NIDAQmx. Also I'm not 100% certain about it supporting a USB camera. Does anyone know of a resource for learning how to use NIDAQmx tools for igor? The manual on the website wasn't very helpful to me.
Also am I trying to do something impossible with the NIDAQmx tools for a usb camera?
Igor ships with some XOPs that can control cameras. Look in "Igor Pro Folder\More Extensions\Data Acquisition\Frame Grabbers".
June 19, 2012 at 08:53 pm - Permalink
I looked at the startMStimer function, but that just seems to only be useful for reporting times, not as a time variable in a time loop.
June 21, 2012 at 11:51 am - Permalink
Although what I posted above would be an infinite loop, you can impose conditions to stop.
June 21, 2012 at 12:31 pm - Permalink
June 21, 2012 at 01:00 pm - Permalink
The cavaet here is that timing precision of the entire loop has to be tested to confirm it is within your bounds. Grabbing a frame and executing the loop statements take a finite time. So for example, suppose that while this statement sleeps for exactly 1 s, the overhead on other steps add 600 micro seconds until you return to this sleep again. By 1000 frames, you are 6 ms off step from capturing a frame at exactly 1 s increments.
June 21, 2012 at 07:38 pm - Permalink
Actually this may be a moot point. If you test the frame grabbing time in low-end devices, you will find sufficient variability depending on the content of the image. In other words, you can't expect a constant/accurate frame rate from this arrangement.
June 22, 2012 at 11:21 am - Permalink
Oh! Yes, that makes sense, either from the perspective of the variability in camera processing or the USB buffer transfer. Thanks for the info.
June 23, 2012 at 05:50 am - Permalink
