Fill all points in a wave with a certain value?
Is it possible to fill a wave completely with a certain value without using a loop?
For example after performing
Make /O /N=5
, is there a way (besides a loop) to assign "nan" or "0" to all points in the wave?
Greets,
Peter
zhen
johnweeks wrote:
Make/O/N=5 wave0=NaN
Make/O/N=5 wave0=0
DisplayHelpTopic "Waves"
and in particular,
Hello John
I'm in a similar problem.
I need to make a wave with same number points as the other one, so I use Make/O/N=(numpnts(wave0)) wave1
Now I need all points in the new wave as integers as 1,2,3.....
How could I make it?
Thank you so much.
hegedus
If your new wave has the default scaling, i.e. start at 0 and delta of 1.
then:
Newwave = x
will populate it with values 0,1,2,3,4.
if you want the first value as 1
Newwave = x+1
gives 1,2,3,4,5
zhen
hegedus wrote: If your new wave has the default scaling, i.e. start at 0 and delta of 1.
then:
Newwave = x
Newwave = x+1
gives 1,2,3,4,5
Yes! It works great. Thanks again!!!
In reply to by hegedus
Jakub
then:
Newwave = x
Newwave = x+1
gives 1,2,3,4,5
For some reason, when called inside of the function, this gives me a wave filled with ones (or with twos if x+1 is used) but called from the command window it works ok. What am I missing here?
chozo
Just use Newwave = p+1 for using the point counter instead. Problem solved, unless you have assigned p as a separate variable as well, I guess! ;-)
